Spraying primer question - paint gun limitations
sdyck Avatar
sdyck Steve Dyck
Calgary, AB, Canada   CAN
1970 MG MGB
Question For all you painters out there;
I bought a LVLP spray gun for painting, one that will run with may mid size compressor.
It comes only with a 1.4mm tip. When I look at most guns recommended for primer the tip is 1.8mm Can I spray all primers with the 1.4mm tip or are there some that have too many solids (ie high build) and wouldn't flow properly?
Thanks
Steve D
'70B - current
B-racer Avatar
B-racer Jeff Schlemmer
Shakopee, MN, USA   USA
You may have issues with thin coats and too fast of a dry time. You will need to thin the primer about 25% more to use the 1.4mm tip, but you should get a nice smooth finish!!! Another option is to go but the cheapest ($30) spray gun you can find for the primer. I have a generic harware store gun that I use for primer and a Sata for the top coats.
dennis70 Avatar
dennis70 Dennis Diiorio
Schenectady, upstate NY, USA   USA
I agree get another gun for the primer, and save the good one for the color coat. By the way I have the same hood support, Moss # 3333321, works great until I try to close the garage overhead door. Dennis70
sdyck Avatar
sdyck Steve Dyck
1970 MG MGB
Hey dennis I've been beat up for using that inferiour part. As a good Canadian I should be using a good Canadian OEM hood support such as this one.
Steve D
'70B - current
hockeymonkey_1929_13657275.gif    2.9 KB
dennis70 Avatar
Thats funny, good luck
Ryan Reis Avatar
Beatrice, NE, USA   USA
1968 MG MGB
I've sprayed Omni high build primer with a hvlp gravity feed gun with a 1.5 tip. Worked fine.
Ryan
Jim1971 Jim Smith
Ladysmith, BC, Canada   CAN
Most manufacturers of primers, finishes tell you which tip and what pressure to use.
The big thing is to clean the gun properly. I leave a bit of lacquer thinner in the gun and remove the nozzle and put it in the gun.
A good gun that you can buy maintenance parts for is worth the extra. Different sizes of tips can be bought. The DeVilbiss HVLP gun that I have was worth the extra.
A PA HVLP is used for primer. The DeVilbiss is used for finish work.
The lower cost HVLP needs to held much closer to the surface. This means that the overlap is harder to get correct.
The DeVilbiss is held 9" to 12” away and gives a consistent 10" t0 12" pattern and flow. This makes it easier to get the finish to flow on even. With the good gun you can see the finish flowing. The PA HVLP is much harder to use.
Jim...Nanaimo, BC
1971 MGB collector
1975 MGB driver
1975 MGB in pieces waiting for V6
2005 Mini Cooper
A wise man overhauls his brakes before his engine.
Martysh Marty Schmitz-Hertzberg
Angus, ON, Canada   CAN
1970 MG MGB GT
I use my Sata with a 1.4 tip for both primer and topcoat.. If you thin the primer sufficiently, there is no problem blowing the solids out..( I use Dupont urethane 2 part high build primer) you can lay on a really nice flat coat..so you end up sanding less paint off!! $$$ saved...
I sometimes think I could just polish it right out of the gun, and it would look like a top coat in the primer grey MGB color...
I think that keeping spray equipment clean is one of the keys to success with this work and not getting frustrated.... every time I use the gun, I break it down and clean everything to as new with laquer thinner, reassemble and put away. It is tedious!!
By the way I used 1 gallon of urethane to completely paint inside and out ..my 65 B.. and I still have some left. Thats how effective a HVLP gun is.
September 03 016.jpg    57.6 KB
Taylors, SC, USA   USA
1961 MG MGB "LL" Lady Lynn"
Thats a pretty blue Marty.
I think having a cheap second gun ofr primer isn't a bad idea as well. Most of this poly primer almost goes on as dry spray anyway. The poly two par primer is one of the best thing to come down the pipeit's so thick it acts a filler for light imperfections and prep sanding. Just get a good coat of primer on the car, most of it will end up in the floor anyway from wet sanding.
1976 MG Midget 1500
