High horn contact wear
KenAdkison Avatar
KenAdkison Gold Member Ken Adkison
Shelton, WA, USA   USA
1975 MG MGB
My '75 MGB horn contact refuses to slide easily on the steering wheel ring. It leaves film powered bronze (or whatever yellow metal it is) all over the inside of the plastic covers.
Previously, it would squeal when turning. It is like the metals have too much friction.
I have had this car apart so regularly, that I have had a chance to readjust the contact spring pressure and its angle to try to solve the problems to avail. I am on my second contact with no real improvement.
What do you all think about dielectric grease here? Maybe I should scrub the ring with a graphite pencil?
Any better ideas.
1975 MGB restored in 2009 to near stock with 9.8:1 compression and mild cam.
Bespoke closed loop, sequential, port fuel injection system with crank triggered ignition.
Hand made intake, wiring and other parts.
https://www.youtube.com/channel/UCcdmkAGSliRgRzpdyuSaMrA
Edited 1 time(s). Last edit at 2024-04-09 10:39 PM by KenAdkison.
Not-Anumber Silver Member Chris S
Southend, South east UK, UK   GBR
Is it switching the horn directly or have you added a horn relay to reduce the amount of sparking and arcing the horn switch contacts are exposed to ?
Edited 1 time(s). Last edit at 2024-04-10 07:05 AM by Not-Anumber.
  Mudlark thanked Not-Anumber for this post
smokey w Avatar
smokey w Juri P
Toronto, ON, Canada   CAN
In my experience, the squeal comes from a worn brass button on the contact spring. I did a termporary fix by building up the button with solder, and have a new contact ready to install when I next remove the steering column plastic cowling. The pics show how it works on my '71 NA. Moss sells the contact : PN 141-804.
Turn signal switch bracket.jpg    43.6 KB
IMG_0391.JPG    40.9 KB
KenAdkison Avatar
1975 MG MGB
I have a horn relay. I was thinking about taking the idea Smokey has a bit further and making a new contact out of A better/different material. IT is like the replacement contact and the ring are of too similar metals and one won't slide well on the other. My thought was a carbon brush from an electric motor would work better.
I should not be the only one with this trouble. It may be time to pull the covers and measure the contact pressure and photograph the alignment.
BH Davis Avatar
Grosvenordale, CT &, Warren, VT, USA   USA
1968 MG MGB GT "Primrose"
Just use dielectric grease as you suggested.
BH
GlennMGB Avatar
GlennMGB Silver Member Glenn G
Fort Worth, TX, USA   USA
1965 Triumph TR4A
1967 MG MGB GT "Rose"
I use a dab of conductive grease here. Kopr-Shield seems very expensive these days, so maybe try MG Chemicals 846 or 8463A.
smokey w Avatar
smokey w Juri P
I first tried the grease, and it worked for a while, but the squeal came back. The squeal is caused by the hard spring-type brush making direct contact with the ring, leading to a resonance. The solder blob has worked for a couple of years, but will obviously wear out, so I have a new brush ready to go when I'm in there again to replace the turn signal and wiper switches.
BH Davis Avatar
Might as well put a new brass ring in as well for the spring loaded stub to rub against.
BH
smokey w Avatar
smokey w Juri P
Thanks, didn't realize it was available. I'll order one and put it on the shelf.
In reply to # 4784451 by BH Davis Might as well put a new brass ring in as well for the spring loaded stub to rub against.
BH
1972 MG MGB GT
