LPS 3 rust proof wax
MudSnow Avatar
MudSnow Nathan ~
OR, USA   USA
Is anybody using LPS 3 on their cars? I know a guy who uses it on his reel mowers and it makes a pretty tough waxy film.
http://www.lpslabs.com/product_pg/corrosion_pg/LPS3.html
Edited 1 time(s). Last edit at 2010-10-18 02:11 PM by MudSnow.
leapfrog Avatar
leapfrog Mark Smith
Santee, CA, USA   USA
1974 MG MGB GT "RUSTY"
2005 Mini Cooper S Coupe "Leapfrog"
The company I work for uses it for outdoor use on chains and sprockets. It takes a few months before the rain washes it off, especially in Hawaii. We also use it on machined parts that go in our Warehouse for long term storage. I guess you have some parts you are putting on the shelf for now?
MudSnow Avatar
MudSnow Nathan ~
OR, USA   USA
I think I am going to spray it liberally under and inside my cars.
It penetrates pretty well.
MudSnow Avatar
MudSnow Nathan ~
OR, USA   USA
I just found this performance test on it.
http://www.wetdogcharters.com/MAIN%20PAGES/FAQ.htm
ABSTRACT
How to prevent rust on boats has been one of the sailor’s most enduring challenges. For this test of anti-corrosion sprays and coatings, anything that had “rust” and any reference to “marine” or “boats” or “salt spray” was fair game. Paint was out. Our saltwater test, which involved full immersion of mild steel coupons, was admittedly harsh, and quickly produced results. After three days, most of the steel coupons were significantly rusty. Only three saltwater test panels showed no corrosion—those coated with CorrosionPro Lube, CRC Heavy Duty, and LPS 3.
Wouldn’t it be nice if you could have a rustproof boat? In search of our ideal anti-corrosion coating, we chose the products based largely on their advertised claims and also on how easy they were to find. Among the products we tested for corrosion prevention: West Marine CorrosionPro Lube, CRC Heavy Duty Corrosion Inhibitor, Corrosion Block, Boeshield T-9, WD-40, CorrosionX, Corrosion X HD, Shark Hide, LPS 1, LPS 2, LPS 3, and TC-11 all popped up during Internet searches. We left out products that made no specific claims for use in the marine environment.
THE TEST
Each of the test products was applied to two mild steel strips—one to be suspended in salt water and the other to be sprayed with fresh water. One of mankind’s greatest early achievements was the extraction of pure metal from rock. The process takes ingenuity and consumes vast amounts of energy. So it is with considerable frustration that we watch nature so easily reclaim what we have wrought at such cost. Few are more familiar with corrosion than mariners, who fight a constant battle against it in the salty interface between sea and sky.
A visit to the hardware store or a search on the Internet reveals no shortage of products to address, and even redress, corrosion—most are touted as being able to penetrate ("frees rusted parts"winking smiley, lubricate, or protect electrical components. Here we examine the corrosion-inhibiting properties.
What We Tested
We chose the products based largely on their advertised claims and also on how easy they were to find. Several are available in hardware stores. West Marine carries its private-label product, CorrosionPro Lube, as well as CRC Heavy Duty Corrosion Inhibitor, Corrosion Block, Boeshield T-9, and WD-40. CorrosionX, Shark Hide, the LPS products, and TC-11 all popped up during Internet searches. We left out products that made no specific claims for use in the marine environment. Anything that had "rust" and any reference to "marine" or "boats" or "salt spray" was fair game.
Twelve made the roster: PMS Products’ Boeshield T-9; LPS Laboratories’ LPS 1, LPS 2, and LPS 3; Corrosion Technologies Corp.’s CorrosionX and CorrosionX HD; ICC Industries’ TC-11; Lear Chemical Research Corp.’s Corrosion Block; West Marine’s CorrosionPro Lube; CRC Heavy Duty; Shark Hide; and WD-40, because it was already in the workshop.
