King Pin Pin removal
moebuster Avatar
moebuster Keith Montgomery
Athens, AL, USA   USA
I see the 8mm nut and have removed it.
now- what's does it take to get the pin OUT??
is it threaded in or pressed in?
somehow I can't see brute force doing anything short of destroying it.
1974 Mk2
Keith,
the threaded pin cannot be removed that little nut only held the wedge shaped "cotter pin" in place until enough time and corrosion had permanently fixed it in there
to remove the king pin, saw through the lower fulcrum pin on either side
don't worry about trying to save the lower a arms, they are consumable (they crack and wear so by the time this level of overhaul is called for they are scrap)
hope this helps,
Norm
Frankenmuth, MI, USA   USA
You can try to remove the pin, but often they are rusted solid to the kingpin. Put the nut back on even with the end of the threads and whack it with a hammer. If you're really lucky the pin will come out. It's OK if you destroy the pin, replacements are readily available and they're cheap. The last two cars I disassembled came apart without too much trouble. If the pin resists your efforts follow Norm's advice and saw through the fulcrum pin on each side of the kingpin.
Perambulator David D
Phoenix, AZ, USA   USA
Correct me if I am wrong, but that fulcrum pin is hardened steel no?
If the a-arm is going in the skip, you don;t even have to bother with the lower fulcrum. Just undue the top trunnion, pull the swivel axle off and toss the old kingpin and a-arm in the bin.
PeterC Avatar
Madison Wisconsin, USA   USA
In reply to # 3271163 by Perambulator Correct me if I am wrong, but that fulcrum pin is hardened steel no?
Almost that simple. You have to loosen the backing plate to clear the kingpin base, unfortunately, which means removing the rotor, etc., etc.
ajbowles Avatar
ajbowles Adrian Bowles
Westport, CT, USA   USA
and then buy your parts from Peter - that's what worked for me!
wishbone.jpg    47.7 KB
moebuster Avatar
Athens, AL, USA   USA
got the retaining pins out via Kroil but the kingpins are seized solid and destroyed new saw blade in about 10 seconds!
1974 Mk2
moebuster Avatar
Athens, AL, USA   USA
Does anyone know what Peter gets for a-arms?
1974 Mk2
S1 Elan Kurt. Appley
Akron, Ia., USA   USA
In reply to # 3271595 by moebuster got the retaining pins out via Kroil but the kingpins are seized solid and destroyed new saw blade in about 10 seconds!
You need something that will cut hardened steel. Friction cut off wheel used here.
Kurt.
moebuster Avatar
Athens, AL, USA   USA
DUH!!!
Why didn't I think of that!
Thanks for the wake up call Kurt.
1974 Mk2
1973 MG MGB GT
