[Solved] new Smiths voltmeter wiring in positive ground car
FulfordMan Avatar
FulfordMan Tobin Peever
Saltspring Island, BC, Canada   CAN
Solved
Removed an ammeter and the associated wiring that was in my car when I bought it and wanted to fill the hole in the dash with a voltmeter. Bought a new Smiths voltmeter from Holden Classics in UK. There was nothing on their website about not being able to fit the gauge in a positive ground vehicle so assumed it would work in my car. Gauge is made by an outfit called "Caerbont" and is very nice quality (see attached).
Got a question about fitting this gauge to my '66 GT that is positive ground. When I opened up the package the instructions state "gauge to be fitted to negative earth vehicles only" (see attached). I examined the gauge and both terminals are isolated from the case (see attached). When I tested on the bench with a battery I could get no continuity through the case or through the mounting studs in either direction. So it is unclear to me why this gauge cannot be mounted in a positive ground vehicle and the warning in the instructions a bit of a mystery to me. Plan was to feed the negative terminal of gauge from the ignition switch and put a low amperage fuse (2 amps) in that line. Positive terminal on gauge from ground. Any reason why this shouldn't work?
IMG_3406.jpeg    32.2 KB
IMG_3407.jpeg    30 KB
IMG_3408.jpeg    39.7 KB
Fresno, CA, USA   USA
TOBIN: YES, very ODD. I would have thought that a 'VOLTMETER" was of the D'Arsonval, permanent magnet type. and would normally work for either polarity. Possibly, it das an internal, steering diode, or surge protection. Give them a call, that would be the proper route to take. Good Luck.
In reply to # 4695607 by FulfordMan Removed an ammeter and the associated wiring that was in my car when I bought it and wanted to fill the hole in the dash with a voltmeter. Bought a new Smiths voltmeter from Holden Classics in UK. There was nothing on their website about not being able to fit the gauge in a positive ground vehicle so assumed it would work in my car. Gauge is made by an outfit called "Caerbont" and is very nice quality (see attached).
Sir Henry Royce
co-founder of Rolls-Royce .
Joe Baba 2021
FulfordMan Avatar
In reply to # 4695625 by oleanderjoe TOBIN: YES, very ODD. I would have thought that a 'VOLTMETER" was of the D'Arsonval, permanent magnet type. and would normally work for either polarity. Possibly, it das an internal, steering diode, or surge protection. Give them a call, that would be the proper route to take. Good Luck.
Thanks Joseph. Have done just that. Hopefully Caerbont's techline can clear it up for me.
Fresno, CA, USA   USA
Kind of curious, since I have a tuneup (Homemade) box, That has both a Tachmometer and a volt meter, on it, and I can use it on + or - ground cars.
In reply to # 4695652 by FulfordMan
Sir Henry Royce
Joe Baba 2021
ME SHOP TOOLS 005.jpg    45.6 KB
FulfordMan Avatar
Interesting. I have had no problem using a modern strobe light with tachometer and dwell meter on my car but I always use an external 12V power supply rather than the car's battery. Dwell clip goes to points side of coil (positive on my car) and it gives me inverse dwell readings. So I get readings of say 30 which I can convert to actual dwell readings by subtracting the number on my dwell meter from 90. So 90-30= 60 degrees of dwell.
Tar Trekka Avatar
Tar Trekka Ross H
Sydney, NSW, Australia   AUS
1968 MG MGB MkII "Miss B"
Hi there,
I Think that you will find it's OK to connect the "Volt Meter Only".
BUT DO NOT CONNECT THE LIGHT.
The "Polarity On The Light Is NEGATIVE EARTH".
I had a "Similar Issue With A Tacho", when young & "Inexperienced".
All was fine, until I "CONNECTED THE LIGHT".
Ross H.
PS. Are you mounting it to "Metal Of The Body, or Plastic Etc"?
Any day above the ground is a great day, especially "Driving Miss B".
Edited 1 time(s). Last edit at 2023-08-27 02:16 AM by Tar Trekka.
FulfordMan Avatar
In reply to # 4695765 by Tar Trekka Hi there,
Ross H.
Body of my gauge is metal but some of them are plastic. As I said above, I could detect no electrical continuity between case or mounting studs and 2 input terminals. So as long as both input terminals remain electrically isolated from the case and mounting studs, I should be OK to mount in steel dashboard. Hopefully the inline fuse will ensure that if the case becomes conductive because of an internal short, the wiring will be protected.
Response from Caerbont:
As long as you have a volt meter with 2 terminals then connect the gauge connection 2 to battery positive and the other to battery negative it will work OK.
Later versions with a 6 way plug or negative earth only.
Regards
Peter Wilkinson
Software Engineer
Direct Phone +44 (0)1639 732243
Caerbont Automotive Instruments Ltd
Fresno, CA, USA   USA
His gauge does not have an internal light. It is a push-in type from the harness. According to the picture. smileys with beer
Ross H.
Sir Henry Royce
Joe Baba 2021
FulfordMan Avatar
Correct! No internal light. Light supplied with new gauge has a plastic base, two leads, and a conventional bulb and slides into a brass tube attached to case. Since case is electrically isolated from terminals, I should be able to reuse the light that was in my ammeter. That one has a single lead and relies on grounding through the gauge case.
