Rocker assembly
hurst280 Avatar
hurst280 Gold Member Sean D
Plano, TX, USA   USA
1954 MG TF "The MG"
Does anyone have a rocker assembly in reasonable shape (arms that have not been ground down) which could be sold to me for my TF?
Or maybe just arms, and I could purchase the rest
of the bits from AS or moss.
Thanks!
"the pursuit is the thing, not the reward, not the gain."
crankjournal Len Fanelli
Yonkers, NY, USA   USA
Sean the rockers can be resurfaced with a whetstone by hand, I do not like the replacement rockers.
Remember that the shaft wears much more than the rocker bushings.
Do you have the early 14" shaft with wide and narrow rockers or the later 14 7/8" shaft with all wide rockers?
Len Fanelli
Abingdon Perormance
LaVerne Avatar
LaVerne LaVerne Downey
Fruita, CO, USA   USA
1954 MG TF "Green Hornet"
1979 Triumph TR8 "Wedgie"
He has a TF so he should have the longer shaft assembly.
plus4moggie Tom Lange
Bar Harbor, ME, USA   USA
They appear on eBay not infrequently, under $200, but needing rebuilding.
I use Rocker Arms Unlimiteed for this service, as they do not use the soft and poor-quality Chinese rocker shaft from the usual... They hard-chrome it and centerless-grind it back to spec, they re-weld the tips with Stellite rod and re-shape them, they re-bush and re-fit the rockers. Well worth the money for what they do.
Tom Lange
MGT Repair
jean yves Avatar
jean yves simon jean yves
cannes, paca, France   FRA
break
DSCN2174.jpg    27 KB
WHT Avatar
WHT william luddite
Brakenville, USA, USA   USA
Rocker Arms Unlimited do a great job of rebuilding/refinishing.
ValveGear2.JPG    31.1 KB
Tim66 Avatar
Tim66 Silver Member Tim Burchfield
Toledo, OH, USA   USA
1951 MG TD
1953 MG TD
Sean, I have quite a few rocker arms. PM me if you are interested.
Tim
1951 MG TD TD26711
1953 MG TD TD12524
1980 Corvette
1972 MG MGB GT
