Body Filler ?
Posted by 59mgaguy
Jul 2, 2024 06:23 AM
With all the new body filler out there I was wondering which one you use and the reason why?
I'm using USC 16400 Pro-Gold ES which goes on so nice, no pin holes and sand so nice. Wish it would take a longer time before it starts to set up. I need more time.
John
John
Jul 2, 2024 07:39 AM
In reply to # 4815201 by 59mgaguy
Don't we all.
As for the body filler, don't overdo the hardener. And once mixed, spread it thin on your mixing board. If left in a thick pile the heat will build up causing it to react & harden faster.
Eric Russell ~ Mebane, NC
1961 MGA #61, 1̶9̶8̶1̶ ̶A̶l̶f̶a̶ ̶R̶o̶m̶e̶o̶ ̶G̶T̶V̶6̶, 1984 Alfa Romeo Spider, 1991 Honda ST1100
Jul 2, 2024 07:45 AM
Bondo™ have a line of good 'consumer' grade products. I recently needed to 'build up' a shape section and their chopped strand glass reinforced putty filled the ticket.
Jul 2, 2024 12:24 PM
In reply to # 4815230 by ghnl
Don't we all.
Don't we all.
I do know is that the hardener and filler is mixed by weight.
So Erie will you answer my question on which filler do you use? I'm looking to see which is more liked over the others and why.
John
Jul 2, 2024 02:10 PM
I bought some Evercoat brand at Advance Auto. Because it was handy, not because I know which brand is better.
Jul 2, 2024 05:31 PM
I should add that as a vintage race car it is not a show car. My goal for body work is to make it a 'ten'. Looks good from 10 feet away or over 10 mph.
ohmite thanked ghnl for this post
Jul 3, 2024 12:19 PM
In reply to # 4815526 by dela217
Optex
https://www.summitracing.com/parts/fge-135?seid=srese1&ppckw=pmax-paints-and-finishing&gclid=CjwKCAjwyo60BhBiEiwAHmVLJXmgmHBV60dq7B13XPp6IKuKqm5Ml5wFSXSW80bRbMjlnxN3jUIUnhoCPM8QAvD_BwE
How easy was it for filling and sanding?
Was there anything you didn't like about Optex?
John
