Compression Testers - Snap on VS Harbor Freight
Posted by Aridgerunner
Aridgerunner
Bill Bussler
Montoursville, PA, USA
Dec 23, 2014 07:31 AM
I posted this on the A side too because it's relevant to both A & B.
Just for giggles yesterday, after running the 1800 engine on the test stand we decided to do a comparison test between my brothers Snap on gauge and my Harbor freight gauge. The results were practically identical; varying maybe a pound between gauges.
And to dismiss the rumor that the Harbor Freight gauge did not have a check valve in the hose I have attached a picture of the end of the HF unit. You can clearly see the check valve. The piece on the right side of the hose is the long reach adapter which does not have a check valve and because it's only about 1 1/2" long it shouldn't need one. And we did use it for the test. So now I feel comfortable using the HF gauge in the future.
Bill
Si Vis pacem, para bellum
Bill
Tiger05 thanked Aridgerunner for this post
Dec 23, 2014 08:07 AM
Dec 23, 2014 08:32 AM
Good test
but just a start, a sample of one does not prove much.
Let's put these testers in the commercial shops for 5 years and validate after this life cycle.
I will say however it is the delta between readings not the reading so most likely any 'quality' gauge will suffice for the masses here.
Bruce
Bruce
Dec 23, 2014 08:55 AM
Joined 18 years ago
Dec 23, 2014 09:01 AM
Joined 13 years ago
In reply to # 2878918 by riley1489
Bruce
Bruce
I seriously doubt there are many here that will justify spending $200+ for a Snap-On tester and use it once or twice a year when a $30 HF will work just fine. Comparing home use to commercial shop use is idiotic.
Dec 23, 2014 09:26 AM
X2, for most of us the HF unit is fine for once or twice a year. I check mine annually during tune-up and compare to previous year readings.
I've also found the HF leakdown tester to work reasonably well, just have to be very careful when using it to follow the procedure exactly so as to avoid pegging the needle on the output gauge. Pegging the needle (easy to do) will cause the needle to be off on the reading indexes.
ohlord
Rob C
A tiny Island off the coast of Washington State, N.W., USA
1957 Land Rover Series I "OVRLND" 1971 MG MGB 1971 MG MGB "Bedouin 2" & more |
Dec 23, 2014 09:40 AM
accuracy gives a good indication of compression. Do you propose that if all the numbers read within 10% high to low and they were all reading in the 90psi range that the engine is fine because it is the delta between readings not the reading that counts ?
LNDRVR4X4.COM
Home of Project "INCARN8'
1957 Series 1 Land Rover electric VEHICLE CONVERSION
FIXITUPCHAP.COM
FIXITUPCHAP INCORPORATED
RD3 Radar/ Electronic Warfare Technician
VIETNAM 1969-1972
Good test
Bruce
Bruce
LNDRVR4X4.COM
FIXITUPCHAP.COM
VIETNAM 1969-1972
Dec 23, 2014 10:03 AM
Joined 13 years ago
Aridgerunner
Bill Bussler
Dec 23, 2014 10:20 AM
In reply to # 2878959 by ohlord
Here's my backyard understanding of this. First, please keep in mind that I was doing a comparison test between two gauges to look for differences. I wanted to make sure that my Harbor Freight gauge was giving accurate readings.
When doing a compression test of this type you are looking for two things. One, are the readings all within that 10% range? Actually, I don't even like that. 10% of 90 psi is only 9 pounds. But on a high compression engine of say 200 PSI now your looking at 20 PSI difference and that is too much for me. Two, you want to see if your readings are close to the factory specification or close to what you got when you first rebuilt your engine. Significant differences tell you there's a problem somewhere.
Bill
Dec 23, 2014 10:48 AM
In reply to # 2878979 by JWD
I was referring to your statement, not you as a person. Sorry if I offended you. That wasn't my intention. Have a Merry Christmas.
Jim,
No apology needed and no umbrage taken I was just trying to set the record straight, ( I have very thick skin
). In my post I fully agree that any low cost 'quality' tester is for most of us just fine.
Bruce
davester
Dave Diamond
Dec 23, 2014 10:58 AM
In reply to # 2878945 by ClayJ
I disagree. The HF tester is only good for testing a lawn mower because it operates at about 20 psi, not 100 psi as it should. I bought one and realized that they are designed incorrectly, with a 100 psi gauge on the compressor side and a 25 psi gauge on the engine size. I fixed mine so it works correctly by chucking the stupid "test" gauge and substituting in a 100 psi gauge. Adding to that problem, the fitting to connect to the air compressor was machined incorrectly on mine and wouldn't fit. I substituted a fitting from the hardware store. After those two mods it works like it should.
Dec 23, 2014 02:23 PM
Joined 13 years ago
Dec 23, 2014 02:38 PM
Joined 22 years ago
Compression gauges are a pretty simple device. I have one that my dad was given by a friend about 45 years ago, used. Later I bought one from Mac Tools when I was a professional mechanic. They both still work fine and read very close to each other.
"If I knew where the good songs came from, I'd go there more often."
Leonard Cohen
Leonard Cohen
Dec 23, 2014 03:50 PM
A lot of "Snap-On" tools are not even manufactured by Snap-On. Especially gauges and electrical testers, as well as many machining tools like drill bits, taps and dies, etc...
I would not guess that the compression gauge is made by Snap-On. MityVac makes a kit that looks surprisingly similar to the Snap-On. Hmm... They may also make a cheaper version for other companies.
jeff@advanceddistributors.com
