LED Compatible Hazard Flasher
stiffarm67 Avatar
stiffarm67 Joe Herz
Ridgefield, WA, USA   USA
1969 MG MGB GT "The GT"
This is in regards to my 69 GT. So, I had the same problem as several who chimed in a couple weeks ago about having only partial function of LED replacement lamps using the older style electronic flasher units. Taking advice from those members, I purchased 2 of the newer style (lower current sensing) relays for the turn signal and hazard flashers. The turn signal flasher works fine for all 4 corners. That unit needed a separate ground wire connection to the "E" terminal. Simple enough. The hazard flasher is wired different. There is no ground connection on the original flasher wiring so I'm at a loss as to how to wire this relay in.
The photos attached are the new relay, the original (or what was currently installed) and the wiring diagram for a 69.
Any suggestions appreciated.
20180529_181526.jpg    24.3 KB
20180529_181352.jpg    19.2 KB
20180529_181301.jpg    16.1 KB
ZetecMGB Avatar
ZetecMGB Brian Collins
Orlando, FL, USA   USA
We use CEC Industries' EF32 (two terminal) and EF33 (three terminal) electronic flashers. We've used them on dozens of cars and they work great. Best of all, no ground is needed. They're truly plug and play.
Wray Avatar
Wray Gold Member Wray Lemke
., SC, USA   USA
Joe, there are a couple of differences from the OE flasher but would wire in the same way as the turn flasher, brown to the B+ and Lgn/N to the "L". The "P" terminal on the OE flasher is for the indicator light on the console. Since the new module is electronic, it must have a ground to operate whereas the OE module did not need one. So, find a spot to land a wire from the "E" terminal to a good body ground.
You could just leave the "P" disconnected but I think I'd just piggyback it on the "L" terminal. That should make the indicator light work.
jonathan.lipkin Avatar
jonathan.lipkin Silver Member jonathan lipkin
., Long Island, USA   USA
1972 MG MGB "Restoration Project"
2012 Volkswagen Passat
I switched to LED turn signals a few years ago and had to replace the flasher unit with an electronic one, but last time I looked, Moss wasn't selling either the bulbs or the flasher unit any more. Glad to hear there is a replacement possible
stiffarm67 Avatar
stiffarm67 Joe Herz
Thanks Wray. I'll give that a shot.
In reply to # 3745820 by Wray Joe, there are a couple of differences from the OE flasher but would wire in the same way as the turn flasher, brown to the B+ and Lgn/N to the "L". The "P" terminal on the OE flasher is for the indicator light on the console. Since the new module is electronic, it must have a ground to operate whereas the OE module did not need one. So, find a spot to land a wire from the "E" terminal to a good body ground.
stiffarm67 Avatar
stiffarm67 Joe Herz
Brian,
I had the EF32 that a PO had installed. It worked on only 2 of 4 signals. When all 4 corner lamps were installed, nothing. Doing nothing more than replacing with a grounded relay solved that. Could be that the lamps I have (all Sylvania) draw less current - I've read that the CEC style relays do not work well when the current draw is low.
In reply to # 3745816 by ZetecMGB We use CEC Industries' EF32 (two terminal) and EF33 (three terminal) electronic flashers. We've used them on dozens of cars and they work great. Best of all, no ground is needed. They're truly plug and play.
Donthuis Avatar
Donthuis Don van Riet
I noted the classiccarleds company puts stickers on their LED compatible flashers, since people seem to connect the B battery and L light feed the wrong way around, which of course ruins the unit.
I fail to see what is so complicated about connecting an E post or spade to an earth or mass connection for a threewire configuration. If this connecting of 3 spades is already too complicated to understand, better let somebody else do it for you
stiffarm67 Avatar
stiffarm67 Joe Herz
Don,
The OE hazard flasher on my 69 has 3 connections with no ground. The 3 pin LED compatible replacement flasher has 3 pins one of which needs to be grounded. This presents me with 4 connections needed but only 3 terminals available. There is nothing straightforward here which is why I asked the question. Wray in post #3 actually read and understood my post and I'll be trying his suggestion.
Joe
In reply to # 3745917 by Donthuis I noted the classiccarleds company puts stickers on their LED compatible flashers, since people seem to connect the B battery and L light feed the wrong way around, which of course ruins the unit.
Donthuis Avatar
Well it's time then to change isn't it? Use the Advance diarams of a later year with two pin connections on the flasher and buy and install the 3 pin variant with the thiird pin on earth/mass.
If it is not straightforward now, make it for the future I would say. "KISS is keep it simple stupid", assure you are not the stupid one here on MGE eye rolling smiley
In reply to # 3746148 by stiffarm67 Don,
Joe
stiffarm67 Avatar
stiffarm67 Joe Herz
Wow Don. That's twice you have insulted my intelligence. We're done here.
In reply to # 3746172 by Donthuis Well it's time then to change isn't it? Use the Advance diarams of a later year with two pin connections on the flasher and buy and install the 3 pin variant with the thiird pin on earth/mass.
Joe
Wray Avatar
., SC, USA   USA
Don, not everyone lives in the world of electronics like some of us, they just aren't as familiar with it and don't want to, a) blow something up or, b) cause extensive damage to their cars. Ease up a little.
Ahmed Avatar
Ahmed Ahmed A
Calgary, AB, Canada   CAN
1958 MG MGA
1972 Volvo P1800
Joe,
Looking at your wiring diagram, the "P" is for the hazard indicator light on the dashboard. This function got moved to the hazard switch in later models, I am assuming so that they can use similar relays for turn signal and hazard.
In your case, connect your new relay as follows:
"BI+" to the brown wire (was B on the original relay)
"L" to the light green/brown wire (was L on the original relay) and to the light green/purple (which was P on the original relay). You could use a piggyback terminal like the one below if you do not want to splice/solder the wires.
"-IE" to a ground point (earth). I usually run a black wire with a terminal to the screw which holds the relay in place.
Pretty much what Wray suggested in his reply above.
My 1958 MGA is not a car, it's a CAREER..!! ... angry smiley angry smiley
Edited 1 time(s). Last edit at 2018-05-30 03:10 PM by Ahmed.
stiffarm67 Avatar
stiffarm67 Joe Herz
Ahmed,
Yep. Makes sense and same thoughts as Wray. Thanks much.
In reply to # 3746224 by Ahmed Joe,
1971 MG MGB GT
