MG Magnette Forum
Oil Filter spin on upgrade
Ian Williams Avatar
Ian Williams Ian W
Has anyone upgraded to a spin on oil filter and are there any complications/adaptions to fitting these please? I'm looking at Moss 235-940 for the kit. Are the filters readily available too?
Thanks
Edited 1 time(s). Last edit at 2021-04-11 08:25 AM by Ian Williams.
riley1489 Bruce H
This is an easy install and uses the hard pipe you have. You will need two new crushable washers for the banjo fitting at the adapter housing.
These kits had, (past tense hopefully) a potential interference in the height of the 'screw on' part (below) wherein not all spin on oil filters were compatible. If this interference remains the oil filter itself will jam tightly to the 'screw on' part and unscrew when you change the filter causing all manner of grief.
Check yours before installing it,
Lay a straightedge across the adapter and if the 'screw on' bit sits proud of the sealing flange then you will need to machine some thickness from this part. (below)
Ensure you use the lock tab as provided, a bit of a bugg*r to bend over unfortunately.
I show a premium Wix ™ filter.
Edited 3 time(s). Last edit at 2021-04-11 12:14 PM by riley1489.
BH_adapt_001.2.JPG    21.4 KB
BH_adapt_004.JPG    24.5 KB
BH_18G OF install.jpg    49.1 KB
mcquaid Avatar
mcquaid James Jans
Hood River, OR, USA   USA
Ian: The filter adapter was very easy to install. Just make sure the washer that has a flap gets bent over to hold the bolt so when you replace the filter the bolt does not come loose. The filter I have is a very popular model a Fram PH3600
'58 ZB
Hood River, OR
20210411_071607.jpg    43.9 KB
20210411_071817.jpg    41.7 KB
philp Avatar
philp Phil Parmenter
Chailey, Sussex, UK   GBR
I installed one of these recently. I would just say that when you bend over the locking washer make sure that it is not proud of the face of the nut otherwise your filter may catch on it and not be able to seal properly. The other thing that happened to me was that the copper washers on the banjo leaked - I substituted fibre washers which stopped the leaks.
about 4 years and 4 months later...
Ian Williams Avatar
Ian Williams Ian W
Thanks Phil
With any copper washers I now anneal them before use.. �
In reply to # 4322299 by philp I installed one of these recently. I would just say that when you bend over the locking washer make sure that it is not proud of the face of the nut otherwise your filter may catch on it and not be able to seal properly. The other thing that happened to me was that the copper washers on the banjo leaked - I substituted fibre washers which stopped the leaks.
Darvie43 David Hill
If any body in Australia wishes to do this conversion i have a new kit available for $50 plus postage.
about 1 week and 1 day later...
mjamgb Avatar
mjamgb michael anderson
Highly recommend!
Filter is common as dirt Ford Item.
Darvie43 David Hill
The kit mentioned above is new and includes the oil filter.
about 2 weeks and 1 day later...
Ghosty Allan Aylward
Berry Park, Nsw, Australia   AUS
Is this still available
Alllan (Ghosty)
0413 622597
Darvie43 David Hill
Yes Allan. $50 or $65 posted.
1976 MG MGB MkIII
