Best engine for MG and Triumph Spitfire???
marygee1951 mary gee
worcester ma, USA   USA
Hi folks -- My guy Jim asked me to post a question -- looking for an MG -- wants to know what year was the strongest and most dependable mechanical year ??? He thinks there was an issue with the 1500???
Any input would be greatly appreciated. Thanks for your help.
Fairfield, CA, USA   USA
MG what?
Midget? 1976. 1275 engine, no smog stuff.
B...1800 engine used throughout, generally pre 68 would be a bit stronger stock.
Spitfire? the Mark IV I think used the Mark 3 1300 engine, or a Mark 3 which is a little lighter I think. the earlier cars used 1200 engine. don't recall years.
SUs, Datsun 5-speed
JoeReed Avatar
JoeReed Joe Reed
Cordova, TN, USA   USA
1978 MG MGB "Kermit"
MG Midget had the 1275 A series engine from about 1966 through 1974 (earlier models had a smaller version of the A series), with the '72 - '74 models being high on the wish list due to the round rear wheel arches. Earlier flat dash midgets (through '67, I believe), are neat too and have their own charm. 1975-1978 had the Spitfire 1500 engine. They had some engine issues (fixable) and the advantage of a synchronized 1st gear - but are generally thought of as being unattractive due to the addition of rubber bumpers that didn't flow with the body lines as well as the MGB.
MGBs always had the 1800 B series. Midgets in the same condition can generally (but not always) be had cheaper, but some parts (especially body parts) can be more expensive. Many more MGBs were built, and many more are still on the road - so that makes for a larger parts market.
OldBloke Avatar
OldBloke Jim Legg
Napa, CA, USA   USA
1970 Rover 3500
1970 Rover P6 "Napa NADA II"
1971 MG MGB GT
Being 6'1" I never fit comfortably in a spridget or a spitfire although I spent a lot of miles in friends cars. If you're gonna get in this madness you'll never go far wrong with a "B".
"Not all who wander are lost." -J.R.R. Tolkien
Jack Long Avatar
Millsboro, DE, USA   USA
1955 MG TF 1500 "Harriet"
1974 MG MGB "Lucy"
As mentioned by others, the 1500cc Triumph engine that was put into the Midget and Spitfire from 1975-on is considerd to have a weak "bottom end" (main and rod bearings and especially thrust washers) that requires frequent inspection/replacement. It does feature a fully synchronized transmission but my own experience with that transmission is that it is awfully fragile as well.
PAMidget Avatar
PAMidget Thomas Reimel
Philadelphia, USA   USA
Bit if a correction to the Spitfire info above:
The Spitfire (in American spec) was a 1500 (really 1493 IIRC) from 1973-on, not 1975-on. It's a funny thing, as even Moss, Victoria British, etc. often list '74 or even 1975 as the first "1500" year for Spits, while at the same time (correctly) listing early "1500" badges (and the like) as including the 1973 model! Part of the confusion, I think, is because the 1500 didn't become standard for all markets until 1975.
Taylors, SC, USA   USA
1961 MG MGB "LL" Lady Lynn"
Yep 76 Midget was a 1500 Triumph motor, thye are decnt motor, but if you're in the market for a Midget find a 1275 car, far better engine with more perfofmance possibilties.
MGB twin SU carb cars performa the best, they stop making them, about 75 ( correct me guys if I'm wrong) but plenty of single carb MGBs have been converted to twin carbs which make great cars as well. The later single carb MGB are not dogs by no means, it's just with the single carb and few other emission changes that made it cut the HP about 25 horses.
ggnagy Avatar
ggnagy Gregory Nagy
Harpers Ferry, WV, USA   USA
1961 MG Midget "Ace"
1961 MG Midget "27"
1962 Austin-Healey Sprite
1971 MG MGB GT "Bumble"    & more
Speedracer Wrote:
Quote: mac townsend Wrote:Quote:
MG what?
The twin SU intake manifold from the 1293 Spitfire will fit the 1500 Midget motor. The earlier manifold will probably be missing the the coolant line that runs through the manifold, but that can be plumbed around, iirc. Air flows much better when it does not need to make all those abrupt right turns. NOLA-MINI, if you are out there, have you got any pictures of the setup?
