Distributor lubrication question
Posted by BH Davis
Apr 17, 2026 11:32 AM
Is there, or is there not supposed to be a felt insert in the center of the distributor shaft below the rotor button (removed for photo). If so then what is the 2 or 3 drops of oil you would put on it intended to lubricate?
I put a dab of grease on the outside of the shaft for the points block to ride upon so that is lubricated.
Thanks,
BH
Thanks,
BH
Crownvicjohn thanked BH Davis for this post
Apr 17, 2026 12:18 PM
Joined 2 years ago
The felt is something that came on certain brands of points. Haven't seen any new points like that in a while...
Here's the dreaded "AI Overview":
"The felt wick on a distributor breaker points assembly is designed to lubricate the cam lobe, preventing the points' rubbing block from wearing down prematurely. It should be lightly oiled with a few drops of engine oil or specialized cam grease to ensure smooth operation, preventing worn points and unstable ignition timing."
Apr 17, 2026 12:39 PM
Joined 6 years ago
The only lubrication that gets to the distributor shaft from the crankcase is to the lower part that rides in the bronze bushing. None of that oil gets to the top portion of the shaft that the points cam revolves around, Oil must be sparingly applied around the screw head at the interval stated in the Drivers Handbook. If this isn't done the cam will become rusted to the shaft and there will be no mechanical advance.
Silas
Silas
Watauga thanked SilasW for this post
