How important for cylinder heads to be tightened?
Fresno, CA, USA   USA
10-4 cause that's all that really MATTERS. You done got "Don, Hap and Ben, on their soapboxes, and I don't have time to read all that stuff this week. Cheers.
In reply to # 4783146 by ingoldsb
Quote: I want to know where "Dianna Princes" underwear goes when she spins around and turns into Wonderwoman.Now, that is puzzling. confused smiley
I'm glad that you take time to reflect and ponder the mysteries of life! smiling smiley
Sir Henry Royce
co-founder of Rolls-Royce .
Joe Baba 2021
Taylors, SC, USA   USA
1961 MG MGB "LL" Lady Lynn"
In reply to # 4783280 by oleanderjoe 10-4 cause that's all that really MATTERS. You done got "Don, Hap and Ben, on their soapboxes, and I don't have time to read all that stuff this week. Cheers.
I don't even own a soapbox, LOL, I am here to help, I leave the peeing battle to the others in fact I ignore most of the comments, I've heard it all before, and already know it, or know better devil smiley
ingoldsb Avatar
Calgary, AB, Canada   CAN
Nobody's mentioned Angstroms yet. Wouldn't it be cool to set the toe-in of the front wheels using a specification in Angstroms? We could also specify it as a certain (large!) multiple of a given emission line of Krypton. smiling smiley
Terry Ingoldsby
terry.ingoldsby@DCExperts.com
scudrunner Avatar
scudrunner Jay Nichols
La Marque, TX, USA   USA
1967 MG MGB "Let Go For MGTD In 1974"
1973 MG MGB "A Work In Progress"
1974 MG MGB "Jay's 74 MGB"
After all the Fig Newtons, Pascals, Charles Avoirdupois, we can't measure speed with a ruler as in the speed of light (although no one mentioned Ole Roemer),kilograms, pounds, weight vs mass, cats and dogs living together........
I'm just going to go ahead with my plan and torque the head to 50 ft/lb and then retorque later to 55 ft/lb. But my torque wrench is also marked in newton meters, so I may use that instead.
Jay in La Marque, Galveston Texas.
In God we Trust. All others bring data.
Trust, but Verify
Fresno, CA, USA   USA
EASY tp do in Angstroms. with a couple of 2x4's and a wooden spoon, just like some people do using inches. smileys with beer
In reply to # 4783312 by ingoldsb Nobody's mentioned Angstroms yet. Wouldn't it be cool to set the toe-in of the front wheels using a specification in Angstroms? We could also specify it as a certain (large!) multiple of a given emission line of Krypton. smiling smiley
Sir Henry Royce
Joe Baba 2021
Rick Fawthrop Avatar
Langley, WA, USA   USA
I don’t know about the rest of you but I am a retired mechanic.
After I install the head after a heat cycle I put my Snap On 3/8 torque wrench on it and set it to 55 lbs and give the bolts of click.
I usually don’t have other peoples cars long enough for three heat cycles.
As far as the metric imperial debate I can go either way.
For close tolerance work my brain defaults to decimal.
ingoldsb Avatar
Quote: I usually don’t have other peoples cars long enough for three heat cycles
And neither did the factory! How did all those MGBs ever survive without having their heads retorqued. Did the dealer do that? Was it done at the factory? Was it never done?
Terry Ingoldsby
Donthuis Avatar
Donthuis Don van Riet
Terry, my MG mech did this for me at the time a first Gold Seal engine was replacing my OEM 1972 block and the B had passed 1000kms/600 miles. If not followed he just could not assure the guarantee, given by the same organisation nowadays called Ivor Searl. By his own mistake after a severe HGF on this block by having the head overskimmed without adding a spacer or grinding the combustion chambers out I even needed a 2nd Gold Seal block in later years. And this block once more required a 1000km /600miles running in procedure and his retorque afterwards. Quite a nuisance! sad smiley
This was only needed for blocks with the traditional head gaskets, this changed to the "torque once only" procedure for the Payen. It is also the reason my I.S. block came with the explicit guideline NOT to retorque the headnuts, since the block with its Payen had undergone the single heatcycle at their plant. A Payen lookalike headgasket BTW, since it carried the AK660 number debated elsewhere as belonging to a Lucas branded production line confused smiley
(The 200+ post thread of my own Payen gasket renewal after a stuck valve repair describes the SINGLE retorque done by myself explicitly)
PS In one of many tries to reduce the high oil usage and apparent coolant leakage on my 2nd Gold Seal unit I retorqued the headnuts mainly around cyl # 3 & 4 and put a three step coolant additive from Toralin in the block, which indeed stopped the coolant leakage. The other additive from Toralin I used called "compression repair" (nowadays renamed to "max compression"winking smiley equalized compression levels across all cylinders, but did not stop oil usage
PS2 In line with the above this Toralin company on which some of its products I myself and my tire shop mechanic have positive opinions about offered me a product kickback on any sale over a link made via my social media activities if I desire to exploit my "influencer" activities this way. I must say I am quite hesistant on such implicit responsibilities. Rest assured to MGE members I never coupled my advice on this forum to any financial gain.
For reference to any debate on additives I use with positive results either experienced or expected I list them hereby free or charge smileys with beer :
1) TSL in the engine oil for proven reduced internal friction and against cold start wear in the starting phase when oil pressure is still low
2) an expensive 3 step copper based coolant anti-leakage Toralin product, now also offered in 2 step variants for closing up smaller gaps
3) a Toralin compression repair/max compression oil additive to equalize compression levels across cylinders after higher mileages (50k miles)
4) a protecting gasoline Toralin E10 additive that claims also to protect against other nefastious side effects of newer gasmixtures in E5 shape
5) a Spanish Toralin coolant additive for protecting against rust developments and greasing the waterpump was fine, but removed from their offer
6) many years ago I used Bar leaks on a dubious radiator, which indeed closed up pinhole leakages. But when I had to remove the radiator once, leaks started all over, so I hereby advise anyone having an older radiator in situ just to have it re-cored or move to a new unit instead of using Bar Leaks.
