Barkeeper's Friend as windshield cleaner
Fairfield, CA, USA   USA
(note USA Brand names used, have no idea of an equivalent in UK or Oz)
I have used this, and the "hasn't scratched yet" cleanser (Bon Ami) on ceramic stove tops as well as porcelain and other similar surfaces. Works very well.
Wondered if it would work on the buildup of crud on the MGB windscreen. First step, see if someone has made a you tube video<G>. Of course they have.
Second step...actually do it. Well, that's for tomorrow.<G> Although I cheated and actually did it months ago. And it helped clean the screen a lot when normal glass cleaning didn't help that much on a 47 year old windscreen.
Note: i did not pay any attention to the frame.
Certainly cheaper than using clay bar stuff on a messy windscreen, which I've seen suggested.
If your wife has a ceramic stove top, you might swipe some of the stuff she uses...and then show her the much cheaper Barkeeper's Friend (or the Bon Ami, which I think is about the same)
I think that after a full cleaning this followed by a Windex, or lite vinegar solution washing (vinegar does a great job on oily road grime, but too much and you'll smell it for a long time<G>winking smiley. I'd use Rain-Ex as the final treatment as it tends to then shed rain and dirt when later washed with plain water. (willing to accept disagreement here<G>winking smiley
SUs, Datsun 5-speed
lgorg Avatar
lgorg Larry Gorg
Renton, WA, USA   USA
1966 MG MGB "Robbie"
Thanks, Mac! I never considered using Bon Ami or that ceramic stove top stuff. An I am the one who cleans the ceramic stove top in the Kitchen!
tvrgeek Scott S
I just use a razor blade with plenty of water.
warekl Avatar
warekl Gold Member Keith Ware
White Bear Lake Mn, USA   USA
Usually too coarse of a particle in those. Glass is much softer as well. You could easily destroy your windshield....... There is Glass Wax made to do just that.... other glass polishes as well....
USMC 1967 - Always ... Semper Fi
78 Midget MK IV Pagent Blue
73 GT in Black Tulip.. Engine by Hap Waldrop, OD Transmission by Dick Moritz Distributor is "Schlemmerized"
72 Midget MKIII Red
Edited 1 time(s). Last edit at 2019-02-20 06:33 AM by warekl.
woodenu2 Avatar
woodenu2 Paul Osborne
Lima, NY, USA   USA
Soap and hot water and use a stiff brush.
mgblestyle Avatar
mgblestyle Philip Shave
Olympia, WA, USA   USA
Mac, the old GM recommendation for water spots on glass was Bon Ami. I've used it, wet slurry, doesn't hurt glass. Phil
MountainWilliam Avatar
MountainWilliam Silver Member Bob Stonestreet
Spring Arbor, MI, USA   USA
1979 MG MGB MkIV "Baby"
Wonder if this can be cure for foggy headlamp covers?
Horsepower is how hard you hit the tree
Torque is how far you push the tree
Oversteer is when you hit the tree with the back of your car
Understeer is hen you hit the tree with your front end.
Bill MacTavish Avatar
Clayton, ON, Canada   CAN
1970 MG MGB "Monty"
It might be too coarse for the plastic of headlight covers, however I've heard
that toothpaste works.
I haven't tried it though... so not a recommendation.
Bill.
"Remember, for every mile of road, there are two miles of ditch."
Bill MacTavish
Clayton, Ontario
'70 BRG Roadster 'Monty'
ktm Avatar
ktm Keith M
Simi Valley, CA, USA   USA
I use Meguiar's clear plastic cleaner #17. I figured if it is safe for plastic convertible windows and computer screens it would be worth a try. It works great and also works on shower doors.
Keith
SteveZBMagnette Avatar
SteveZBMagnette Gold Member Steven Hanegan
Lake Forest Park, WA, USA   USA
1958 MG Magnette "Zeebee"
1962 MG MGA MkII "Arthur"
1969 MG MGB GT "The Black Russian"
Bar Keeper's Friend and Bon Ami both work great. Also, so does Comet and Ajax, and so does 0000 (Four ought) steel wool. DON'T use anything coarser than 0000 on glass, and use plenty of water. I have been doing this for decades. The trick is to remember that you are not sanding the glass - just cleaning it. Road film is tough to get off, but not impossible. The glass in a windshield is "toughened" (heat treated) and is very resilient. Vinegar and newspaper also work well for maintenance. Once per year (in spring to get the winter yuck off of the glass) for the intense cleaning then vinegar and newspaper for maintenance should be enough. If you have light scratching, folks such as Griot's garage make a dedicated glass polish that is designed to be used with a polishing pad on a random orbital buffer that will clear things right up.
Any product that is designed to be used on a glass cook-top or for removing soap film from shower doors etc will also work very well - assuming that you are not intending to do this every time you wash the car... Make sure that you take a cloth and some isopropyl alcohol to wipe the wiper blades too - dirty wiper blades will transfer the yuck right back onto the glass.
I learned these "tricks" back in the late '70s/early '80s working in dealerships to do the "new car get ready"/Pre Delivery Services to get shipping crud, crayon marks etc. off of the glass of the new cars. Makes 'em sparkle! I also make it a policy to buy the BEST wiper blades available (currently Bosch Icons) and replace the wiper blades twice per year - start of spring (Seattle rainy season) and beginning of fall (Seattle really rainy season), and haven't been disappointed yet.
Be advised that using newspaper on the inside of windows that have been tinted with film will not work (for long anyway...) - the newspaper is fine on glass, but too abrasive for the tinting films. For that, use "Sprayway" foaming glass cleaner and Costco blue paper shop towels. "Sprayway" can be had at NAPA, Tacoma Screw and other better industrial/fastener/proper damn parts stores (NOT O'Reilly's or Walmart!!), or, online.
As for plastic headlamp lenses, a super fine polish (such as Griot's #4 machine glaze or 3M glazing compound) and a random orbital buffer will make quick work of foggy lenses. Toothpaste and patience will also work well to clear them up (a random orbital buffer is just WAAAAY faster & easier). Afterwards, wax the lenses just as you would the painted portions of the bodywork. This will add some UV protection to help keep them clear.
I have a 2004 Toyota Sienna van that has giant plastic headlamp lenses that Toyota wants $1000 EACH for. The van lives outside in all weathers. I first did the #4 machine glaze when the van was 10 years old and the lights were starting to fog up and get dull, and did a minor touch up again last year, and they are crystal clear.
I have restored ancient glass that has sat outside in the weather for decades and/or been primered/painted over using either 0000 steel wool and dish soap or Comet and the "no scratch" dish sponges many times over the years with great results. The typical process is: 1) Wash with dish soap and a "no scratch" sponge to get the loose stuff off, 2) Razor blade off tougher paint/glue/sealers/silicone, 3) either Comet and a "no scratch" sponge, or dish soap and 0000, then dry. A final touch-up with "Sprayway" makes glass look like new. When you are drying the glass, make sure to use a fresh clean dish towel, best if the towel is older and has been washed a million times so it is nice and soft and absorbent.
ohlord Rob C
A tiny Island off the coast of Washington State, N.W., USA   USA
1957 Land Rover Series I "OVRLND"
1971 MG MGB "Bedouin 2"    & more
4 Aught steel wool the professions glass/glazers choice thumbs up
LNDRVR4X4.COM
Home of Project "INCARN8'
1957 Series 1 Land Rover electric VEHICLE CONVERSION
FIXITUPCHAP.COM
FIXITUPCHAP INCORPORATED
RD3 Radar/ Electronic Warfare Technician
VIETNAM 1969-1972
