Spec info: 93-95 Camaro V6 motor weight, T5 gear ratios, Auto ratios, tire sizes and more! -GM Documentation-
Posted by BMC
Mar 19, 2016 12:10 PM
In reply to # 3220371 by V8MGBV8
Flywheel, clutch, pressure plate, throwout bearing...bet it's close.
In reply to # 618865 by BMC
The only issue I have with the weight is that the flywheel, clutch and all that cannot make up for 40.8 Lbs. The Camaro flywheel is not light compared to others but hmm... I guess I will have to take some weights and measurements to compare.
-BMC.
-BMC.
I have weighed everything needed to build a complete, ready to run, Ford 302 except clutch, pressure plate, and throw out bearing - any one have actual weights for these? If I had those numbers, I'd know within a couple of pounds how much a 302 weighs.
Grapegrower
Bill Nicolaou
Mar 23, 2016 08:28 PM
Mar 23, 2016 08:53 PM
In reply to # 3224359 by Grapegrower
Just measured the weight of the 95 Camaro flywheel at 19 lbs. the clutch and pressure plate at 14.5 lbs., the lever and TOB at 1.75 lbs.
Weighed together came to 35.2 lbs. Should be real close! Bill
Thanks, Bill,
That puts the weight of a 302 w/aluminum heads, a 27 pound flywheel (standard on FMC crate engines) and light weight accessories at 424 pounds. Compared to the original MG engine at 396 pounds!
Mar 25, 2016 08:29 AM
Carl, that's what I was thinking too, versus a couple pounds for a flex plate. Bolt a torque converter to the flex plate or remove the clutch assembly and you have a better comparison.
jeff@advanceddistributors.com
Mar 28, 2016 08:16 PM
Joined 16 years ago
Mar 29, 2016 04:07 PM
Joined 21 years ago
In reply to # 3227991 by fiveiron
the OP says T5 in the subject line and the other info says M49 are they the same?
thanks
thanks
T-5 in general is a 5 speed manual tranny of which there are many variations. M49 is the General Motors RPO code for the GM V6 T-5, specifically.
about 1 week and 29 minutes later...
Apr 5, 2016 04:36 PM
Joined 16 years ago
about 3 years and 3 months later...
Jul 11, 2019 12:23 PM
So, looking at these numbers it seems like it should be fairly easy to transplant the entire '94 Camaro 3.4 / 4L60E engine/automatic transmission setup to an MGB using the MGC's 3.07 gear ratios as used in most T5/V8 conversions. "Fairly" being relative - tunnel mods, mounts, custom driveshaft, etc. But with, say, 205/60/15 tires (more mods?) and the stock MGC gear ratios, the revs are amazingly close.
A great man is hard on himself. A weak man is hard on others.
“When someone shows you who they are, believe them the first time.” ~Maya Angelou
Edited 1 time(s). Last edit at 2019-07-12 11:09 AM by RSS.
In reply to # 617989 by BMC
Automatic aka Hydra-Matic 4L60E
4 speed Auto w/ Overdrive(4th gear Overdrive, Lock Up Torque converter Clutch)
1st 3.06
2nd 1.63
3rd 1.0
4th 0.70
Reverse 2.29
MAXIMUM Upshift speed: 1st-2nd=37 mph, 2-3=70 mph, 3-4th= N/A Above 56% throttle, Will not Make WOT 3-4th
MAXIMUM Upshift Engine RPM: 5200
Axle Ratio (Both Manual and Auto) 3.23
No. of Teeth- Pinion= 13 Ring Gear=42
Wheels And Tires
P215/60R-16 (STANDARD ON SPORT COUPE)
P235/55R16(STANDARD ON Z28; OPTIONAL FOR SPORT COUPE)
Rim Size
Cast Aluminum
16x7.5
16x8 (OPTION FOR SC, Z28 rims)
1st 3.06
2nd 1.63
3rd 1.0
4th 0.70
Reverse 2.29
Wheels And Tires
Rim Size
Cast Aluminum
16x7.5
Minneapolis, Minnesota, USA
1959 Austin A40 Farina
1959 Austin-Healey Bugeye Sprite 1959 Morris Minor 1000 Pickup 1961 Austin-Healey Sprite "Green Sprite" & more |
Jul 16, 2019 08:27 PM
Joined 26 years ago
In reply to # 3975032 by RSS
Rick,
As you're getting ready, call me and I can get you a list close to what your searching for. Our parts and bits and pieces you'll need from elsewhere. As long as you are converting a 1968 and later MGB, the automatic fits with a little work, but from all accounts I have read and helped with, the 3.4L with automatic fits a lot easier than most other conversions. Slightly more work than a T5, but not much more.
-BMC.
Jul 16, 2019 09:25 PM
Thanks, Brian. Parts of that may be happening sooner than I'd planned. I was talking to a friend, and it turns out he's got a '94 Camaro, 3.4L, A/C, automatic, ~156K miles, that he gave to his college-age son a few years ago. Sonny moved on, got a blingy new car, and the Camaro is just taking up room in Dad's driveway. The car runs rough - needs a cat, EGR, new plugs, wires (it's ticking/sparking on one side due to old wires), tires, fluid changes, etc. Maybe more, once it settles in and I can look at the DTC codes. But it runs. Best part is, looks like I'll be able to get it for a song - basically free.
So - the plan is to get the car, get it back on the road, and use it as a spare set of wheels until I'm ready to start on the GT conversion. (Gotta get rid of a donor '69 GT, gotta get my wife's old Maza's alternator replaced, that sort of thing. Oh, and replace the starter on my '73.) I do not want it to sit unused for another year or two, so it's important to spend a few shekels to make it road-worthy again.
Still pretty unsure about using this engine directly in the conversion 'cause of the mileage, but worst case is I use it as a core for a "new" long block. Jegs and Summit have remanufactured "crate" engines for under $2K. Pretty much everything else will be scavenged for the conversion.
Edited 1 time(s). Last edit at 2019-07-16 09:29 PM by RSS.
Jul 16, 2019 09:32 PM
Joined 26 years ago
There are three parts to a conversion:
*The car
*The new driveline
*And all the parts that are built to connect the two unrelated items.
The third part is where we come in.
As for price, look at car-part.com and consider what an engine and gearbox cost off there. I suggest a used T5 is worth around $400, a used 3.4L is worth about $600, or $1,000 for the set. A used automatic, in my opinion, is worth a couple hundred less as more of them can be found very easily. If the asking price on the Camaro is $2,000 for instance, that's not a very good deal when you have to look at the total price of the conversion- which is not a simple "headers+engine+gearbox=done" as many imagine at the beginning. I'm not trying to scare you or lead you away but educate before starting. I know you will Love the end results.
-BMC.
*The car
*The new driveline
-BMC.
