Spitfire 1500 overdrive Gearbox into MG Midget 1500
CUDHSO Avatar
CUDHSO Richard O'Neill
Penzance, Cornwall, UK   GBR
Hi,
I have a chance to purchase an overdrive gearbox from a spitfire to fit into my midget 1500. The available box has no gear stick. I plan on using a steering column mounted overdrive switch so I don't actually need the original gear stick with the switch etc., so long as my midget 1500 gear stick fits mechanically.
I figure there is a small chance it could fit, given the limited parts bin shared by the manufacturers when they were produced. Has anyone done this swap using the Midget 1500 gear stick and did it work well? Are there wise words I need to consider?
Thanks, Richie.
Besides confirming if the different shifter lever will fit, you didn't mention that you will need to modify the tunnel so I bring it up just to make sure you have done a search here and found the photos which show how it was done before.
Not a simple swap, because of the structural changes needed, but like so many things it can be done with surgery.
CUDHSO Avatar
Hi Kerr,
Thanks for the post. I fully recognise the requirement to widen the tunnel. It is commonly done using a scissor jack and the amount to clear is not that much. Thanks for bringing it to my attention though.
I don't follow your tack regarding "Besides confirming if the different shifter lever will fit". Are you confirming it will fit? if so, that's great. Have you fitted a 1500 gear stick into a Spitfire overdrive unit?
Thanks, Richie.
mg man 75 Avatar
mg man 75 maurice sallee
Campbellsville, Central Kentucky, USA   USA
unfortunately, no, I've no useful information
Maurice's link looks pretty informative though, hopefully someone knowledgeable will chime in about the shift lever.
dlrhine Avatar
dlrhine Dave Rhine
Columbia, SC, USA   USA
Richard
That sounds like a Triumph specific type question.
You may want to try the folks on the Triumph experience.
When I've been stumped & can't find 1500 engine/transmission knowledge here, I go there...
http://www.triumphexp.com/phorum/list.php?8
Good Luck
smileys with beer
If it ain't broke, I'll fix it until it is! winking smiley
Edited 1 time(s). Last edit at 2016-08-14 04:42 PM by dlrhine.
jdeatsch Avatar
jdeatsch Jim Deatsch
Leesville, SC, USA   USA
1978 MG MGB "Orval Shiftright"
2002 Mazda MX-5 "Two Zoom"
Richard,
You don't mention the year of the year of the Spitfire.
If you are late and the Spit is late then you're good to go EXCEPT that your shifter will not fit into the Spit gearbox unless you slot the other side (left side) of the ball where it fits into the top of the shifter extension.
If you are late and the Spit is early (three rail) then all bets are off unless you change the clutch as the earlier 1500 Spits used a 10 spline disk and the later cars, your and the Spit, use a 21 spline clutch.
Clear as much?
Edited 1 time(s). Last edit at 2016-08-14 05:16 PM by jdeatsch.
jmac Avatar
jmac Gold AdvertiserAdvertiser Jere McSparran
Greenup, IL, USA   USA
1970 MG Midget "(SOLD)"
1974 Triumph TR6 "(Destroyed In My Fire)"
1978 MG Midget "Therapy (SOLD)"
1978 MG Midget "(SOLD)"
Make sure it is the "J-type" overdrive from a later Spit. The Midget shifter WILL work, however you must move the alignment pin from one side of the shifter hole to the other side. The alignment slots on the Spit is opposite to the Midget. I made the switch and used a Midget shifter on my OD tranny conversion.
JMAC
Jere McSparran
JMAC Engine Shop
Website: http://www.jmacengineshop.com
email: jmacengineshop@gmail.com
Phone: 217-232-7303
MG/Triumph engine rebuilding. Specializing in the Midget/Spitfire 1500 engine.
CUDHSO Avatar
Thanks all for this great Advice. A big 'hat tip' goes to jdeatsch and Jmac, who provided me with the essential info I needed. The 'box' that was easily available is a D-type overdrive so I have saved some money and heartache by not buying it.
Mg man 75, thanks for the great link.
I shall cast my net wider for a J-Type box.
Richie.
jmac Avatar
From what I hear, they are getting harder and harder to find. But keep looking, they are out there.
JMAC
Jere McSparran
JMAC Engine Shop
Phone: 217-232-7303
1967 MG MGB GT
