Cleaning a spray gun.
Jono1 Avatar
Jono1 John Alderson
Segonzac, France   FRA
Hi,
Having finished the prep I am just about to start spraying part of my wing.
A neighbour has lent me his spray gun and he suggested cleaning it with white spirit. Not too sure about that!
Is it best to use thinners to clean all the parts.
Any advice appreciated.
Thanks.
MG Baker Avatar
MG Baker Sonny Baker
PHOENIXVILLE, PA, USA   USA
1968 Mercedes-Benz S-Class "SOLD In 1998"
When I was a young man I worked in an auto body shop. We always clean our guns with lacquer thinner. Here in the US white spirits
is an oil based solvent. Any traces of an oil film may cause "fish-eye" and other defects in your final finish. Best to call a local auto paint supply company and ask the experts, or the paint manufacturer.
I can only tell you what we used back in the 70's.
Best of luck
Motoring with the top down, laughing in the face of the wind!
Safety Fast (Just be sure your brakes are good!)
garyd Avatar
garyd Gold Member Gary Dabrowski
Naugatuck, western Connecticut, USA   USA
1957 MG MGA 1500 "Long Gone"
1970 MG MGB GT
1975 MG MGB
John;
In order to achieve excellent results one must be fastidious in cleaning your gun.
A couple of references for your use:
https://www.autobodytoolmart.com/spray-gun-maintenance
https://www.autorefinishdevilbiss.com/Portals/0/documents/Cleaning%20Your%20Gun-Rev1.pdf
Maker of BHH558 carb and choke bracket for MGB cars fitted with the SU HIF4 carb & later car HIF4 upgrades and the highly regarded Air Filter Builder’s Kit, a compact and stylish alternative to Coopers Cans using economical paper filter elements.
Rick Fawthrop Avatar
Langley, WA, USA   USA
Here is a photo of a disassembled primer gun.
I start by wiping out the spray gun cup with lacquer thinner.
Then put some thinner in the cup and spray some thinner through it.
Then unscrew the cup and disassemble the gun as shown. And get each piece spotless.
And reassemble.
The guns usually come with a spanner and brush.
In America we use lacquer thinner to clean spray guns. In our jargon they are called “wash thinner”.
Edited 1 time(s). Last edit at 2023-04-17 04:32 PM by Rick Fawthrop.
EB2B0BD4-A302-4340-B9BA-9153265ECBD0.jpeg    40.8 KB
72FA070E-DC3C-405E-A14D-C1679B5A8DFE.jpeg    44.6 KB
748C8661-8380-43C6-B062-2EC1B8BC62AB.jpeg    44.9 KB
rustynut17 Jerry O
Almont, Mich, USA   USA
In reply to # 4641146 by Jono1 Hi,
Thanks.
John,... your cleaning solvent is dependent on what type of paint you are spraying. If using a standard automotive type paint lacquer thinner should be used. With other types of paints you may need something different. The directions on the paint can should tell you which type is recommended for that type paint and cleanup should be done as soon as possible especially if a hardener is being used... Jerry o
NOHOME P P
O, ON, Canada   CAN
As in "paint spray gun".
Edited 1 time(s). Last edit at 2023-04-17 06:26 PM by NOHOME.
Jono1 Avatar
Jono1 John Alderson
Many thanks everyone.
Some really helpful people on this forum. Am now a lot more confident in embarking on the final spraying phase.
Wish me luck!
Charles94 Avatar
Charles94 Chip Long
Charlotte, NC, USA   USA
1957 Triumph TR3
1960 Triumph TR3A
1961 MG MGA MkII
1972 MG MGB ~ For Sale ! ~
X2. Rick’s got it
In reply to # 4641316 by Rick Fawthrop Here is a photo of a disassembled primer gun.
And reassemble.
Chip Long
Charlotte, NC
  Speedracer thanked Charles94 for this post
Fresno, CA, USA   USA
EPA / Air Resources Board in California, recommends, "Gun Cleaning" solvent, or Acetone. Not Laquer Thinner.
Thanks.
Sir Henry Royce
co-founder of Rolls-Royce .
Joe Baba 2021
sweep Avatar
sweep Gold Member Chris W
Gosford, NSW, Australia   AUS
1966 MG MGB "Basil"
2013 Volkswagen Tiguan
2015 Audi A3
To me, a member of the inexperienced unwashed, it makes sense to wash your gun with the same solvent you thinned your paint with using the procedure outlined by Rick.