Each showed different degrees of viscosity, all went on wet, and most stayed wet, or at least tacky. Those that left a waxy coating, performed the best in the saltwater test.
None is pleasant to use and all of their containers carry stern warnings about flammability, use in poorly ventilated areas, and against inhaling them. Most use heavier-than-air butane, pentane, or heptane, or a mixture thereof, as propellants, which means there’s a risk of an explosive mixture accumulating in confined spaces, such as bilge compartments. Ventilate these areas thoroughly before operating anything that might create a spark.
The LPS products use carbon dioxide as propellant, and Corrosion Block nitrogen, but the solvents are still flammable.
Boeshield T-9
According to its maker, Boeshield T-9 spray is for penetration, moisture displacement, lubrication, and rust and corrosion protection. It’s relatively heavy and dries slightly tacky. The T-9-coated strip sprayed with fresh water was rust-free after a week. The one submerged in salt water had rust around the screw and at the top after three days. The trend continued through eight days, with more corrosion on the cured side (see sidebar above) than on the uncured side.
Bottom Line: In terms of what our test covered, T-9 works as advertised, even in salt water. Slightly more corrosion at the screw and price edged it out of the top three.
Corrosion Block
Advertised as a corrosion preventer and inhibitor, Corrosion Block is a heavy, blue spray that dries thin, clear, and slightly tacky. After seven days of freshwater dousing, the Corrosion Block coated strip showed some rust spots at the top, where we’d expected a thicker coating. The saltwater strip, however, was very rusty after three days except for an area toward the top. After eight days, it had rust all over it.
Bottom Line: Corrosion Block is OK for freshwater purposes, but not salt water. To be fair, the manufacturer makes no claim regarding rust.
CorrosionPro Lube -West Marine
West Marine claims its product offers "...excellent water resistance and superior rust and corrosive preventative characteristics." And it does. This fine spray leaves a visible, amber-colored, waxy coating. The coating remained intact through a week of freshwater dousing, and the metal strip showed no signs of rust. The saltwater strip saw similar success: The coating remained after three days, and there were no signs of rust. It was only after eight days of saltwater abuse that some rust appeared along the "uncured" edge.
Bottom Line: This product does what it claims. The waxy film isn’t pleasant to the touch, but for hard-to-reach parts, it’s on the money.
CorrosionX
This aerosol, which maker’s claim provides protection against rust and corrosion, initially forms a foamy, blue-green film. The bubbles eventually disappear. CorrosionX’s freshwater performance was excellent: After seven days, there was no rust and the film was still tacky. (So sticky, in fact, that a few small flies met their end on the metal strip.) Unfortunately, its saltwater efficacy rated at the other end of the spectrum. After eight days, except for a band at the top, the metal strip was very rusty, and particularly corroded around screw.
Bottom Line: CorrosionX works fine in a freshwater environment, but it’s not ready for brine time, especially in a mixed-metal situation.
CorrosionX HD
Think of this as CorrosionX’s big brother: A "high-performance, thick film version of CorrosionX," according to Corrosion Technologies Corp. It comes out as a fine spray with some bubbles and a thick, amber color.
The CorrosionX HD saltwater panel (right), like several other test panels, had more rust on its bottom half than its top half, and oddly, it had less rust on its “uncured” side. Like its sibling, we rated it Excellent in the freshwater test, but wasn’t up to the challenge of salt water. The strip in saltwater had a rusty bottom half and a less-rusty top half, almost in proportion to the thickness of its coating. A clear halo appeared where the product accumulated around the nut, and curiously, less corrosion formed on the "uncured" side.
Bottom Line: The sticky film does resist freshwater penetration, but it isn’t immune to salt water, especially for the long term.
