What should I use to soak my carb?
Posted by MG Larry
Dec 19, 2010 07:06 PM
Joined 16 years ago
Dec 19, 2010 07:21 PM
Joined 26 years ago
I use Berryman carb and parts cleaner. A bit expensive and stinks but it works as well as anything else on the market now. The one gallon can has a basket but only allows you to soak one carb body at a time. I much prefer to keep a five gallon bucket on hand to be able to do everything at once. Spray cleaners may work if there is not much gunk in/on the carbs but I'd rather soak and be sure. Gunk may still make a soak type cleaner, too
Dec 19, 2010 08:19 PM
Joined 18 years ago
Weber..? Use a suitable container for the weber (metal paint can works) you can use Gasoline or mineral spirits (stronger odor) but cleans better. Soak it for about 24-48 hours remove it and drip dry use compressed air to blow out the jets and small ports.
Dec 19, 2010 08:39 PM
Joined 22 years ago
Dec 19, 2010 08:55 PM
depends. sometimes the nasty to be dealt with is rust and corrosion (such as on items obtained via ebay). if all parts move properly and it's just a general cleaning, then a water-based solvent (Simple Green, etc) may work. If it is a case where everything has fused into one solid lump, then the toughest stuff you can find will be needed, ask at a professional store like NAPA or such (I don't put much faith in the minimum wage clerks at AutoZone or even Kragens/O'Reilly).
SUs, Datsun 5-speed
SUs, Datsun 5-speed
Dec 19, 2010 09:11 PM
Joined 24 years ago
Dec 19, 2010 09:49 PM
Joined 16 years ago
i wouldn't use gasoline either. it's way too unsafe to use as a solvent/cleaner.
I've seen too many houses burned down and people killed.
You'd be amazed how fast and far the gas vapor will spread without your knowing it.
See this
link.
the auto-parts store will have much safer materials specific to that use that's nowhere near as volatile.
btw, get yourself a good half-face mask with chemical filters and splash goggles while you're at it.
frank
See this
link.
frank
Dec 20, 2010 05:52 AM
Joined 17 years ago
Don't use a water based engine degreaser. They are almost all caustic and will eat away at the alloy if you leave it more than a little while.
Paint thinners is good & quick, followed by carb cleaner. Brake cleaner works wonders on the outside
