Air Cleaner Bolt Spacer Ideas
AmishIndy Avatar
AmishIndy Seth Jones
2007 Mazda 3 "Porco Rosso"
Inside the "cooper cans" style air cleaners are some tubes ment to keep the two bolts from crushing the air cleaner. Originally they were made of a soft steel that had been bent into a tube, but the seam was left unwelded. I am rebuilding a set of SU carbs for a friend and we bought a set of the OEM cooper cans for it from a swap meet. they needed some work. I got rid of the dents, carefully primed sanded primed sanded and panted so they look great. It was missing this spacer or "distance piece" on one bolt and the rest look pretty smashed. I was wondering if anyone had some ideas of what I material I could use instead of the factory spacers that would stand up to the heat of an engine bay and be about the same size as the original piece. The bolts are 5/16" in diameter. There has to be some fiberglass, or carbon fiber that would work right? I remember making some OEM style ones out of some electrical conduit back in the day when I was closer to a good shop with a good vise and a hacksaw.
BTW I've checked, this part doesn't show up on moss as far as I can tell, and yes I've checked the factory parts lists too.
Seth Jones
1971 MG Midget
www.SpridgetGuru.com
sam-i-am Avatar
sam-i-am Sam L
Caledonia, Wisconsin, USA   USA
Hi Seth,
Check out a McMaster Carr catalog. They sell thick wall tubing in smaller sizes.
Sam.
ice Avatar
ice Platinum Member Larry Ice
Lawrenceville, GA, USA   USA
How bout a piece of 5/16 fuel line cut slightly longer than the original steel tubing and forced over the bolts? When compressed they will provide support for the "can". I don't think you would have a problem with the heat and you can easily adjust the proper length with a knife. Don't think the vibration would bother them either.
FWIW
Ice
Iceman
Atlanta GA
71 MG Midget
62 AH MKII
67 Midget
71 Midget
trevorwj Avatar
trevorwj Trevor Jessie
Louisville, KY, USA   USA
Gutter spacers.
Perdido Avatar
Perdido Silver Member Rut Rutledge
Tuscaloosa, AL, USA   USA
Seth,
I have 4 spacers from my 73 parts car if you're interested.
Rut
littlecars Avatar
littlecars David Bassett
Nashville, TN, USA   USA
1959 Ford Country Sedan "Oliver's Hearse"
1963 Chevrolet Corvair "SOLD!"
1965 MG Midget MkII "Buffoon --- SOLD!!!"    & more
I found a couple spares rummaging around in my boot. Welcome to them as patterns or to use.
Cut lengths of PVC pipe to fit... winking smiley
66jalopy Avatar
66jalopy Phillip Jolliffe
Lake City, FL, USA   USA
I attached the bottom plate with a stud and nut, threaded another nut on the top thread the right distance and put the top on then tightened another nut on top.
mantwillys Avatar
mantwillys skip m.
wadsworth, NV, USA   USA
seth,
3/8" pipe from hardware store cut to proper length.
skip
if you are are not happy,you are doing the wrong thing. sooo.....??
TeamEvil Avatar
TeamEvil Thomas C (Disabled)
Kingston, MA, USA   USA
If you decide to ignore all of the above terrific suggestions. Take a trip to Lowes or Home Depot and just walk around. You'll find more options than you can count.
Easy Peasy ! !
Billm Gold Member Bill Masquelier
Santee, CA, USA   USA
Don't try to cut the EMT tubing with a hacksaw- get a tubing cutter from Harbor Freight ($5.00) and get a straight, clean cut
BillM
littlecars Avatar
We don't need no stinkin' straight cuts! Do like the boys did in Abingdon did on a Friday afternoon…just after their first pint.
1975 MG MGB