CRC HD Corrosion Inhibitor
CRC Heavy-Duty Corrosion Inhibitor, which is seemingly identical in appearance and performance to CorrosionPro Lube, is made for saltwater use. It claims to protect and preserve metal surfaces subject to salt spray and high humidity. It comes out as a fine spray with a thick coating. The freshwater test strip still had a sufficient coating and no rust after seven days. It was equally impressive in the saltwater test: coating intact and no rust after eight days.
Bottom Line: Excellent performance. It lives up to its claims. (Bass Pro, Ace Hardware, Boaters World, West Marine...)
LPS 1
LPS Labs offers three products with three levels of rust protection. LPS 1 is marketed as a greaseless lubricant that displaces moisture. Colorless, it has a broad spray range. In the freshwater test, the LPS 1 panel only had some rust on the uncured side after a week. After three days in salt water, the strip was very rusty, except at the top, and by Day 8, it had rusted all over. The brass screw also showed signs of rust, as though iron were being transported to its surface by galvanic action, there to repeat its demise (just a guess).
Bottom Line: LPS literature says the product displaces moisture on electronic components and that its light, greaseless film inhibits corrosion. It doesn’t claim to prevent rust, but it works for fresh water, if given time to cure. The broad spray pattern made it difficult to concentrate the product where it was wanted.
LPS 2
LPS 2 is touted as a multi-purpose lubricant and penetrant with added corrosion protection. It’s a colorless, fine spray with a strong almond odor and broad spray pattern. The freshwater LPS 2 panel had no rust after three days, but some after seven days; more on the "uncured" side. After three days, the saltwater test strip exhibited extensive rusting, and after eight days, it was completely corroded.
Bottom Line: LPS 2 claims to provide protection indoors for a year, and its performance indicates that as its limit. Not useful in salt water.
LPS 3
The strongest of the LPS series, LPS 3 claims to be a long-term, heavy-duty rust inhibitor, even in the harshest environment. Its bubbly, thick spray forms a waxy, pale brown coating. After a week of freshwater exposure, there was no sign of rust and the coating was still tacky. And even after eight days of saltwater torture, the LPS 3 panel showed no sign of rust and it was still very sticky.
Bottom Line: We tested it under "harsh conditions," and it does what it claims—but it’s not pretty.
Shark Hide
Shark Hide claims to be a protective coating against weathering and salt spray. Marketed mainly to owners of aluminum pontoon boats and similar craft, it lists steel among the surfaces it can be used on. Unlike the other test products, Shark Hide is a thin, colorless liquid—not an aerosol—that wipes on with soft cloth. It’s a thin liquid, and has really nasty solvents (toluene and xylene)—so be sure to apply it in the open air and wear gloves. The freshwater test strip showed rust spots on the "uncured" side after three days. But there was no rust on the cured side, even after a week. The saltwater panel’s uncured side was rather rusty after three days, but the other side had only mottled rust. Even after eight days, the coupon wasn’t completely rusted.
Bottom Line: Shark’s Hide works well in fresh water when allowed to cure. And it performed better than expected (Fair) in salt water for having such an invisible coating. It’s easy to apply to large, smooth surfaces, less so to small parts like nuts and bolts.
TC-11
TC-11 is the "complete answer for rust control," according to its maker. The bubbly, blue-green spray forms a thick coating that was still sticky after a week of freshwater exposure. It kept the freshwater panel rust-free after seven days. The saltwater panel did not fare as well: After three days, it had extensive rusting, and after eight days, only the very top was rust-free.
Bottom Line: This product isn’t the silver bullet—but it works in fresh water.
WD-40
Nearly as ubiquitous as duct tape, WD-40 claims to protect against rust and corrosion. Although the fine, colorless spray’s coating was dry after a week of freshwater sprays, the panel had no rust. However, after three days in salt water, the metal strip was completely rusted, except the top. After eight days, only the very top was showing resistance.
Bottom Line: Works well in fresh water—and makes no greater claims.
