Which wiper blade is better: Trico or Bosch?
Posted by 78mgb
Nov 20, 2010 09:17 PM
I am looking at replacing my windshield wiper blades. I have found two different brands being advertised: Trico and Bosch. Which is the better brand? So far I have read a couple reviews and they said the Bosch was good. Has anyone used a Trico?
Thanks
Thanks
Nov 21, 2010 12:12 AM
Joined 17 years ago
Nov 21, 2010 02:07 AM
Let's see, each is made of rubber . . . Can there be a significant difference between wiper blades? I mean, after all, if one doesn't work so well, you throw it out and use the other. They're pretty cheap. Maybe a web site like the oil filter test site? Wiper blades ranked in order of quality? Well, okay then, I'd at least look at it, I suppose.
ejh27051946
egbert hascher
Nov 21, 2010 04:45 AM
Nov 21, 2010 05:19 AM
In reply to a post by DrewM
I need three of them and it will cost over $26.00 for them. I am interested in finding ones that are easy to install and do a good job.
Nov 21, 2010 07:22 AM
In reply to a post by 78mgb
My local Advance Autoparts has 10" blades with the correct fitting on the shelf, they are used for a few rear wipers on some smaller minivans.
Nulla tenaci invia est via
1971 MGBGT, overdrive, Limey relay and fuse kits, Rick Ingram struts all round, Jeff Schlemmer points distributor, mgccars.com alternator, Basil Adams camshaft and side cover, Eurospec tail lights, 1976 dashboard and console, 1999 Chevy cavalier seats, GM heater motor and fan with Ford 3 speed controller, Ford Merkur/Sierra parcel shelf, cruise control.
1979 B, Olds 215 engine with 1996 Land Rover heads, Carter AFB, Camaro T5 gearbox, Limey relay kit, Rick Ingram struts all round, mgccars alternator, Jeff Schlemmer distributor with Petronix, Eurospec tail lights, cruise control, 99 Pontiac Sunfire seats.
1969 MGBGT, Miata seats, late centre console, apart from that it's stock!
Nov 21, 2010 11:25 AM
Bosch and Trico both suck. They're really not much better than the ones Moss sells, which IMO are the worst of the lot.
Mike's right about getting the smaller blades at Advance Auto (AutoZone, too). I'm using 11" blades right now, trimmed 1/2" at each end, because they were out of 10" blades at the time, but they are available.
A great man is hard on himself. A weak man is hard on others.
“When someone shows you who they are, believe them the first time.” ~Maya Angelou
Nov 21, 2010 11:44 AM
Nov 21, 2010 11:59 AM
Joined 26 years ago
Uh, there is another consideration, and that is that each maker has varying product lines. Some in each are better than others. Some are simply a redux of the original designs for OE replacement. Others can progress from "advanced" to relatively "exotic" (at least, if you believe their advertising).
If you look at the full spectrum of what is out there, it is pretty easy to see that the designs can vary significantly, some better in some applications than others. Some have blade support that is minimal and may not apply pressure where it is needed at the extremes of the wiping action on a given windshield, others have systems of almost continuous support, and others still have changed little since the 1930s.
I ran with genuine Tex blades for years, because they were OE and seemed to work well. Then I started to experiment on my GT. In a two wiper set up, I liked the Bosch fairly well, and now find that the Rain-X do as good or better. But in between each of those there have been many experiments that didn't work out - for my car and the piece of glass in the windshield. I found it interesting that even a difference in make of glass could make a difference, but it seems to. What worked well on Safelite windshields, didn't work out as well on a Triplex. And what worked well on either of those were just ok on the korean glass in my wife's Sonata. I would think that they would not be a significant factor, but the empirical reality is that they were.
Selecting a good wiper has been for me, as much luck in getting a good match up of rubber and glass as it has been the design of any given maker's blades. FWIW.
Nov 21, 2010 07:22 PM
I have the original blades (the rubber part has be replaced) and the original windshield. I have been using Rainx on it and it seems to help the blades move over the windshield. I was hoping that getting new blades would make them work better. I put new blades on my other car and it improved how they worked. Probably removing the wiper motor and cleaning it out would help a lot but that would mean that my car would not be available for driving. I am trying to limit the down time and get some improvement on the wipers. For years, my car never went out in the rain because I did not have a top. Now that I have a top, I hope to use it more. I am kind of leaning to the Bosch blades. The prices that I see for new blades run from $6.95 Bosch to $20.30 Anco per blade. I am trying to determine if getting the most expensive blade is worth the extra money.
If anyone has used the Anco blades, can you tell me they perform.
Thanks.
Thanks.
Nov 21, 2010 08:12 PM
http://www.amazon.com/Anco-31-3110-Wiper-Blade/dp/B0009IK5SK/ref=wl_it_dp_o?ie=UTF8&coliid=I13HRIOIGK84RZ&colid=1DZBZ4HTAG54P
http://www.amazon.com/Trico-Products-Exact-Wiper-Blade/dp/B000CRKOHK/ref=wl_it_dp_o?ie=UTF8&coliid=I1ZBSM4M3WXGG&colid=1DZBZ4HTAG54P
Nov 21, 2010 10:08 PM
Joined 22 years ago
Just a word in defence of Moss - I've have a set of their blades on the car for about 3 years - they've been fine.
Terry Ingoldsby
terry.ingoldsby@DCExperts.com
Terry Ingoldsby
Nov 22, 2010 11:23 PM
In reply to a post by ingoldsb
I tried to find wiper blades on Moss and could not find any. I used the Moss search and it did not show any wiper blade. Please provide a link and I will consider them.
Thanks.
Nov 23, 2010 12:31 AM
Joined 16 years ago
bosch 9" blades were my anser to your prob.
Michael J. Caputo
'79, '77, '76, '74.5 (rubber dual SU), and '73 owner. 12v Audio System design. Vendor of Regalia and Promotional Products since 1993. Supplier of Accessories to MOSS. Forum Member since 2009. Warped sense of humor since birth.
Publisher of the annual MGB & GT Calendar, mailed worldwide. Buy one!
Michael J. Caputo
Send photos for the next calendar to photos27@mgbcalendar.com. If you need help with your Weber downdraft carburetor, feel free to call me at 978-249-5760, USA, Central Time! http://www.MGBcalendar.com
tomgrigsby
Tom Grigsby
Nov 23, 2010 08:12 AM
Joined 16 years ago
I tried to get blades from advance this weekend but the arm clips were too narrow to hold the blade - do these come with an adapter for the thin arms on my 71?
