Bubble Flaring Brake line tool. Recommendations. Or Nicopp type supplier
Posted by Fieldbuilder
Fieldbuilder
Kevin Hart
Aug 4, 2018 03:04 PM
Looking to replace old brake lines with NICOPP type brake line's.
Mainly due to easy of bending.
Is there a Bubble Flaring tool that some have had success with?
I see Moss sells nickel copper lines in sets. But not individual lines.
Or, is there a supplier where I can order NICOPP type 1972 MGB
pre-made brake lines, with bubble flare ends and the threaded ends?
Aug 4, 2018 03:58 PM
Try this tool. works great:
https://www.eastwood.com/eastwood-on-car-flaring-tool-for-3-16-tubing.html
Ian Williams
Ian W
Chipping Longjourney, Toofarupnorth, UK
Aug 4, 2018 04:28 PM
Joined 10 years ago
Aug 4, 2018 05:07 PM
Joined 7 years ago
Madison Wisconsin, USA
1931 Morris Minor Saloon "Cammy OHC"
1960 Land Rover Series II 1962 MG Midget MkI 1963 Volkswagen Karmann Ghia & more |
Aug 4, 2018 05:44 PM
http://www.fedhillusa.com. Good folks to TALK to with everything you need.
Supplying New Old Stock parts for all imports. A LARGE quantity being loaded to our EBAY store stores.ebay.com/worldwideimportautoparts
Rebuilding lever shock absorbers for British cars.
(608) 223-9400 M-F 9-5 Central or parts@nosimport.com
tahoe36c
Paul Hruza
Aug 4, 2018 06:01 PM
Kevin,
I manufactured the complete brake and clutch system for my GT plumbing using annealed stainless tubing and the Eastwood flaring kit. Not cheap ($200), but superb quality. I will use it for the MGC when that time arrives, hence my investment...
Those who confuse Burro and Burrow don't know their @ss from a hole in the ground...
Aug 4, 2018 06:15 PM
Same as mine. DAMN Good tool. I have three of the other "HORSE SHOE %^&*90 " Clamp type ones.
DO NO do the HF one for sure.
Sir Henry Royce
co-founder of Rolls-Royce .
Joe Baba 2021
Sir Henry Royce
Joe Baba 2021
Aug 5, 2018 08:41 AM
I have the same one, but regret not spending another $100 for the smaller, hydraulic version that can be used on the car. Sort of a pistol grip setup, like a mini grease gun. Its not really needed on the MGB, but would work SO much better on many other projects where you need to flare one end after threading a long line front to back on bigger cars. Luckily I have a friend I can borrow one from. Perfect flares every time, if you don't forget to install the nut in the proper orientation before flaring. Oops.
jeff@advanceddistributors.com
Aug 5, 2018 10:41 AM
Joined 10 years ago