I still have a tin of the Bar Leaks cleaning agent lying around which I will never use: once tried it destroyed my starter motor upon emptying the system
So a bit OT maybe, but as least linked to cylinder head (re)torqueing practices and related to potential oil and coolant leakages cool smiley
In reply to # 4783360 by ingoldsb
Donthuis Avatar
Mercedes and BMW (and some very rare cartypes sold at exorbant price levels) once gambled on full metrically defined tires taken over the market. But in the end this never materialized and tires remained in their strange mixed Imperial/Metric numbering scheme you described so correctly below.
Those old- and youngtimer owners that posses such vehicles have to spend a lot of money every 7-8 years or so on "metric" tires or change their wheel to the familiar mixture in numbering design. Often buying and mounting newer wheels is cheaper than buying these ever more expensive tires. Still for those fanatics on originality this is not an option, since more expensive cars often also carry specially designed alloy wheels in certain productyears!
PS On the matter of parameter definitions I do not have much more to add I'm afraid. About 70 years ago I had to master any calculation between the 4 main systems I mentioned in my earlier posts on my secondary school, including conversions between Calories, Joules and Watts. Later in my UNI years somebody (I no longer remember who) explained to me why so many conversions inbetween had a 4 pi factor inside. Forgot this intel by now..
And temperatures in a Fahrenheit scale were last used by my grandparents and never covered in any of my educational schemes (let alone Réamur)
In reply to # 4783277 by ingoldsb The hilarious part of this is that, after converting tire sizes to metric, we're now left with a combination on almost all tires. I.e., the width is in mm but the inner diameter (where the wheel goes) is in inches.
Quote: elbow to hand was once called an "el" for measuring cloth
In English, I believe that is the cubit! Weren't the measurements for Noah's ark given in cubits?
Quote: PS2 I find Australia interesting, since over there they redefined their Imperial heritage from Britain in Metric units that are close enough in size
The inch stays what it was for them, but is less and less used because of this redefinition of sizes in practical day to day mechanical activities
That is generally what happened. In the U.S. (and I presume Canada), the inch is defined as 2.54 cm. Other measurements are defined in a like way. I was once told that this led to a discrepancy between the original British inch and the newly defined inch, but the error was in the hundreds of thousandths column so almost no one noticed the change. I guess we got lucky that a two decimal value was such a close match! Wouldn't you hate it if you had to remember some weird number like 2.539162 ? smiling smiley
Would that all mechanics and machinists were as conversant and bi-metric as Hap!
One thing the metric system did for us was to cause definitions to be stated in terms of reproducible physical phenomena. Previously there were standard bars (for length) and standard weights and so forth. These would be reproduced as accurately as possible - but just copying the original held the possibility of altering it. I.e., if you measure the bar's length with calipers you might distort it. Now, anyone with the proper equipment can determine what a unit is without looking at any other example.
sweep Avatar
sweep Gold Member Chris W
Gosford, NSW, Australia   AUS
1966 MG MGB "Basil"
2013 Volkswagen Tiguan
2015 Audi A3
You know, the OP of this thread was Gary’s last post on this site anywhere.
Hmm…..
• The secret to creativity is knowing how to hide your sources.
• To the intelligent person, life appears infinitely mysterious, but the stupid have an answer for everything.
First rule of forum debate:
• My opinion becomes truth if I can find one other person, on the Internet with the same opinion. It is 'chiselled in stone" if I find two!
• War is God's way of teaching Americans geography.
lewk Avatar
Cambridge, ON, Canada   CAN
So this six page diatribe on the merits or non-merits of the metric system had value after all.
In reply to # 4783605 by sweep You know, the OP of this thread was Gary’s last post on this site anywhere.
Hmm…..
That was all done in the engine test bed, in a different plant, not on the assembly line. "the factory" did not build the engines, Morris did. They don't call them assembly plants for nothing, they don't build car parts, they assemble finish parts to assemble a car.
Edited 2 time(s). Last edit at 2024-04-11 10:28 AM by Speedracer.
twentyover Avatar
twentyover Greg Fast
Lives in SoCal, Moving back to ancestral homeland, the Pacific NW, USA   USA
Not exactly true, there is a foundation for the length of a meter, rather than just because I said so-
The meter was supposed to be 1/10,000,000 the distance from the equator to the north pole. Y'know, back when the earth was foolishly believed to be round, rather than the pear shape it actually is.
In reply to # 4783034 by Arizona Shorty Neither an inch nor a millimeter has any validity or reference that man did not give it. Neither measurement system has intrinsic value or validity. They are merely standards by convention. So, since a millimeter has no value other than by convention, suggesting an inch is now defined metrically is nuts. An inch may equal 25.4 millimeters by observation, but one does not define the other.
GMc
ingoldsb Avatar
Quote: Calories
Don - you forgot to mention Calories is different than calories (note the capital C). IIRC "Calories" is actually kilocalories - the webs we weave. smiling smiley
Hap - thanks for that bit of info. So, Morris built the engines, presumably ran them up to temperature, then re-torqued the head bolts.
P.S. We're happy to go on with or without Gary! smiling smiley
This was all in fun!
Terry Ingoldsby
1975 MG Midget 1500
