Front Crank Seal Leak Repair
Posted by bfried
May 23, 2009 03:28 PM
Joined 17 years ago
A mechanic recently told me that the cause of the oil leak in my '65 renovated MGB was a front crank seal that needed replacement. The leak diameter of oil on the ground an hour after driving is about two inches. Any ideas on how much this should cost t repair? How essential is repairing it if I monitor the oil level frequently?
scottydawg
Scott B
May 23, 2009 03:33 PM
That should be pretty easy to fix, Brandon. Things you have to remove: Fan, Crank Pulley, oil slinger, timing chain cover. Hammer the old seal out, and the new one in. You may (may) have to loosen the motor mounts and jack up the engine a little to get to the bottom bolts on the timing cover...
For a good mechanic, this is a 1 or 2 hour repair, max. Costs are minimal, I think the seal is less than ten bucks. I might have an extra timing cover gasket laying around too.
"Since the creation of the Internet, the Earth's rotation has been fueled, primarily, by the collective spinning of English teachers in their graves."
"Keep in mind that free advice can frequently be worth less than you pay for it."
May 23, 2009 04:27 PM
Replacing the seal may only be a temporary fix. Have a look at the pulley surface where the seal rides and if there is any trace of a grove, the new seal is not going to last long.
Speedy sleeve the pulley, OR machine the surface, OR buy new pulley. OR ignore it aadn hope it last long enough!
For a brittish car, the oil loss you describe is almost expected; when it stops, we add oil!
Pete
Pete
May 23, 2009 04:40 PM
Joined 18 years ago
ZOMBIEWOOF
CHIP GRIFFIN
LAWRENCEVILLE,GA., USA
May 23, 2009 11:16 PM
Joined 17 years ago
May 24, 2009 12:52 AM
Joined 18 years ago
May 24, 2009 06:50 AM
Joined 18 years ago
May 24, 2009 07:01 AM
May 24, 2009 07:09 AM
wdp Wrote:
http://www.vsm.skf.com/en-US/HeavyDuty/KitsAndTools/~/media/Files/enUS/HeavyDuty/2007_027_FULL_BOOK_for_Web_secure.ashx
Pick a size. Any size.
Someone will chip in with a diameter on the crankshaft front.
On earlier threads to do with the rear main seal and the shaft diameter, there was a fair bit of variance on measured shaft sizes. You'd probably do best to take three or four readings on your own shaft, then use the average as the speedi sleeve size. The catalog allows you to come up with a part number.
Many machine shops and supply houses stock the sleeves
1971 MGB GHN5UB237226
Edited 1 time(s). Last edit at 2009-05-24 10:55 AM by RonnieMac.
Quote:
I have the same problem, leaky front seal. Anyone have a part number for the correct speedy sleeve?
