Corroseal Rust Converter ------------does it work----------need opinions
j46222 jeff Nabarek (Waddington)
Brownsburg, IN, USA   USA
1976 MG MGB
1976 MG MGB "Katie"
I found this stuff on the internet. Anyone have experience with Corroseal? give me your opinions. It says one based latex metal primer.
Can I put acrylic enamel over this?
Thank you for your response.
Jeff
Corroseal Rust Converter is an elite, industrial strength product for all marine, household, automotive, and industrial rust problems. Rust occurs naturally when the iron in steel oxidizes and returns to its original state, iron oxide. Through an innovative chemical conversion process, Corroseal Rust Converter converts rust (iron oxide) into a stable substance, magnetite. It also primes the surface with a high quality latex metal primer at the same time. Corroseal truly provides one step corrosion control. Corroseal features, water based rust converter with high quality latex metal primer, non-flammable, non-corrosive, Easy to apply (brush, roll, or spray), easy to cleanup with soap and water. Eco-friendly alternative to sandblasting Corroseal is the best way to deal with rust because it is less expensive, less time consuming, and is much more environmentally friendly than sandblasting. Corroseal eliminates the need to sandblast rust by chemically converting rust from iron oxide to magnetite, a black and inert substance. Don't remove rust, convert rust.
Paint, prime, convert rust in 1 step
Easy to apply - brush, roll or spray
Water based formula is easy to clean up with just soap and water
Compatible with most topcoats
Non flammable - non corrosive
2 year shelf life - keep from freezing
Marine uses include: bridges, ships, decks & deck railing, boat trailers, ferries, oar locks, shipping containers
Household uses include: garden tools, lawnmowers, trailers, wrought iron furniture & railings, decorative screens, pet housing, mailbox, fences, storage sheds
Automotive uses include: automotive restoration, vehicle frames, recreational equipment, utility trailers, ramps, floorboards, quarter panels
Industrial uses include: storage & fuel tanks, structural steel, manufacturing equipment, farm equipment & implements, fencing and gates, pipes, rebar
Subject to or will include a recycling fee in the following states: CA, OR, CT
Info & Guides
Product Brochure
SDS
You will need Adobe® Acrobat® Reader to view PDF documents. Download a free copy from the Adobe Web site.
If you read my post I thank you here. Thank you for reading/or responding to my post. I also thank you by pressing the thank you on your post.
May God Bless my fellow and lady friend MGers'. I wish all my fellow and lady friend prosperity, happiness and good health.
"Thumbs up to life and give the world a kick".
Donthuis Avatar
Donthuis Don van Riet
I tried so many rustproofing and rustconverting solutions, I wonder whether I can list them all in one go by memory eye popping smiley
What I do remember straightaway are my dubious results with the converting types like Kurust & Trustan: remnants of the solvents being used have to be meticuluously removed, which is not so easy. Passivation types like Hammerite are much easier to use and are only to be applied with a first, special primer if used over alloy material. Other passivation ones like Zincplate or Coroless ly inbetween.
Remember that still the best solution of all is removing all rust and start with some layers of metal primer on the bare metal before painting over (if needed preceded by filling and sanding flat) eye rolling smiley
Personally I mainly use Hammerite for touch up repairs. I made some with a color not too far away from my body, so finishing with the original paint is easy. On black parts I use Hammerite only
tkamd73 Avatar
tkamd73 Gold Member Tim Bradley
Menomonee Falls, WI, USA   USA
Bought a bottle from Moss last year. Tested it out on the hitch receiver on our Honda Odyssey. Wire brushed it and applied Corroseal as per instructions, lasted about a year, all rusty again. Tim
Marc2 Mark Hoefle
Richardson, TX, USA   USA
Jasco Prep and Prime works. My son is project manager in a metal fabrication shop, and they use it all the time. Used it on my engine bay before painting - worked great.
You can get it at Lowes
http://www.jasco-help.com/product/prep-primer
Edited 1 time(s). Last edit at 2017-11-11 10:12 AM by Marc2.
1974 MG Midget MkIII
