Original hose clamps
Gearhead Avatar
Gearhead Mark Ramos
Clayton, South Jersey, USA   USA
1974 MG Midget "Gearhead"
Can someone identify the correct hose clamps that should be on a 56 MG MGA 1500 I think they were double wire clamps??
ghnl Avatar
ghnl Eric Russell
Mebane, NC, USA   USA
1961 MG MGA "Calvin"
http://mgaguru.com/mgtech/care/cf116.htm
Eric Russell ~ Mebane, NC
1961 MGA #61, 1̶9̶8̶1̶ ̶A̶l̶f̶a̶ ̶R̶o̶m̶e̶o̶ ̶G̶T̶V̶6̶, 1984 Alfa Romeo Spider, 1991 Honda ST1100
Gearhead Avatar
Gearhead Mark Ramos
Whose part #’s are the hose clamps what vendor
MG Cobbler Avatar
MG Cobbler Silver Member Fred Horner
Westford, MA, USA   USA
I believe both Todd Clarke at Clarke Spares and Restorations and Cecelia Bruce at Scarborough Faire both carry the larger wire hose clamps for the radiator and water pump hoses as well as band clamps for the heater hoses.
Don MGA 1600 Avatar
Rutland, MA, USA   USA
As Fred mentioned, the radiator hose clamps were of the wire type design. The tightening screw for this style of clamp was a domed slotted head. Not the hex drive type with a slotted head as often seen on cars. The heater hoses were band clamps and not wire clamps. However, the original band clamps had an interrupted slot going about 120 degrees around the clamp. It is very rare to see an MGA with the correct heater hose clamps. The valve cover hose clamp consisted of a twisted wire clamp. Todd carries this correct clamp. I am not sure about the other vendors. It is rare to see this correct clamp on MGA's. Usually you see the standard corbin style clamp that is readily available in a hardware store. One last detail is the clamp for the 4" heater intake hose. Most often this clamp is either missing or is of the cotter pin variety that is incorrect for the MGA. The original heater hose clamp was a hex head with a slot going through it. Todd has just recently started to carry this piece to retrofit into the previously supplied clamp with the cotter pin style. Please note that I posted a few pictures of the correct clamps. Don
Look sharply after your own thoughts. They come unlooked for, like the morning dove upon your window sill, and, if you turn to your usual task, disappear; and you shall never find that perception again; never, I say-but perhaps years, ages, and I know not what events and worlds my lie between you and its return.
Ralph Waldo Emerson
Edited 1 time(s). Last edit at 2021-10-05 10:15 PM by Don MGA 1600.
Hose clamps.JPG    37.3 KB
Hose clamps-1.JPG    35 KB
Hose clamps-2.JPG    30 KB
Hose clamps-3.JPG    44.7 KB
  ghnl thanked Don MGA 1600 for this post
1959 MG MGA
