1968 Seat Frame Left and Right
sam77 Avatar
sam77 Sam Carman
Haskell, AR, USA   USA
1968 MG MGB
I had my seat recovered on my 68 MGB over a year ago. I am ready to put them back in the car. I really cannot tell which seat is the left or right.
Can anyone help me figure out which is left and right.
Thanks Sam
chris Avatar
chris Chris Roop (RIP)
Pendleton, OR, USA   USA
I believe that the slides would have the trigger on the outside rail closest to the door. Also, the seat bottoms has one side between the top horizontal and the bottom rail wider than the other side; the wide side would be outboard, closest to the door. (My 68 just left yesterday so this is from memory).
Edited 1 time(s). Last edit at 2014-03-09 12:32 PM by chris.
TxBrit Avatar
TxBrit Rodger M
Fort Worth, TX, USA   USA
1954 MG TF "Old Sod ***Sold***"
1969 MG MGB "Old Yeller ***Sold***"
1974 Triumph TR6 "Old Blue ** SOLD**"
Ha !! Had the same problem and spent an hour struggling to fit seat on wrong side, trust me they will not go in the wrong side. Anyway, black adjuster knob goes on the outside nearest the doors, chrome adjuster on the inside next to tunnel.
sam77 Avatar
sam77 Sam Carman
1968 MG MGB
Hey Chris, thanks for responding. The seats I have are non reclining When you say the seat bottoms has one side between the top horizontal and the bottom rail wider than the other side. I am not sure that I see the differnece. Can you elabroate a little further.
Thanks Sam
sam77 Avatar
sam77 Sam Carman
1968 MG MGB
Hey Chris, my seats do not have the chrome lever on the sides of the seat. The are non-adjustable, Any other thoughts, Sam
chris Avatar
62-68 seats don't have the adjuster chrome lever or the black knob lever that flips the seat forward. I'm pretty sure the forward/back latch is on the side closest to the door.
As for the wider side of the seat bottom, put the frame on the floor, stand behind it and look at the relationship between the seat frame horizontal loop and the vertical seat rail.
sam77 Avatar
sam77 Sam Carman
1968 MG MGB
I got it figured out. The bottom seat is slightly different on the two seats. Rodger in the above post is correct. You cannot install them wrong. You just have to try to install one of them and it will not slide back and forth. You got a 50/50 chance. Of course, I installed the wrong seat. Thanks for all the help. Sam
chris Avatar
Little late for you now, but here is a thread where the differences in seats is discussed. If you look at the poorly angled pics, you might just see that the outside of the seat bottom is larger (from the runner rail to seat frame) than the inside, and that the runner latch is on the outside.
<http://www.mgexp.com/phorum/read.php?1,2007846,2008726#msg-2008726>;
bobmunch Bob M
Ontario, OR, USA   USA
Here is a photo of actual EARLY MGB seat frames (#1). They differ on the seat bottoms due to the difference in the shape of the trans tunnel in the early cars compared to the later cars with the slightly larger 4 syncro trans. From 1968 (and perhaps a little before) the seat frames became truly "handed" as the inside sides of each seat tapered to accommodate the wider tunnel (Photo #2).
Photo #3 is the late model seat frames and perhaps you can see the handed taper introduced more clearly in that photo.
Edited 1 time(s). Last edit at 2014-03-10 04:05 PM by bobmunch.
$_12.JPG    38.8 KB
1969 seat frames - Copy.jpg    24 KB
Late Seat Frames 1.jpg    36.9 KB
about 6 years and 3 months later...
agustin38 agustin e
bahia blanca, bs as, Argentina   ARG
Hello Bob & Chris, sorry to disturb you.
I have a 1967 Mk1 MGB GT but the seats are from a newer model. I guess 1969. Do you have the Mk1 dimensions for me to see if I can modify the 1969 seats to make them look as close as possible to the original ones?
Thanks and sorry to disturb you.
Agustin
Rod H. Avatar
Amity, OR, USA   USA
1964 MG MGB
1968 MG MGB GT
Welcome to the forum, Agustin.
Unfortunately, Chris passed away last year and Bob no longer participates here so is unlikely to see your post.
What I see people do to late seats to make them look like early seats is to eliminate the head rests and use leather upholstery like on early seats. Don't know of anyone changing frame dimensions, which actually aren't very much different anyway.
"If I knew where the good songs came from, I'd go there more often."
Leonard Cohen
Edited 1 time(s). Last edit at 2020-06-21 01:24 PM by Rod H..
agustin38 agustin e
Thank you very much Rod.
Sad news about Chris.
I will do so. I will remove the headrests. Fortunately the seats I have are leather ones but with a different strip configuration than the Mk1...
Tanks again Rod.
Diver648 Avatar
Tucson, AZ, USA   USA
They bolt right in. No changes to the frame necessary.
agustin38 agustin e
Thanks Diver648
1957 MG MGA 1500
