Relay question what is terminal 87A
Dinghyboy Avatar
Dinghyboy Gavin Dickie
Henrico, VA, USA   USA
I have a Bosch relay, that has never been used but is not in the the original packaging. It has an 87 and an 87A terminal. Is the 87A terminal the same as *& or is it for a different purpose.
Thanks
Gavin
70 MGB-GT (driver)
76 MGB roadster (in progress)
DB Wood Avatar
DB Wood Gold Member Daniel Wood
Bend, OR, USA   USA
1967 MG MGB GT
1968 MG MGB
1970 MG MGB GT
Terminal 87a which is the center terminal completes the circuit with terminal 30 when the relay is not energized, and breaks continuity when the relay is energized by putting 12v through 85 and 86 to ground, in which case the 87 through 30 circuit is completed. This allows you to do some interesting things with these relays.
Dan Wood
70BGT driver, OD, , HS4's, Peco, .060 over, Elgin cam, Superlite wheels, poly bushings, panhard rod, rear tube shocks, 1" lowered front end, HD shock valves, etc, etc.
68 MGB rebuilt engine D9 cam balanced, much more.
1967 MGB-GT project
2006 Saab 9-3 2.0T
2004 Dodge Ram 6sp with HO Cummins diesel
Lucas= Loose Unsoldered connections and splices
78mgbfan Pat Harrison
Memphis, TN, USA   USA
1978 MG MGB
What Dan said !!!
Here is a link to additional info on relays and some of their uses:
http://www.the12volt.com/relays/relays.asp
Pat
78 MGB
Weber DGEV 32/36
Lucas 25D Schlemmerrized dizzy w/Pertronix
Desmogged