That's what I do - but what do I know. I wash my hands with WD40, then soap.
• The secret to creativity is knowing how to hide your sources.
• To the intelligent person, life appears infinitely mysterious, but the stupid have an answer for everything.
First rule of forum debate:
• My opinion becomes truth if I can find one other person, on the Internet with the same opinion. It is 'chiselled in stone" if I find two!
• War is God's way of teaching Americans geography.
waldog99 Avatar
waldog99 Wally Jonker
Outside of Tacoma, WA, USA   USA
In reply to # 4641950 by sweep To me, a member of the inexperienced unwashed, it makes sense to wash your gun with the same solvent you thinned your paint with using the procedure outlined by Rick.
That could get expensive. Especially since the primers, sealers, basecosts, clear coats all use different thinners. Gun wash was what we use to use. Just don't know if the same gun wash is used for waterborne paints vs. the solvent based products.
Wally
I pay $63 for 5 gallons of wash thinner and $30-$55 for a gallon of reducer.
There is an aerosol can in the top photo that is 3m spray gun cleaner. The attachment that holds the disposal cup is removed from the gun after spraying. And the aerosol cleaner is shot into the gun while the gun trigger is pulled.
  Jono1 thanked Rick Fawthrop for this post
rustynut17 Jerry O
Haven’t bought any lacquer thinner recently but i believe it is in the same price range. There is the more expensive version vs the cheap universal type which i use for cleaning the guns, cleaning bare steel for painting and cleaning engines and auto parts prior to painting. I’ve not used the actual gun cleaning solution yet as the cheap thinner has always done the job for me. I might give it a try if i found a gallon at a good price... Jerry o
  Jono1 thanked rustynut17 for this post
spikemichael Avatar
Bay City, OR, USA   USA
1973 MG MGB "Freebie"
1974 MG MGB "Spike"
1976 MG MGB "Cecil"    & more
Coming from the leather finishing world many years ago...
As production manager and QC at a leather finisher some 40 yeas ago, I held strict rules about mixing lacquer, water, and oil runs and employees.
Top coating was (is) lacquer. The old single headed sprayers I cleaned first thing in the morning (even though it was also the last thing cleaned the night before) the nozzles sat in lacquer thinner overnight. After assembly I would run thinner through the lines (typically 15 feet of hose), spraying useless hide to check spray pattern before dropping the pickup into the barrel (55 gal drum) of color.
The lines, gun, and nozzles were cleaned between every run or any time the system was idle for more than 20 minutes (hence 15 minute cigarette breaks were by bell). The guns were disassembled and cleaned between runs, changes of color, and at lunch, every day. Then at lose of business everything above the rack or outside the spray booth was cleaned before punching out.
No water was allowed near the lacquer booth, not even a cup of coffee or a bottle of spring water. The lacquer run was physically separated from the base coat (water based) spray runs by 25 feet at the closest point. Oil treatments were performed in completely different buildings. Though staff was all quite social, there was no mingling between start of business through lunch and start of afternoon work through close.
Keep your gun clean, wash using the same type of solvent you are spraying with.
Keep your spray booth clean, Keep distractions (and people) away while you are spraying.
Michael J. Caputo
'79, '77, '76, '74.5 (rubber dual SU), and '73 owner. 12v Audio System design. Vendor of Regalia and Promotional Products since 1993. Supplier of Accessories to MOSS. Forum Member since 2009. Warped sense of humor since birth.
Publisher of the annual MGB & GT Calendar, mailed worldwide. Buy one!
Send photos for the next calendar to photos27@mgbcalendar.com. If you need help with your Weber downdraft carburetor, feel free to call me at 978-249-5760, USA, Central Time! http://www.MGBcalendar.com
  Steve-in-Florida thanked spikemichael for this post
stryper Avatar
stryper Michael Menard
Houston, TX, USA   USA
1967 MG MGB GT "Spot2"
1971 MG MGB GT "Spot"
Since you understand british terminology watch the gunman painting videos on youtube he is in Oz
Best info for free and he is good...
Thanks.
'learn from the experts, you won't live long enough to figure it all out..."
1979 MG Midget 1500
