Paddy hopkirk pedal
jon.wright.lbc Avatar
jon.wright.lbc jonathan wright
Tehachapi, CA, USA   USA
I saw some where that the paddy hopkirk accelerator pedal cover fits the early 62-67 accelerator pedal, will it fit a 74 cb accelerator pedal too?
mgbbrown Avatar
mgbbrown Tony and Sharon Ann Brown
Siler City, NC, USA   USA
Jon; I cannot speak for the 1974 design-my guess is with modification of the original factory pedal it will work-it may require reshaping the factory pedal face. It does work on an MKII. Because it is a bit wider, heel and toe is improved for aggressive driving. I would perhaps do a cardboard or thin metal sheet mock-up to examine how it may fit. I do not have mine here so I cannot take the Paddy Hopkirk pedal face measurements for you. I do caution you in that the new face is very close to the carpet as it is quite a bit wider. Amco did make a scuff plate for the transmission tunnel to help avoid extra carpet wear. These were polished stainless and would be a simple projet to replicate. The photo is of an original-the reproduction one of both the Speedwell version and the Paddy Hopkirk version is good. God Bless! Tony Brown RN mgbbrown
Always drink upstream from the herd. Will Rogers
MGB Paddy Hopkirk Throttle Pedal NOS.JPG    44.4 KB
I have an extra 67 pedal, are they interchangeable? Would I be able to swap it over?
mgbbrown Avatar
Jon, I have never tried it. Check the upper portion of the pedal pivot and if they are the same you should be in business. It may also require a throttle cable change. Here is a photo of one early type of Speedwell pedal. God Bless! Tony Brown RN mgbbrown
Speedwell Accelerator Pedal.jpg    18.5 KB
joaniebo Bob Olach
Crystal Lake, IL, USA   USA
1968 MG MGB "Myrtle"
Like one of these?
Paddy Hopkirk Pedal.JPG    41.9 KB
mgbbrown Avatar
Nice Bob! Mine came in a hideous green and black blister pack with a picture of Paddy on the cardboard front- it was my first period accessory and I unfortunately did not take a photo of it. Speedwell also offered their version in aluminum alloy and a hard composite material, and there were several smaller runs by various suppliers of Mini Cooper specific accessories too. God Bless! Tony Brown RN mgbbrown
Speedwell Throttle Pedal Alloy.jpg    43.4 KB
Speedwell Plastic Throttle Pedal NOS.jpg    24 KB
Throttle Pedal Extension Unknown Maker.jpg    9.8 KB
MGB 1976 Avatar
MGB 1976 Silver Member Mark Turechek
North of Boston, MA, USA   USA
1976 MG MGB "The Never Ending Project"
You could swap out your 1974 accelerator pedal with a later model pedal -
MGBAccPdl7780.jpg    9.3 KB
I would prefer to get the actual hopkirk pedal ill see if I can swap the earlier pedal over and that would solve my problem