CONCLUSIONS
Our saltwater test is admittedly harsh, and quickly produced results. After three days, most of the steel coupons were significantly rusty. Only three saltwater test panels showed no corrosion—those coated with CorrosionPro Lube, CRC Heavy Duty, and LPS-3. Of the remainder, the Boeshield T-9 panel showed the least corrosion, followed by the cured Shark Hide. (The cured vs. non-cured results support the notion that it pays to follow instructions. Most non-cured sides mimicked the control panel.) In the freshwater test, the Shark Hide remained rust free. It might be the answer for stainless steel rigging, stern rails, etc., because it leaves no sticky residue—however, it’s an expensive solution. At 63¢ per ounce, CRC gets the Budget Buy nod. For day-to-day use, loosening sticky mechanical parts, or softening greasy deposits, WD-40 works and is inexpensive.
Edited 1 time(s). Last edit at 2010-10-18 03:03 PM by MudSnow.
FTD in an MGB Avatar
FTD in an MGB Ed Sweeney
Reading, PA, USA   USA
Great stuff, and quite a bit easier to use than Waxoyl.
Proper Noise Limited
www.propernoise.com
mgv8glen Avatar
mgv8glen Glenn Towery
Dover, DE, USA   USA
1974 MG MGB GT "Pumpkin"
I have USED the LPS for 30 years! Now THE REST OF STORY!!!!!!!!!!!!!!! In 82 I got my 75.5 GT & the first thing I did was rustproof my M.G. AFTER a paint job. Next was the Rover V-8 & it went in at 103,000 miles, around 200.k I pulled her apart & were I spryed the inside & bottom of the doors the LPS came off like sheat of wax paper. I have used waxoil & it comes off if you scratch it with your finger nail & you get waxoil! My G.T. sits outside & is driven every day & now has 531,891 on her today! For a 36 year old she has a GREAT BODY!!!!!!!!!!!!!!!!!
rocannon Avatar
rocannon Gold Member rocannon L
Mansfield, TX, USA   USA
1967 MG MGB GT "GT From Hell"
glenn,
not quite sure i get it... you like LPS3 or Waxoyl? winking smiley
frank
Rich in Vancouver Avatar
Rich in Vancouver Rich McKie
White Rock, BC, Canada   CAN
2002 MG ZT "Andy (Capp)"
2003 MG ZT "Gromit"
Back in the 80's we used LPS3 on MG's with good results. I have also used Boeshield for aircraft applications and sometimes on cars, also with good results. Both are similar to Waxoyl but I am not sure how they compare.
Modern MGs aren't just Transportation, They're a Hobby!
jharden73 Avatar
jharden73 John Harden
Frankenmuth, MI, USA   USA
1973 MG MGB MkIII "The Grain Hawnet"
1973 MG MGB MkIII "The Grain Hawnet Pic 2"
I have used the LPS products in the aviation industry for thirteen years. Meets many aircraft manufacturers MIL spec.
The LPS 1 is like WD-40 only better. Same viscosity. Water displacing. Common lubricant.
LPS 2 has more viscosity. Aircraft control surface hinges. High altitude performance, low temp, higher adhesion. Better water displacement.
LPS 3 is even thicker. A basic metal protector. Washes off. A lower viscosity material than Procyon.
LPS Procyon in a quart (not spray can). The closest thing to Waxoyl that I have experienced. Poors exactly like room temperature maple syrup.
Drys with a light brown waxy semi-hard coating. Doesn't wash off like LPS 3. Coated the inside of my bumpers and over-riders with it. Perfect for inside of the sils, doors, fenders, etc.
2.5L of Waxoyl from Moss $109.00 + ship.
1 Gal. of Procyon is $110.00 + ship. http://www.rshughes.com/products
mgv8glen Avatar
Dover, DE, USA   USA
Frank, the LPS#3 PEALS off, after 3 years like a sheat of wax paper. There was not much bonding to the part it was sprayed on. Wax oil is there for a real long time & I respray my MGs every year or 2.
1965 MG Midget MkII
