[Solved] Wheel bearing grease: wrong
Solved
  This topic is about my 1967 MG MGB GT
rocannon Avatar
rocannon Gold Member rocannon L
Mansfield, TX, USA   USA
1967 MG MGB GT "GT From Hell"
Solved
Got some new front wheel bearings for the splined to bolt-on wheel conversion. Kit came with Exxon Mobil polyrex EM grease in packet, which I used. Pretty blue color.
As I'm out of grease for my 3oz grease gun, I figured I'd get a tube of that blue grease. Only available in the larger sizes. So I went to the Mobil website to see what alternatives are available in the small tube size.
Surprise, surprise ... that grease is for electric motors (that's the EM part). Now I get to pull and clean the bearings. angry smiley
The moral being: Don't assume. winking smiley
ozieagle Avatar
Highton, Victoria, Australia   AUS
1958 Wolseley 1500 "Wooly"
1966 MG MGB "Bl**dy B"
1995 Toyota Highlander "Hi Ace Van"
2022 MG ZS
Hi Frank,
I use Molygrease, heavy duty, for all my greasing needs. I have a grease gun that accepts a cartridge, does all my nipples (zerks), wheel bearings, brake cable etc.
Herb
albeegreen1 Avatar
albeegreen1 Silver Member bob tresch
bordentown, NJ, USA   USA
1972 MG MGB MkIII "ALBERT"
Kendal EBL It's for wheel bearings. Amazon has it
Kendals been making grease for a long time.
"Only those who have patience to do simple things perfectly ever acquire the skill to do difficult things easily"
James J. Corbett
  mgbtf thanked albeegreen1 for this post
little G Avatar
little G Charlie T
2024 MG MGB "Little G"
That scared the **** out of me...LOLOLOL
I have just been doing wheel bearings . ( not mg )..and my grease is that pretty blue colour !!
I had to go straight out to the garage and check mine...Penrite high temp..phew !
Funny how one can be triggered and self doubt even though you know to have been initially correct..LOLOLOL..
albeegreen1 Avatar
Lucas makes one 2.
James J. Corbett
lewisrn Avatar
lewisrn Gold Member lewisrn L
Danville, IN, USA   USA
1980 MG MGB "The "B"
Always be leery of anecdotal evidence! winking smiley
mattrogers5 Avatar
mattrogers5 matthew Rogers
N.C., Brown summit, USA   USA
Polyrex em grease is recommended by most motor aNd pump manufacturers.... most that specify the grease will void the warranty iffin you don’t use it . I’ve been using it on all my bearings for 20 years and never had a grease related failure. This grease is rated for 80,000 hrs of continuous use. It looks just like you put it in when you repack your bearings every 5 years or so. Plus it’s the grease most all ntn bearings come packed with.
Edited 1 time(s). Last edit at 2020-07-19 06:21 PM by mattrogers5.
little G Avatar
little G Charlie T
Now logically thinking about it...electric motors can rotate at massively greater revolutions than our wheel bearings and for sometimes indefinately...so one would think that it would be better than the normal high temp wheel bearing grease before breakdown ? Though they tend to use sealed bearings in motors..
Yes..correct about anecdotal..lolol
Steve S. Stephen Strange
Harrisonburg, VA, USA   USA
1957 MG Magnette
Bob-
Kendall EBL wheel bearing grease is for use on non-driven axles. That makes it adequate for use in applications such as trailer axles, but not for the driven axle of an MGB! Instead, try Castrol Pyroplex Red EP 2 Grease instead. It can even withstand the heat that is generated by disc brakes!
ErnieY Avatar
ErnieY Ernie Y
Albatera, Alicante, Spain   ESP
Cheap as chips multipurpose grease is all road going MGB ever needs.
You can convince yourself that something else will work better or last longer but you'd be completely wrong.
riley1489 Bruce H
Ernie x2, cheap and cheerful
I use wheel bearing grease that I use for my sailboat boat trailer hubs. These trailer bearings see a much more harsh environment than the MGB.
Ethan Harris Avatar
Little River, SC, USA   USA
I've been using AeroShell Grease #5. Fabulous specs: -20/+177 Deg C, heavy load condition rating, excellent water resistance, etc. AeroShell Grease 5 handles high temperatures from high rolling friction and hard braking which takes into account the 177 Deg C upper limit for this grade. It's overkill for an MGB, but operation is absolutely worry free.
https://www.shell.com/business-customers/aviation/aeroshell/knowledge-centre/technical-talk/techart13-30071520.html contains a simple description of how greases use various oil bases, thickening agents and additives, and how various greases are sometimes mixed.
rocannon Avatar
I hear this is good:
https://www.neobits.com/lubriplate_l0220_004_22004_16_oz_1552_lithium_p1452387.html?atc=gbs
In reply to # 4182888 by ErnieY Cheap as chips multipurpose grease is all road going MGB ever needs.
20DE8B0C-9EDF-4730-B858-1DFBDF25D2C5.jpeg    48.9 KB
Carlosii Charles Roche
Vincennes, Indiana, USA, USA   USA
I use the red stuff for everything. Good enough for John T, good enough for me.
PaulP Avatar
PaulP Gold Member Paul Peterson
Seattle, WA, USA   USA
1973 MG MGB GT
Am I reading that right? $2,069.73 USD for qty: 12, 16 oz containers?
Yikes!! smiling smiley
Edited 1 time(s). Last edit at 2020-07-22 11:22 AM by PaulP.
1979 MG Midget 1500
