74 MGB - Shock Absorber Replacement
Posted by MagnumRT05
MagnumRT05
Richard F.
Apr 11, 2011 02:44 PM
Finally got my 74 MGB out of storage and it seems to have developed a leak on the drive home. I assume its the front shock absorber as there is mineral oil all over the ground. It seems to be coming from the arm (I have attached a photo). Please correct me if I am wrong however.
My questions are, how difficult is it to replace? And more importantly, is there anything else I should buy while I am under there (bushings/etc)? The car hasnt been driven much over the last 7+years, and I dont recall any new front suspension components over those years either.
Philly 'burbs, PA, USA
Apr 11, 2011 02:54 PM
Joined 16 years ago
Richard,
Indeed a leaking shock. I'd recommend that you remove both front shocks and send them off to Peter Caldwell at World Wide. You can find his contact info in the Directory on the left side of your screen, and he is a long-time and respected member of this Forum, and also pretty much the source for refurbishing lever shocks. You'll find many, many satisfied customers here on the MGE.
Might-as-wells include rebuilding king pins and replacing bushings. Some prefer stock bushings, some prefer poly. You might also replace sway bar links and bushings. Do a search and check the library for more info. All depends on how well it rides and how deeply you want to get into the front end. Unlike the rear leaf springs, front springs often do not require replacement unless there is noticeable sag in the front end.
Apr 11, 2011 02:55 PM
Richard,
Welcome to the land of "might-as-wells". This can range anywhere from replace the shock to a full front-suspension rebuild to "might-as-well" do the rear at the same time.
On the other hand, you could fill will oil periodically and use thru the driving season, repair while its snowing! As long as its not rattling or banging, probably no harm to drive it. Might check with Peter Cadwell on that suggestion.
MagnumRT05
Richard F.
Apr 11, 2011 09:40 PM
Thanks guys. As a matter of fact, I found World Wide on ebay after posting this thread. It looks like their "improved" design is a must upgrade. I suppose I could fill the leaky shock periodically, but the darn thing is leaking pretty good and making a mess everywhere.
And I think some poly bushings will be on the list as well. Fairly inexpensive and Im sure I have some brittle ones anyway due to this climate.
Are there any special tools required for the shock install or is it straightforward? I had a Bentley manual somewhere that Im sure would tell me, but it seems to have been misplaced...
Apr 11, 2011 09:47 PM
Joined 16 years ago
Apr 11, 2011 10:11 PM
Hi Richard
am in process of doing my bushings already purchased from Basil Adams a fellow MGE`r basiladams@yahoo.com best price and good to deal with.
Cheers
Paul
Cheers
Paul
Apr 11, 2011 11:32 PM
Joined 22 years ago
Apr 12, 2011 07:44 AM
Yes the shocks are 4 bolts to remove AND
The shock link bolt to kingpin!
Support the spring pan solidly, loosen pinch bolt in shack arm, remove link bolt at end of arm (hope it comes out easily). Be careful as the stub axle/king pin will want to fall away or pivot
downward. You dont want to put stress on your brake flex line. Finally remove
4 shock mounting bolts. To replace you may have to jam a flat blade screwdriver
into the space between the shock levers where the pinch bolt goes.
RS
Sir Winston Churchill
G.S.George PHD
RS
G.S.George PHD
about 2 years and 7 months later...
missileer79
David T
Huntsville, AL, USA
Nov 23, 2013 05:20 PM
This message is for Robert Schau. You said in your response to removing the shock absorber, "...remove link bolt at end of arm (hope it comes out easily). Be careful as the stub axle/king pin will want to fall away or pivot
downward." Well that darned link bolt (horizontal pin on the lever arm) isn't coming out. Suggestions?
Nov 23, 2013 05:31 PM
Unless you have an oxy/acetelyne rig to heat it, use a cut off wheel in an angle grinder and cut the nut end off then drive what remains out with a small sledgehammer and a punch/drift. Be prepared to swear a lot. Some folks go the penetrating oil route but I didn't have any luck with mine. Replacement bolts are available.
Eric - xcoastie
ET2/E5 Vessel Shore Electronic Support USCG Station Great Egg 81 - 85
1974 Last of the chrome bumpers with Sabrina's
1971 Engine
4 speed synchro, non OD
"A work in progress"
Eric - xcoastie
1971 Engine
