Intermittent ticking noise from engine at idle
Posted by Darrelljb
Apr 16, 2026 02:51 AM
Joined 5 years ago
Hi,
I'm getting an intermittent ticking noise from engine at idle. I've set the tappets and all seemed ok. The noise comes and goes. I cant hear it at higher revs due to general engine noise.
Any ideas what it might be please and should i be concerned?
Thx
Thx
Apr 16, 2026 05:47 AM
Joined 5 years ago
Darrelljb thanked mg rob uk for this post
Apr 16, 2026 10:41 AM
You can also use a spray bottle and spray plug wires. If the wires are going bad you'll see blue sparks. Is there an engine fire miss with the tick. Some times a stethoscope can help locate the source. Remove belt and see if noise goes away.
Ben
1966 MGB Tourer
1973 MGB Tourer
Ben
1966 MGB Tourer
1973 MGB Tourer
Apr 16, 2026 11:28 AM
Sometimes an exhaust leak will make a ticking sound. Use a length of heater hose as a stethoscope to narrow down the source. It won't amplify the sound but with one end aimed at potential sources and your ear at the other end, when you get close the sound will be more evident.
Also, worn rockers can make it difficult to set clearances. If the rocker tip is worn your feeler gauge might be bridging the wear.
See: https://www.mgaguru.com/mgtech/engine/ch200.htm
Eric Russell ~ Mebane, NC
1961 MGA #61, 1̶9̶8̶1̶ ̶A̶l̶f̶a̶ ̶R̶o̶m̶e̶o̶ ̶G̶T̶V̶6̶, 1984 Alfa Romeo Spider, 1991 Honda ST1100
Apr 17, 2026 09:25 AM
I had an intermittent ticking sound when I put the
second MGA on the road.
It was a small wrench on the frame bouncing joyously on the lower pulley.
Immense relief followed that discovery.
The Flat Earth Society has members from all corners of the globe.
'53 XK120SE OTS
'58 MGA roadster
'66 Series 1, 4.2 Jag E-Type OTS
'53 XK120SE OTS
'58 MGA roadster
Apr 17, 2026 06:15 PM
MGBGM1977
Anthony Piper
Apr 18, 2026 06:01 AM
He said it was a wrench.
In reply to # 5043170 by NOHOME
An often overlooked source of noise can be a worn rocker shaft. Easy enough to move a rocker over against the locating spring and check for wear under the shaft ( the shaft only wears on the bottom)
Apr 18, 2026 08:57 AM
That was not the OP, just someone else telling us about a similar experience.
Ben
1966 MGB Tourer
1973 MGB Tourer
In reply to # 5043229 by MGBGM1977
Ben
1966 MGB Tourer
1973 MGB Tourer
Apr 18, 2026 11:34 AM
https://youtube.com/shorts/LONT1oboJrs?si=X4LiQ6rowqF_02hP
MGBGM1977
Anthony Piper
Apr 18, 2026 02:02 PM
Woops, I missed that. I am OLD and BLONDE after all.
In reply to # 5043255 by bencii
