Idle up solenoid on Air Conditioned cars GT's
Posted by mgainaussie
mgainaussie
Gary Lock
Gold Coast, Australia
Apr 20, 2018 10:05 PM
Joined 16 years ago
Just throwing this out there (from the MGA Forum). Has anyone successfully installed an idle up arrangement on their air conditioning installation? To keep normal idling revs at around 750rpm, the carby adjustment needs to be around 1200rpm when you switch the a/c on. Anything less than that can create stalling unless the foot on the pedal keeps the revs up.
I done quite a bit of research on early British cars with twin carbs that had A/C installed from new, but most (like the Rover SD1) had large torque engines, and the changes in revs were not very noticeable.
Cars with single carbs (Webers) are no problem, with a range of solenoids available (Edlebrock etc.)
Any suggestions?
Any suggestions?
modern gentleman
NEIL MILLS
Apr 21, 2018 05:07 AM
Joined 13 years ago
Hi Gary,
Bruce Ibbotson has an idle up solenoid on his MGC airconditioning installation.
When the compressor is turned on a solenoid provides vacuum to a vacuum actuator to rotate the front SU throttle shaft.
The vacuum actuator is connected to the throttle shaft via an Su choke lever.
Heres a link to a thread re Bruce's A/C installation. One of the photos shows a top view of the vacuum actuator mounted on the carb heat shield. There are photos elsewhere on the www showing a front view of the Actuator with the SU choke lever attached to the throttle shaft.
https://www.mgexp.com/phorum/read.php?48,2099389
Safety fast
Safety fast
Apr 21, 2018 11:04 AM
RAY 67 TOURER
Ray Marloff
Apr 21, 2018 01:58 PM
Joined 16 years ago
tvrgeek
Scott S
Apr 21, 2018 03:28 PM
Joined 10 years ago
about 1 month and 32 minutes later...
May 21, 2018 04:01 PM
Joined 22 years ago
Rebumping this topic in hopes someone will provide a good solution for an MGB.. out of the parts bin idle solenoids are not cheap from a parts store...
David Terhune
My Blog http://mymgcars.blogspot.com/
1970 MGB-GT, 1974 MGB and 1957 MGA Coupe
David Terhune
tvrgeek
Scott S
May 21, 2018 04:07 PM
Joined 10 years ago
May 21, 2018 04:26 PM
Joined 13 years ago
In reply to # 3721141 by GlennMGB
I just raise the idle a bit using the choke control. I have the choke set up to raise the idle before enriching the mixture.
For HS4’s, this works perfectly.
1973 MGB: Blow through supercharged, intercooled, 10psi boost. VP12 cam, aluminum flywheel, 8.9:1 compression. Black label OD, Saab 15” minilites. Goes a lot better than it looks.
May 21, 2018 05:42 PM
Joined 22 years ago
Using the choke is interesting.. I have HS4s... but what is meant by "I have the choke set up to raise the idle before enriching the mixture." How is this done.. maybe would be more meaningful looking at the carbs and linkage....
David Terhune
David Terhune
May 22, 2018 09:59 AM
Assuming you have HS4 carburetors (HIFs may be similar), the choke control performs two functions. It raises the idle speed and it enriches the fuel-air mixture. To raise the idle speed, the choke control opens the throttles on both carburetors. To enrich the mixture, it pulls the jets downward from the carburetor bodies. Usually it increases the idle speed before changing the mixture, but it should be easy to verify this. Turn off the engine and remove the air cleaners. Reattach the choke cable bracket to the forward carburetor with a couple of short bolts. Have someone sit in the driver's seat and pull the choke control while you observe. You should see the throttle linkage move before the jets move. Ask your assistant to lock the choke control at the point just before the jets begin to move. Measure the distance from the choke knob to the dashboard with your finger, and that's how far you can pull the choke out to compensate for a/c compressor drag. If you need more idle speed, you can back off the choke adjusting screws to allow more speed before the jets are pulled down. Study the linkage for a while and you'll see what I mean. You don't want to enrich the mixture at all while the engine is hot, because that will stall it.
I like my GT to idle at about 1150 rpm normally. A lower idle seems too rough. When the a/c is on, I bring the idle to about 1800. When the compressor comes on, it brings it down to 1300 or so.
