Replacing ignition module on a Rover V8 Distributor 3.9 35DLM8
Posted by cgill
Ricey30
Phil R
Jan 12, 2021 06:00 AM
Joined 8 years ago
about 1 year and 1 month later...
Mar 12, 2022 09:18 AM
Joined 17 years ago
Is there a lead that goes from the distributor to the module, I am starting from scratch with a lots of bits a friend gave me, so I am in the dark as what to connect to what ! I want to move the module on the alloy plate to somewhere cool.
allanreeling
Allan R
Mar 13, 2022 06:28 AM
Joined 7 years ago
The 35M8 or 35 DLM8 is reluctor distributor. It is not "Hall effect" but actually an AC generator. The pick up coil should have a resistance of 3.3`k ohms or there abouts, and the air gap between the point of the "star" wheel and metal centre of the coil has a tolerance of 0.8" to 0.14", measured with a non ferrous feeler gauge, (brass or plastic).
The DLM's side mounted Amplifier is heat sensitive and needs a good grounding as well as heat sink paste between it and the dissy. These dissys usually have a, largely unused, male earth spade...........use it!
The DM8 uses a remote amplifier, which is, by and large, the GM 4 pin module shown by Jim.Ideally they are connected via a sheathed cable. It needs a good heat sink, ( and paste), a cool place AND a good grounding earth.
The system works off full battery voltage and the coils are low ohm units. The original Lucas item was DLB198, which is 0.8 or 1.00 ohm. You will get little out of anything above 1.5 ohms and nothing from a normal 3 ohm.
soonerv8
Do it right, do it once!
soonerv8
Devonrod thanked allanreeling for this post
Mar 15, 2022 10:37 AM
Joined 17 years ago
In reply to # 4477844 by Devonrod
Apparently I can just make up a lead using Econoseal connectors I have been told ?
Mar 18, 2022 10:46 AM
Joined 17 years ago
I have got some screened cable and some econoseal female plugs, can any one tell me what wires go to where ? from the two pin dissy end to the three pin module end.
Mar 18, 2022 07:02 PM
Joined 6 years ago
Hi Dave
Hope these help. There are two different pages for early and late production. Z139 is the module with wires to the distributor and then to a 3 wire plug out to the coil. The RED wire goes to coil+ and the BLUE wire goes to coil-. The third wire would go to the shield
Tom
Edited 1 time(s). Last edit at 2022-03-18 07:06 PM by Linear72.
Tom
Devonrod thanked Linear72 for this post
Mar 19, 2022 06:27 AM
Joined 17 years ago
In reply to # 4480840 by Linear72
Hi Dave
Tom
Tom
Thank you Tom
TikiCricket
Auggie A
Cambridge, MD, USA
Mar 24, 2022 07:59 AM
Joined 4 years ago
Having owned 10 Range Rover Classics over the past 15 years, I have gotten pretty proficient with changing the ignition module. I always have a spare with me. 9/16ths end wrench for the diz hold down clamp nut and a small adjustable to get the screws off. Pull out the distributor to get at the module, noting the position of the rotor. zip zip, new module on, distributor back in where it was, tighten the nut, off you go.
I recommend the relocation and conversion to the GM module. Makes life easier.
about 2 months and 6 days later...
May 29, 2022 02:08 PM
Joined 17 years ago
I have done the remote mod now, for any body else see attached picture for positive / negative connections
I have the car running fine, I used a brand new Intermotor 12v coil a friend gave me, reading the very good comments from Allen R I was looking at purchasing the Lucas DLB 198 coil, the trouble is most of the "Lucas" products you buy now are just made in china, I was looking at the MSD Blaster 2 coils and wondered if those would be OK, no idea what ohms they are ?
allanreeling
Allan R
May 30, 2022 03:29 AM
Joined 7 years ago
May 30, 2022 08:31 AM
Joined 17 years ago
In reply to # 4513711 by allanreeling
Dave, ~Just check that the intermotor coil's primary resistance is no greater than 1.5ohms, less if you want better spark output. Measure from pos to neg terminals on the coil. Ignition off.
Thank you will do
waldog99
Wally Jonker
Outside of Tacoma, WA, USA
1961 Austin-Healey Sprite
1962 MG Midget MkI 1968 MG MGB GT V8 Conversion "The B" 1978 MG MGB V8 Conversion |
May 30, 2022 10:03 AM
Joined 5 years ago
Looks good! Did you end up using a heat sink for the remote module? Do you have a picture of that set up?
Wally
Wally
In reply to # 4513548 by Devonrod
May 30, 2022 01:32 PM
Joined 17 years ago
In reply to # 4513811 by waldog99
Wally
Wally
This is not on a MGB, I used the factory standard alloy mounting bracket but bent it to be in a cool area away from the rad heat extracted from the fan, any thick alloy would do to make a heat sink but you need the special grease when mounting the module
I also made a spacer you can see in the photo for the coil this also has a 13mm phenolic backing between the cylinder head where it is bolted to, I wanted to keep everything as cool as possible !
Edited 1 time(s). Last edit at 2022-05-30 01:36 PM by Devonrod.
May 30, 2022 01:41 PM
Joined 17 years ago
I am thinking of getting a MSD 82023 blaster coil this is 0.7 ohm coil, and maybe to go with it a MSD 5596 module, guess these would work together ?
https://www.summitracing.com/parts/msd-82023
https://www.summitracing.com/parts/msd-5596
Edited 1 time(s). Last edit at 2022-05-31 06:36 AM by Devonrod.
waldog99
Wally Jonker
May 30, 2022 01:53 PM
Joined 5 years ago
In reply to # 4513912 by Devonrod
Wally
Wally
Agree! I've got a RR classic suffering from a bad dizzy module right now too. I bought the RPi upgrade kit but haven't installed it yet. Not the cheapest option, but shoud yield good results!
Wally
