Who Has Painted a Car With a Turbine HVLP?
LittleBritishCar Avatar
LittleBritishCar Rick Anderson
Napa, California, USA   USA
1966 MG 1100 "Julia"
1975 MG MGB "Chiquita"
I am going back and forth with all of the systems available. Apollo, Fuji, and Citation all get great reviews. Although I would like the Citation 4 stage with an AccuSpray Series 10 gravity feed gun, I am probably only using it one time so I am leaning toward the TP system. It is nearly half the cost and the reviews are pretty good. Anybody have experience using any of these systems?
MG David David Witham
Warwick, UK   GBR
I once used an Apollo one of my friends owns. It did a good job. However, the level of my skill is such that I always end up with areas that need a little bit more paint often due to sand through or not putting enough on. The Apollo is poor and handling small amounts of paint because it has a large underslung paint container. If you can get a gravity fed model that would solve the problem.
72bwhite Avatar
72bwhite Larry McKinney
Thousand Oaks, USA   USA
I use an older AccuSpray spray a very even fan and much less over spray then some of the pressure systems. Painted the MG with it and now doing the 51 chevy pickup with it, wish I had the gravity feed instead of the pot style but that was what we used back when I bought it.
Down side is you have to mail order spare parts
Up side is it's a very easy gun to paint with.
Mine is their complete system turbine and gun came as a set.
stuart sinclair Avatar
honiton, UK   GBR
1951 MG TD "Mixed Breed"
1979 MG MGB GT
I managed some years ago to get brush on auto paint in Torquay, I got away without putting primer on just brushed it onto a GPO yellow H A vauxhall van i sold it soon after,
Zymurgy Avatar
Zymurgy Mike Madden
London, OH, USA   USA
1966 Chrysler 300 "Goldie"
1973 MG MGB "Melvin"
Here is my 2 cents worth. I have had 3 HVLP sprayers over the years. My favorite is my last a Titan Capspray 125. Instead of the continuous running turbines, it has a compressor with twin tanks. The main problem I had with the turbine HVLPs is how hot the air became in a relatively short amount of time. If I was researching for a new HVLP I would check out how hot the air became with the different HVLPs.
The air would get so hot that it would dry the clear coat before it hit the car. I never seemed to have problems with the paint but had issues with the clear. These were pretty early generation HVLPs so maybe they have resolved this problem but I would definitely check it out. My Titan 125 air is always cool but you can empty the small tanks, but if you have a larger compressor tank it's not an issue.
Oxide Avatar
Oxide Del Rawlins (Disabled)
1959 MG MGA
We hada similar problem with the hot air with our Accuspray turbine. I'm told that a longer hose helps a lot, and gives the air a chance to cool a little before it reaches the paint gun.
cstrong45 Avatar
cstrong45 Charles Strong
Bainbridge Island, WA, USA   USA
I have a buddy in CT that swears by the turbine.
1976 MG MGB
