MG Performance Forum
Rover 4.0 project restart
galotis Avatar
galotis George Van Horn
Collegeville,, PA, USA   USA
1980 MG MGB "Ms. Blue"
I am restarting an 3 year old project for a friend, this is a 4.0 rover, it will have EFI, my first problem to solve is the front cover, what the best to use, and if I keep the reverse flow water pump is there a kit to mount the AC and alt? Also on second photo you can see I really don't have much clearance for oil take off, any suggestions on this? As I stated left off this 3 years ago, so am trying to remember what I did.
20180603_145731.jpg    58 KB
20180603_145646.jpg    37.7 KB
Restoman Avatar
Restoman Platinum Member Dana R
amston, CT, USA   USA
Hi George, I was in the same situation, and finally bought a front cover that had proper oil pump for that motor,
but converted back to V-belt c/w rotation. A bit pricey, but very fine craftsmanship.
http://www.johnealesroverv8.co.uk/3.html
George I can't help but will note you'll get better/more responses on the Swaps forum - this is a 1798 performance forum.
V8MGBV8 Avatar
V8MGBV8 Carl Floyd
Kinggsport, TN, USA   USA
In reply to # 3749987 by MGB567 George I can't help but will note you'll get better/more responses on the Swaps forum - this is a 1798 performance forum.
Not exactly, Barrie.
Performance upgrades and modifications discussion for MGB, MGA, Midget and all other MG models
I do agree, he would be better off asking on the swaps forum, since this one is primarily for performance of original MG engines (1798,1500, 1275, 1250, etc). IMO, it is also for tweaking performance in all categories, not just engines.
galotis Avatar
Thanks for the input, am moving to British V8 forums. who ever has control can remove this post
Denis Avatar
Denis Denis Hill
George that engine is almost the same as mine in the GT, Its a 1995 3.9L a little earlier than yours. Mine has a conventional oil pump where yours would probably have the crank driven pump. I fitted the early 3.5 front on mine timing cover W/pump etc and fiddled with a couple of different crank pulley. you can do the same and the early pump will drive off the distributor drive. You then need a new lid for the oil pump for clearance of the oil pipes to the remote filter. Here is a pic of my setup. There are some on the British V8 sight that have used your setup and kept the multi groove belt , crank oil pump etc. Mine works well but I think the crank driven pump is better.
Denis
IMG_1438.JPG    53 KB
joron Avatar
joron Silver Member Michel Joron
Roxboro, QC, Canada   CAN
1977 MG MGB "Victoria"
Denis, it is very nice engine.
1977 MGB Red 'Victoria'
All Classics:
Married, 2 children, 2 dogs, MG MGB May to December.
