Broke the nipple part of brake bleeder screw
G0Bigred Avatar
G0Bigred JD Wyborny
Winterville, NC, USA   USA
1960 Austin-Healey 3000
1976 MG Midget 1500 "The Midge"
So I was trying to loosen the screw on the blake bleeder valve and I accidentally broke off the nipple part of the valve. Will I still be able to bleed the brakes or do I need to replace the entire screw. If so how do I do that?
o2batsea user120545
Location not set
are the wrench flats still on the thing? If yes then you're good. Tighten it down so you have brakes. Order new bleed screw. You can just swap the bad one with new and off you go.
baloo Avatar
baloo s y
Houston area, TX, USA   USA
If it broke off even with the caliper, get a small "screw-out" (reverse thread screw extractor) - stick it in the hole and the remaining nipple will back out. I have also used these extractors when the nipple's hex flats have rounded out such that I could not get anything to grab around the neck.
  Killian thanked baloo for this post
G0Bigred Avatar
G0Bigred JD Wyborny
It broke off above the actually screw. I am going to try and loosen the screw and still see if I can bleed the brakes. I have been soaking it in penetrating liquid to help me turn it.
o2batsea user120545
Location not set
If it broke off in the caliper, I would probably just get another caliper. Time and trouble to remove more than just putting new one on. That's just me.
G0Bigred Avatar
G0Bigred JD Wyborny
Its actually on the rear brake
o2batsea user120545
Location not set
even more reason. get a new wheel cylinder
Richard D Avatar
Knoxville, TN, USA   USA
I hate when that happens....
1969 MG MGB GT