Edited 1 time(s). Last edit at 2023-08-27 10:10 AM by FulfordMan.
Fresno, CA, USA   USA
I HAVE TO ASK" Did you test the polarity with a 'FLASHLIGHT Battery? AAA< AA< C or D are all 1.5 Volts DC, They will deflect the needle, and tell you if the polarity is correct, but NOT enoygh amperage to dame it if NOT. I have a bench poweer supply tha is variable, from about 1 VOLT to 24 Volts, for testing electrical components. (Home made, and is about 30+ years old)., Cheers.
In reply to # 4695884 by FulfordMan
Ross H.
Regards
Peter Wilkinson
Software Engineer
Sir Henry Royce
Joe Baba 2021
FulfordMan Avatar
In reply to # 4695904 by oleanderjoe I HAVE TO ASK" Did you test the polarity with a 'FLASHLIGHT Battery? AAA< AA< C or D are all 1.5 Volts DC, They will deflect the needle, and tell you if the polarity is correct, but NOT enoygh amperage to dame it if NOT. I have a bench poweer supply tha is variable, from about 1 VOLT to 24 Volts, for testing electrical components. (Home made, and is about 30+ years old)., Cheers.
Tested with a 12V motorcycle battery. Also confirmed that gauge is quite accurate with a multimeter
Fresno, CA, USA   USA
Just for fun. DID you try a flashlight battery, to see the results ??? For other people to see. I also use a AA Battery to test car stereo speakers, Putting the speakers leads across a AA or any 1.5V battery, produces a '"Scratchng Sound"", = GOOD Speaker. smileys with beer
In reply to # 4695897 by FulfordMan Correct! No internal light. Light supplied with new gauge has a plastic base, two leads, and a conventional bulb and slides into a brass tube attached to case. Since case is electrically isolated from terminals, I should be able to reuse the light that was in my ammeter. That one has a single lead and relies on grounding through the gauge case.
Sir Henry Royce
Joe Baba 2021
rrikola Avatar
rrikola Platinum Member Robert Ikola
Santa Maria, CA, USA   USA
1966 MG MGB
I'm not sure how this fits into your problem but it might. I have a positive ground car as well. When adding an accessory gauge off any kind you need to check the light. Most gauges like MGs have a bulb and a socket that plugs into the back of the gauge. Usually it has one wire in the center. The light socket is metal and grounds to the case of the gauge that is then grounded to the car body. So even if you isolate the body of the gauge from the body you still have the problem with the light shorting. Speedway motors and others have gauge lights that are plastic and have two leads that do no ground to the case that will fix this problem. You just plug them is as normal and wire both leads as needed. So I assume your gauge has a light plumed into the back. If it has one wire and the socket is metal then it is part of the electrical chain and the case is grounded. My only hopefully helpful tip is be careful that the gauge light polarity doesn't contradict the gauge polarity. Good luck.
FulfordMan Avatar
Thanks for the tip. I have determined that the input terminals and internal mechanism of the gauge are electrically isolated from the case and studs. So no need to isolate the gauge case from the dashboard, it already is. So it should be no problem to reuse the original light bulb I had for the ammeter in the same hole in the dash. In this situation the light would rely on a ground through the case. So the light will be grounded through the case but the gauge will not. Does this make sense? A bulb with plastic base and two leads as you describe was included with the gauge so I could go that route as well if necessary.
In reply to # 4696069 by rrikola I'm not sure how this fits into your problem but it might. I have a positive ground car as well. When adding an accessory gauge off any kind you need to check the light. Most gauges like MGs have a bulb and a socket that plugs into the back of the gauge. Usually it has one wire in the center. The light socket is metal and grounds to the case of the gauge that is then grounded to the car body. So even if you isolate the body of the gauge from the body you still have the problem with the light shorting. Speedway motors and others have gauge lights that are plastic and have two leads that do no ground to the case that will fix this problem. You just plug them is as normal and wire both leads as needed. So I assume your gauge has a light plumed into the back. If it has one wire and the socket is metal then it is part of the electrical chain and the case is grounded. My only hopefully helpful tip is be careful that the gauge light polarity doesn't contradict the gauge polarity. Good luck.
Fresno, CA, USA   USA
A single-wire light bulb as found in the MGB. "Dash Lights" RED w/Wte stripe, work for either Positive or Negative ground They GROUND at the gauge body. (Whether that is + or - Voltage there.) They are NOT polarity conscious Any after-market gauge you buy, is going to have a PLASTIC, TWO wire holder, NOT because of polarity, but because of convenience, NOT sure of HOW a light bolb socket is going to short out on the gauge body, POS or NEG. Mybe I am misunderstanding your post. smileys with beer.
HERE. Very simplified drawing but it shows the relationship between the lightbulb in the electrical circuit. Battery voltage switch from negative to positive has no effect on the operation of the lightbulb. The gauge itself of course is polarity conscious and must follow the positive negative inputs.
Sir Henry Royce
Joe Baba 2021
Edited 2 time(s). Last edit at 2023-08-27 07:23 PM by oleanderjoe.
09A7BCE4-00EE-4083-B80F-FF73C7DDE526.jpeg    32.1 KB
1974 MG MGB MkIII
