Repairing Lucas 9H Windtone Horn
RuhRoRaggy Avatar
RuhRoRaggy Jack Hinds
Guelph, ON, Canada   CAN
1976 MG MGB MkIII "Scoob"
Hello all!
In all the older vehicles I've ever owned, I've always tried to get the stock horns working. A deep, throaty exhaust note is wonderful, but there's something so conversational and cheerful about a horn. They add so much character, to a breed of car already overflowing with it.
Now imagine my disappointment when the Windtone horns on my 1976 MGB were not working when we first purchased the car. There's some funny stuff going on with the horn wiring in the car, so I thought I'd take them out and try them on the bench first.
When I connected them directly to the battery, the high tone would not sound. Hitting it with a hammer and playing with the adjustment screws would not bring it back to life, so I set about taking it apart.
In brief, I used a Dremel with a zipdisk to cut the rivets off the body, then punched them through and out. I was then able to separate the horn into it's three main components; the upper portion with the winding, the diaphragm, and the bottom with the resonance chamber.
There was pretty good resistance through the coil, but no resistance across the contacts or the contact breaker. The culprit turned out to be the contact breaker itself. I was able to separate the breaker with my thumb, and removed some built up carbon with sand paper and brake cleaner. 30 minutes and I was suddenly getting something close to factory spec through it again! I finished the work, cleaned the surfaces with a wire wheel, cut new paper gaskets, and bolted it back up.
Success! A nice, loud tone. I'm going to do the same with the working low tone horn, then repaint them both.
Any thoughts on paint colour? The factory colour was black, but I'm tempted to do it in something close to the MG Maroon.
Would a more in-depth write up be worthy of the tech library? It's not complicated, but there's not much literature on it.
Thanks!
Jack
Remember; I'm pulling for ya. We're all in this together.
1976 MGB "Scoob" - Our summer touring machine
CameraZOOM-20180408153540600.jpg    47.7 KB
CameraZOOM-20180408155335536.jpg    51.4 KB
CameraZOOM-20180408155359753.jpg    42.3 KB
CameraZOOM-20180408200330279.jpg    58.3 KB
CameraZOOM-20180408203014957.jpg    44.4 KB
  Ahmed thanked RuhRoRaggy for this post
lewk Avatar
Cambridge, ON, Canada   CAN
Hey Jack, nice work. I'd be tempted to put it in the tech library as is. BTW, if you go to the British Car Swap Meet tomorrow (Apr, 22) at the Ancaster Fair Grounds, you'll probably find an intact working pair.
Paint them black.
Edited 1 time(s). Last edit at 2018-04-21 09:02 AM by lewk.
astbury Avatar
astbury Gold Member Mark Astbury
Rye, NY, USA   USA
1966 MG MGB "Megan B"
Hi Jack - your post brought back fond memories! My horn adventure here:
https://www.mgexp.com/phorum/read.php?1,2266227
course2kid Jeffrey Johnson
1979 MG MGB "Lucy (Lucifer)"
Below, are a couple videos on different MGB horns. The later model year MGBs have a different horn made by MIXO. Their operation is similar to the Lucas horns, but, they are a bit more fiddly to adjust. I wish I'd taken pictures or a video when I rebuilt mine last year, but, hindsight is always 20/20!
riley1489 Bruce H
Good one Jack. smileys with beer
Mark and Anthony H helped me through my horn 'correction' as well. Not so daunting once you get in there. smiling smiley
On one of my horns I needed to replace a Lucar tang . I used a bolt rather than the brass rivet which broke at removal.
I chose to drill the rivets at the perimeter out then drill & tap the holes for re assembly. No nuts to loosen and looks kinda 'tough'. winking smiley
These duo tone horn is part of the MGB character.
Edited 1 time(s). Last edit at 2018-04-21 03:26 PM by riley1489.
BH_lucas9H rep.jpg    23.4 KB
  Ahmed thanked riley1489 for this post
RuhRoRaggy Avatar
This is why I love this site; you're never the first person to struggle with something. Glad there's people around that think it's worthwhile trying to take care of these little horns!
Jack
RuhRoRaggy Avatar
In reply to # 3721241 by astbury Hi Jack - your post brought back fond memories! My horn adventure here:
Awesome, thanks! Someone made a good point in there about adjusting the tone off the car. Probably a good idea. Time to wake the neighbours...
Jack
little G Avatar
little G Charlie T
2024 MG MGB "Little G"
I threw one of mine in the bin when I first got the car !...wish I hadn't now ...though it was a lot more rusted and corroded inside than that ...so still run with the one horn lololol
1975 MG Midget
