What should I use to soak my carb?
MG Larry Avatar
MG Larry Larry Asero
Basking Ridge, New Jersey, USA   USA
This is a follow up to another post. I want to soak my carb overnight to clean out all the crud. What should I use? regular carb spray?
Gerry Avatar
Gerry Gerry Masterman
Prairieville, LA, USA   USA
I use Berryman carb and parts cleaner. A bit expensive and stinks but it works as well as anything else on the market now. The one gallon can has a basket but only allows you to soak one carb body at a time. I much prefer to keep a five gallon bucket on hand to be able to do everything at once. Spray cleaners may work if there is not much gunk in/on the carbs but I'd rather soak and be sure. Gunk may still make a soak type cleaner, too
James74 James D
beach, VA, USA   USA
1978 MG MGB "The Bee"
Weber..? Use a suitable container for the weber (metal paint can works) you can use Gasoline or mineral spirits (stronger odor) but cleans better. Soak it for about 24-48 hours remove it and drip dry use compressed air to blow out the jets and small ports.
Jim K Avatar
Jim K James A. Krasnansky
Liberty, KY, USA   USA
1970 MG MGB GT "Chloe"
1971 MG MGB GT "Roscoe"
1972 MG MGB "Camilla"
I wouldn't use gasoline, but I'm just that way. Mineral Spirits is cheap and works.
Fairfield, CA, USA   USA
depends. sometimes the nasty to be dealt with is rust and corrosion (such as on items obtained via ebay). if all parts move properly and it's just a general cleaning, then a water-based solvent (Simple Green, etc) may work. If it is a case where everything has fused into one solid lump, then the toughest stuff you can find will be needed, ask at a professional store like NAPA or such (I don't put much faith in the minimum wage clerks at AutoZone or even Kragens/O'Reilly).
SUs, Datsun 5-speed
Wray Avatar
Wray Gold Member Wray Lemke
., SC, USA   USA
Berryman's is the best but you should check the parts every couple of hours. Leaving them soak for too long can damage them.
rocannon Avatar
rocannon Gold Member rocannon L
Mansfield, TX, USA   USA
1967 MG MGB GT "GT From Hell"
i wouldn't use gasoline either. it's way too unsafe to use as a solvent/cleaner.
I've seen too many houses burned down and people killed.
You'd be amazed how fast and far the gas vapor will spread without your knowing it.
See this
link
the auto-parts store will have much safer materials specific to that use that's nowhere near as volatile.
btw, get yourself a good half-face mask with chemical filters and splash goggles while you're at it.
frank
tony53 Tony Graham
Glen Alpine, Australia   AUS
1976 MG MGB "@@#&**@"
Don't use a water based engine degreaser. They are almost all caustic and will eat away at the alloy if you leave it more than a little while.
Paint thinners is good & quick, followed by carb cleaner. Brake cleaner works wonders on the outside
1970 MG MGB MkII
