1/8 inch staples and gun
Posted by jaws
Jan 9, 2016 01:46 PM
Joined 16 years ago
Jan 9, 2016 01:59 PM
Joined 10 years ago
http://www.nailgundepot.com/DuoFast-SureShot-3118-22-Gauge-Upholstery-Stapler-18-to-916-Details.html
A little pricey but one example. Located in your home state.
The problem with doing nothing is not knowing when you’re finished.
Jan 9, 2016 02:14 PM
Joined 17 years ago
4mm staples seem to work fine on interior panels and were much easier to source. Are Tacwise staplers available in the US? I've got one of these and also got a couple for friends who do bits on their cars:
http://www.transtools.co.uk/hand-tools/nail-and-staple-guns/tacwise-z1-53-metal-staple-gun-kit-with-staples-and-remover
Uses 4mm to 8mm staples.
Jan 9, 2016 02:21 PM
Joined 10 years ago
Peter-Sherman
Peter Sherman
Jan 9, 2016 07:34 PM
Joined 18 years ago
I tried staples but found that contact adhesive was, and many years later, still is much better. Easier to use and you get a better job. You can pull and stretch hard and it will stick. For example the top of the door foam bits need some stretching of vinyl. The snotty coloured stuff you paint on and then allow to go tacky. Every hardware shop. Factories like staples because you don't have to wait 5 minutes when you dab some on. Only use it for the back edges, back of winder hole and negative curves (door top) etc. The front of the panel has thin foam under the vinyl. For the foam you have to use a spray on very light adhesive to preserve the foam springiness/elasticity/plumpness (there isn't a word for that).
Jan 10, 2016 08:19 AM
Joined 16 years ago
