Original Factory Primer?
ClayJ Avatar
Mt. Olive, MS, USA   USA
Folks,
My 72 Harvest Gold MGB is in the paint & body shop for rehab. My bodyman sanding the car swears there is no primer under the paint unless its the same color as the topcoat. I was by his shop Monday and I inspected several areas around the car where he had sanded and there is no color change from the original paint down to the shiney metal. I am 99.99 percent positive this car had never been repainted except for the left rear quarter panel that had old damage repairs.
Is it possible the factory tinted the primer/sealer coats?
Edited 2 time(s). Last edit at 2007-12-26 10:19 PM by ClayJ.
72mgb4me Avatar
72mgb4me Shawn Escue
Roanoke, VA, USA   USA
1972 MG MGB "Money Pit"
1974 MG MGB GT "Street Car"
Unless I'm mistaken, the factory primer is a tan color that could easily be mistaken for Harvest Gold. I seriously doubt it left the factory with no primer.
Shawn
rficalora Avatar
rficalora Gold Member ROB FICALORA
Willis, TX, USA   USA
my car was harvest gold. you have to look close to see the difference between the paint & the primer but there was definitely primer on mine.
Custom Sill Plates for classic British cars Heater valve kits (that don't leak) for MGB'S and MGA'S
olparatrooper Avatar
olparatrooper Dennis Davis
NW Iowa, USA   USA
My '70 and '72 both had light tan primer...I don't beleive it was e'coated..it came off too easily.
B-racer Avatar
B-racer Jeff Schlemmer
Shakopee, MN, USA   USA
I used a heat gun to strip a lot of the paint from the body panels of my car, and yes the primer is a light tan/gold color. Funny thing is that it wasn't touched by the heat gun, while all the other paint lifted easily. It was good stuff!
jeff@advanceddistributors.com
sunny124ny Avatar
sunny124ny Sunny Sunny Sonnenrein
Riegelsville, PA, USA   USA
1963 MG MGB "Monty"
I am chemically stripping my 63 right now, and among the 6 coats on the car, the last (light tan) primer coat is the hardest to strip off, while the original paint coat comes off pretty nicely. Of course it was easier to see the difference with Old English White than with Harvest Gold, I'm sure....
Sunny
Jamie B Gold Member James Bourland
St George, VA, USA   USA
1968 MG MGB
1968 MG MGB GT
'68BGT. Primer coat was tan. Hard as rock. Lead based? Surely the car was dipped in it. Tempted to leave it on but since I had the whole car up on the rotator device..... Stuff was nearly impervious to wire wheels and such. Expensive strippers beat it.
Jamie B.
ClayJ Avatar
Thanks to all of you for your reply, I was almost positive that was the answer.
daddog Todd Porter
Paris, Arkansas, USA   USA
I am stripping my '63 also, and the primer color is red. It is a little brighter than most red oxide color primers I have seen.
sunny124ny Avatar
1963 MG MGB "Monty"
Geez, I wonder if they used whatever color their supplier happened to deliver at the time. I know for a fact that this happened with Mopars a lot - run out of one thing, use another....
daddog Wrote:
Quote: I am stripping my '63 also, and the primer color is red. It is a little brighter than most red oxide color primers I have seen.
Benny Avatar
Benny Ben E
San Diego, CA, USA   USA
My '65, '67, and '68 all had red primer. My '70 had the beige stuff others have mentioned, I think it was just something they switched as the years went by.
Ryan Reis Avatar
Beatrice, NE, USA   USA
1968 MG MGB
Yep, red on my '68. As others have said, very tough stuff! One thing I noticed that speaks in favor of stripping to bare metal, is that in many places where the paint had chipped down to metal, there were "fingers" of surface rust spreading under the primer. I wouldn't want that under my shiny new paint job.
Ryan
Bill Taylor Avatar
Seattle, WA, USA   USA
1964 MG MGB
Red on GHN3L/26098
brian70mgb Avatar
brian70mgb Brian Pratt
hunyington, WV, USA   USA
yea i have chemical stipped my B before and i can attest that the factory primer is a pain to come off and mine had a reddish tint to it
Jack Long Avatar
Millsboro, DE, USA   USA
1955 MG TF 1500 "Harriet"
1974 MG MGB "Lucy"
The MGB was one of the first cars to be dipped into an electrostatic primer bath. Note the plugs in the bottom of the trunk floor, put there to let primer drain out after dipping.
Body manufacture and painting was transferred from Swyndon (near Coventry) to Cowley (just outside of Oxford) sometime in the late 60's which may account for the difefrence in primer color between early and later cars.
1947 MG TC
