Amp meter goes all the way down and stands on -20 amp HELP
aremgb Avatar
aremgb are ATR
., ., Norway   NOR
1953 MG TD "Esmeralda"
1969 MG MGB MkII "44 Year Crisis"
1999 MG MGF
2002 MG TF "TF160"
Hi guyes
Driven my restaured car now for 180 km. Last night when i parked in the garage and turned of the key amp goes all the way Down. now lights on now other Source for consumption.. when i cut the Power to the battery immediaty the amp goes to zero. I have buyed av eletronic regulator that is installed. When i turne the key on the warning light for charging is not turned on.
I belive that the regulator is corrupt and Power is going to the generator thrue the regulator. not good at all ?
Am i on the right track ?
best regards
Are
peter14222 Avatar
peter14222 Peter Gilvarry
Buffalo, NY, USA   USA
In reply to # 3737196 by aremgb Hi guyes
best regards
Are
Is this immediately after installing the electronic regulator? If so, check connections.
If it has worked in the past, a bad regulator.
Either way, not good!
Peter
aremgb Avatar
aremgb are ATR
., ., Norway   NOR
1999 MG MGF
2002 MG TF "TF160"
it has been functional for 2 to 3 hours before this happening.
peter14222 Avatar
In reply to # 3737203 by aremgb it has been functional for 2 to 3 hours before this happening.
If you did not change anything probably a bad regulator, or a connection came loose.
Wichita, KS, USA   USA
Sounds like a bad regulator, but it could also be a short circuit to ground somewhere.
aremgb Avatar
aremgb are ATR
., ., Norway   NOR
1999 MG MGF
2002 MG TF "TF160"
It was a bad regulator.
