best badge adhesive
mar3kl Avatar
mar3kl Mark Lambert
San Francisco Bay Area, USA   USA
It's time to attach the GT Special badges to my fenders, and I'm wondering what the best adhesive is to use. Ordinary contact cement should work, but I'm concerned I'll never be able to get the badges off again if for example I need to repaint the fender some day. Will the old hair dryer and dental floss trick work on parts attached with contact cement or do I need to use something different, like rubber cement?
pooch2 Avatar
pooch2 aussie 1968 MK 1
By the Beach, south coast NSW, Australia   AUS
Contact cement will probably dry out and fracture and fall off.
Sicaflex or other urethane is best.
bleteaches6 Avatar
Bonney Lake, WA, USA   USA
Go to an automotive paint store and get the 2 sided tape that they use. The door ding side trims on my Ford are all put on with 2 sided tape.
Car Prep Inc. Avatar
Car Prep Inc. Chuck Methven
Corona, CA, USA   USA
1997 BMW Z3
Don't glue them on!!! 3M double sided tape is what you want. You may have to trim it down to fit your badges but it will hold them on forever. It's what the automakers use on all their OEM badges. You may be able to purchase it at an auto parts store but if not an automotive paint store like Lee suggested.
Cheers!!
Chuck
thomaslea1 Avatar
thomaslea1 Tom Lea
White Heath, Central Illinois, USA   USA
For what you're doing, just go to any auto body shop and they'll probably give you enough 2-sided tape for that.
mar3kl Avatar
mar3kl Mark Lambert
Thanks for the advice - found the 3M emblem tape at a local auto paint and finishing store. Now I just need to make sure the badges are extra squeaky clean on the back, since the tape is very thin.
scottydawg Avatar
scottydawg Scott B
MTP, SC, USA   USA
I'd take some wax remover to the paint where you are installing them so they stick forever. Goof-off will work too.
"Since the creation of the Internet, the Earth's rotation has been fueled, primarily, by the collective spinning of English teachers in their graves."
"Keep in mind that free advice can frequently be worth less than you pay for it."
Les Brown Avatar
Wirral, UK   GBR
1972 MG MGB GT
1972 MG MGB GT "Brum"
I just taken a badge of the back of my GT,its been put on with silicone sealent,almost broke it in 2 removing it.
The BL badges were put on with those double sided sticky foam like the type thats used on rear view mirrors,then when you come to remove it your just breaking the foam,rest comes off with goof off.
Spinal Tap Avatar
Spinal Tap David N
Chicago, IL, USA   USA
1974 MG MGB "Nigella"
In reply to a post by bleteaches6 Go to an automotive paint store and get the 2 sided tape that they use. The door ding side trims on my Ford are all put on with 2 sided tape.
You can pick up the same stuff at Home Depot, Menards (where I got mine), probably Lowe's too. Just get 3M Heavy-Duty doubles sided tape.
When I did mine, I could see where they old tape had been. So if it was good enough "back in the day", it's probably still a good way to go.
1955 MG MGA 1500
