Starter Relay Wiring
2003JAG Avatar
2003JAG Gold Member Chuck Hassler
Monument, CO, USA   USA
1968 MG MGC "Blue Boy"
This is an old topic but I need help. I'm installing a new Lucas starter relay for the 80 MGB and need the correct wire placement for the black, brown, white/brown, and white/red wires for posts 30, 85, 86, and 87. The posts in the archives show every possible combination of wires to posts and none of them agree. Thanks.
Chuck
Dave Braun Avatar
Georgetown, TX, USA   USA
1952 MG TD "Tommy"
1970 MG MGB "Maggie"
1974 Triumph Spitfire 1500 "Sammy"
I've not done it, but after looking at the wiring diagram, I would say 85 and 86 would be black and white/red (doesn't matter which) and brown and white/brown would be 87 and 30, again doesn't matter which.
warmly,
dave
rundjk Avatar
rundjk David Kinsey
Virginia Beach, USA   USA
1980 MG MGB "Runaway"
Chuck, I went to the garage and took photos and scribbled. Now, I keep forgeting which is the ignition and which the starter! For simplicity's sake, the first two pix are of the one closer to the front of the car (Relay 1); the next two of the one closer to the firewall (Relay 2).
1) Looking at the relay and and seeing the numbering, then moving the camera around to the wires. Assume the relay is mounted vertically (though mine is tilted a little): the terminal closest to the engine has the White/Brown wire attached; the terminal closest to the fender has the Brown wire; the terminal closer to the front of the car has the Black wire and the one closer to the rear has the White wires.
2) Assume the same vertical orientation: the terminal closest to the engine has the White/Brown wire (as above); the terminal closest to the fender has the Brown wire (as above); the terminal closer to the front of the car has the Black wire and the one closer to the rear has the Red/White wires.
Hope that helps; maybe a wizard will be along soon.
David
David J. Kinsey
Virginia Beach
Tidewater MG Classics
1980 MGB "Runaway"
P1070238.JPG    33 KB
P1070239.JPG    22 KB
P1070240.JPG    33.2 KB
P1070241.JPG    23.2 KB
2003JAG Avatar
Got this from FRM in PA. Very good information.
30 = load power in = N
87 = load power out = W/N
85 = control negative = (earth) = B
86 = control positive = (start signal) = W/R
85 & 86 can usually be swapped, unless the relay has a diode in it(across coil); most don't - it will show on the diagram usually printed on the relay. If the diagram shows a resistor, polarity does not matter. But above is correct for neg earth system.
For that matter, 30 & 87 could be swapped too, but that is contrary to convention, and again, though rarely, some relays have quenching diodes across those terminals.
Chuck
Jim K Avatar
Jim K James A. Krasnansky
Liberty, KY, USA   USA
1970 MG MGB GT "Chloe"
1971 MG MGB GT "Roscoe"
1972 MG MGB "Camilla"
1980 doesn't look like my 1970.
Relay 001.JPG    27.1 KB
Dave Braun Avatar
1952 MG TD "Tommy"
The 1970 uses the w1, w2 and c1, c2 terminals. The actuating coil is w1 and w2 which correspond to 86 and 85, respectively. The c1 and c2 correspond to 30 and 87, respectively.
They work the same, the coil is actuated by a small current and closes the large contacts to send power the the device, in this case the starter solenoid. This keeps the big current out of he little dash or ignition switch.
warmly,
dave
1973 MG MGB GT
