Weber DGV swap 180 deg.
Posted by brcree
Sep 7, 2013 06:38 PM
Just swapped my Weber Carb around and thought I would share my efforts. The return spring set up is temporary. Will use shorter springs when I get some.
save another one.......
Sep 7, 2013 06:47 PM
Joined 26 years ago
Desert dog
Don M
Sep 7, 2013 06:50 PM
Joined 13 years ago
I was going to do the same thing but I noticed the manifold opening width was tapered to accept the carb. As the secondary is bigger than the primary. With the carb rotated there was some interference between the secondary butterfly and the narrow side of the intake.
Desert dog
Don M
Sep 7, 2013 06:52 PM
Joined 13 years ago
Sep 7, 2013 06:55 PM
Desert dog
Don M
Sep 7, 2013 06:59 PM
Joined 13 years ago
Sep 7, 2013 07:46 PM
Gotta say I have never had to adjust my Weber in the two + years I have had it. Just not an issue for me. Car starts (without choke), runs great with no hesitation, and the secondaries open with no lag at all. Don't understand what the fuss is about.
Sep 7, 2013 07:50 PM
Jay.....my "B" wasn't running as well as I wanted it to when I got it...have been tweaking on it. Bad manifold gasket, missing gasket between air filter plate and carb body....on and on....still fool-en with the jets too.
Edited 1 time(s). Last edit at 2013-09-07 07:51 PM by brcree.
Sep 7, 2013 10:55 PM
Joined 16 years ago
@brcree
nice.
clean.
concerned about your throttle cable at the firewall though it looks like you are rubbing the cable against the flange.
If you need help...
let me know.
Michael J. Caputo
'79, '77, '76, '74.5 (rubber dual SU), and '73 owner. 12v Audio System design. Vendor of Regalia and Promotional Products since 1993. Supplier of Accessories to MOSS. Forum Member since 2009. Warped sense of humor since birth.
Publisher of the annual MGB & GT Calendar, mailed worldwide. Buy one!
nice.
clean.
If you need help...
let me know.
Michael J. Caputo
Send photos for the next calendar to photos27@mgbcalendar.com. If you need help with your Weber downdraft carburetor, feel free to call me at 978-249-5760, USA, Central Time! http://www.MGBcalendar.com
Sep 7, 2013 10:58 PM
Joined 18 years ago
Sep 7, 2013 11:26 PM
Joined 18 years ago
I changed mine around a few years ago were I could get to the mix. screw easer. I open up the intake OR I should say I matched the intake, carb, gaskets, heat sheild & nylon block. I found them not the same size & was going to restrict the air flow to the engine, by a fair bit. I added a alu. plate to help slow up the heat from the exhaust manifold getting to the carb & boiling the gas in the float bowl when I stop after the motor is up to running temp. I also lower the float in the carb. were there is not as much gas to boil. I do not have the problem of restarting a hot engine after a 5 to 10 min. sit. I run the elect. choke were I do not have to mess with the man. choke (getting lazy) In July 07 I ran from De. to Wi & a week later back to De. & the temp. was 98 to 102 on the way there & back. I keep a very good log on my MPG & I did 31 mpg with 87 oct. gas with the A/C on the round trip & I was running anywere from the speed limit to 80 mph, on the average I run 7-8 mph over.
