MGC Forum
Aluminium fuel line
Aluminium fuel line
  This topic is about my 1969 MG MGC GT
JMA Avatar
JMA John Anderson
I am aware that it needs to be routed so it doesn't rub against any hard surfaces but does anyone have first hand experience using aluminium fuel lines?
SimonOopNorth Simon H
Cheshire, Cheshire, UK   GBR
John I've never come across aluminium lines in any British / Euro car. Not to say it doesn't exist but not sure what the properties of aluminium are in this application. I've just installed kunifer fuel lines from tank to engine compartment without too much difficulty.
PETE W Sussex Peter H
Ansty, West Sussex, UK   GBR
I saw a Healey being professionally rebuilt a while ago and they were using aluminium fuel lines - I think the guy called them Hycot or something. Anyway the Goodridge fittings looked very tasty!
chormy Avatar
Norwich, Norfolk, UK   GBR
1963 MG MGB MkI "3330 PE"
1964 MG MGB MkI
1967 MG MGB GT "BABE"
1967 MG MGC    & more
John
I use internal Braided PTFE lines via JIC bulkhead fittings. Copper and aluminium both work Harden over time so they should be secured over there length and as now rubber tubing taken from the secured end. Obviously corrosion in alloy could be faster than copper or Kunifer.
MGC Racing , Alloy parts and uprated items for the C, Engine rebuilds to full race or EFI. Secondhand parts available. Facebook page "Holmes racing" www.holmesracing.co
L1040210.JPG    48.6 KB
geezer Avatar
Magee, MS, USA   USA
1967 Morris Minor 1000 Saloon (2-door) "Sold"
1974 MG MGB GT "Foghorn Leghorn"
1974 MG MGB GT
Aluminum fuel lines are common in aircraft. The problem with aluminum is our modern fuels with corn alcohol added is very corrosive to aluminum.
CAUTION!!
Life's uncertain, eat dessert first
Know the rules well so you can break them effectively. Dalai Lama
Unapologetic proponent of vented and 4 wheel disc brakes
Journal index
https://www.mgexp.com/journal/Charles-Durning.2966/toc
JMA Avatar
JMA John Anderson
We don't have many cornfields down here and although our fuel is 3rd world quality those blends that have ethanol use sugar cane and they very rarely contain more than 10% and are in the lower octane category. For a short time we had E85 but it never caught on and created all sorts of problems when the humidity hit in the warmer months in parts of the country as ethanol is hydroscopic.
What I don't know yet is when Australia is going to Euro 6 emmisions and as our current fuel blends won't accept that standard, what we get is anyones guess.
My thoughts of using aluminium is its ease of use and my current lines have too many rubber hoses through the length that I'm comfortable with especially as I'll be putting 60psi through it, also I'll be rerouting it to the back of the engine bay. When I've used the steel tube, ours has a copper lining which maybe the same as Kunifer but down here it's called bundy tube, I have wasted more than I've used.
I have looked up to try and find out what I was talking about in my earlier post - the Healey rebuild with aluminium fuel line.
It was Hycot. It turns out this is a trade name for a polyamide coated aluminium tube made by Norsk Hydro. It seems to be widely used and apparently Bentley are using it in their ‘flex fuel’ 620bhp monster that will run on E85 or petrol. Goodridge sell it with the fittings - no flaring required.
about 1 week and 1 day later...
tampaguy Avatar
tampaguy Jack Shea
Elgin, OR, USA   USA
Are you building a race car ? Why not just use what works with out the experiment
about 1 week and 6 days later...
kirks-auto Robert Kirk (RIP)
Davenport, IA, USA   USA
Clarify lines and hoses. Lines run under the car and are subject to everything the tires kick up to nick and damage them. Aluminum wouldn't be up to the task and probably is illegal in the US. Here it has always been a steel base often with lead in the alloy. Cupric nickle is the fashion in Europe and now accepted in the US. Fuel hoses are another matter.
Regards,
Robert Kirk
kirkbrit@yahoo.com
Business phone 563 323 1017
http://kirks-auto.com/
Moss distributor/UK importer
grassoc Avatar
grassoc Gary R
Mount Colah NSW Australia, NSW, Australia   AUS
1970 MG MGB
I'd make sure it has compliance in Aus. It may require stringent install methods as alum breaks/cracks quick under vibration etc.
Diesels fuel lines work around 60psi from the tank to the injector pump and they are all steel.
1979 MG MGB GT Limited Edition
