MG Motorsports Forum
Dropped spindles
Posted by JP12
Sep 29, 2008 06:47 AM
Joined 17 years ago
Hi,
There seem to be a fair few guys in the know about racing MGBs on this forum so I thought it would be a good place to ask for a bit of advise on the best setup for the front suspension of an MGB race car.
I want to lower the front of my MGB race car and I have been looking at using the dropped spindles which don't appear to be commonly available in the UK. If I fit the modified spindles how to I reduce the increase in bump steer? Do I need to adjust the rack and steering arms, and if so by how much?
Also, is this a beneficial modification or am I better off fitting a lowered spring. The front springs I currently have fitted are 8" 800lbs.
Thanks
Joe
Thanks
Joe
dcraddock43
Dave Craddock
Redford (Detroit), Mi., USA
Sep 29, 2008 07:26 AM
Sep 29, 2008 08:46 AM
Joined 23 years ago
Sep 29, 2008 09:14 AM
Dave Headley's dropped front axels are not suitable for street use. His modification is such that the "dust" cover between the bottom and top trunnion is not usable there by allowing for all sorts of dust, debris, and water easier access to the trunnion bushings with subsequent faster wear. If you do decide to use on a street car, you will need to grease quite often to "clean out" the trunnions. Dave’s axels also raise the roll center, a good thing, and provides some dynamic camber gain, also a good thing. As for Bump steer, I used Dave's dropped axels on my pervious B racer and IIRC, I did not need to adjust for bump steer - Stock steering arms with Dave's axels gave me about zero bump. I was using shorter spring for a total drop of about 2 and 1/2 inch. Whatever you install, you will need to measure the bump steer and make suitable adjustments to approach zero steer. I have seen some reverse the steering arms, left to right and right to left with various degrees of bend in the arms to approach zero bump. Some also use spherical rod ends with a thur bolt and spacer to adjust bump steer. This will require drilling out the tapered hole to accommodate the bolt.
Sep 29, 2008 09:24 AM
Joined 17 years ago
Sep 29, 2008 09:30 AM
blackmgb
Fred McConnell
Sep 29, 2008 11:02 AM
Sep 29, 2008 11:18 AM
Dick Luening's spindles are also available through John Targett at Targett MotorSport, which might be an advantage to you (living in the UK) because John travels home to the UK with a very full suitcase from time to time, and that might save you shipping costs.
Here's what they look like:
Here's contact info for Targett MotorSport:
Sep 29, 2008 11:33 AM
I don't think Dick and Dave use the same procedure to drop the axel. With Dave’s you get a different suspension geometry. The trunnions are moved apart by 1 inch by lengthening the king pin an inch and welding a 1 inch long tube to the bottom of the swivel axel. This drops the car an inch and provides additional dynamic camber gain on bump.
I believe Dick’s process just raises the axel relative to the two trunnion points by removing an inch from the top of the swivel axel and adding an inch to the bottom of the swivel axel, thereby retaining the stock geometry and lowering the car 1 inch. You can see this in the post above.
With Dick's process, you do not need to modify the kingpin. With Dave's you have to cut the kingpin at about its center point, add an inch spacer and weld.
I think I still have a set of the Headley dropped axels and will try to post pictures tomorrow.
Edited 1 time(s). Last edit at 2008-09-29 11:41 AM by JohnP.
twentyover
Greg Fast
Lives in SoCal, Moving back to ancestral homeland, the Pacific NW, USA
Sep 29, 2008 11:51 AM
The swivels I got from Headley are stock length, he milled 1" off the top and welded a 1" sleeve on the bottom. Internal dust covers still worked ok, the swivels work on stock kingpins.
While I agree that if a taller kingpin is used, there would be a change in negaive caster gain, the units he supplied me fit stock kingpins, there is no additional length between trunnions
blackmgb
Fred McConnell
Sep 29, 2008 12:22 PM
JohnP Wrote:
John, You are right. As a result, my bump steer is not zero like what you got from Headley. This is something I need to sort out this winter.
Edited 1 times. Last edit at 09/29/08 09:41AM by JohnP.
Sep 29, 2008 12:43 PM
Sep 29, 2008 12:58 PM
Joe, another option on your side of the pond is Bob Yarwood. He's located at
60 Whitchurch Road
Audlem
Cheshire
CW3 OEE
01270812083
He currently is racing a B in your neck of the woods.
60 Whitchurch Road
Audlem
Cheshire
CW3 OEE
01270812083
V31 Lightweight Aluminum Seats are built utilizing a state-of-the-art CAD/CAM system and production techniques that ensures the Vintage 31 seats are of the highest level of quality for your vintage racer or sports car. Proudly built in the USA.
Sep 29, 2008 01:04 PM
Another option Joe is to deepen your spring pans. Works very well.
Sep 29, 2008 06:31 PM
Here is a picture of the two different types of dropped axels that I know of. The lower one is from John Targett. The upper one is from Dave Headley. You can see the weld on the Headley version. It precludes removing the king pin and using the dust cover.
