Need external balance 2.8l GM flywheel
MGBGM1977 Avatar
MGBGM1977 Anthony Piper
Mossy Head, FL, USA   USA
Does anyone know where to find a flywheel for a 1980-87 GM 2.8l engine? Would be flywheel with GM Part #14088277 which carries the casting number 14033082.
flywheel2.jpg    50.1 KB
260mgb Jim Nichols
Sequim,WA, USA   USA
Anthony, Any auto parts store can get it. Check Rockauto or Google online for 83-85 Chevy S10 flywheel.
MGBGM1977 Avatar
Tried Rockauto, Partsgeek, Summit, O'riellys, Advance, Autozone...........etc. What they are saying fits is actually for the internal balance engine made after 1987. All the GM parts sources say it is no longer available.
260mgb Jim Nichols
Sequim,WA, USA   USA
Anthony, Try car-part.com. Nationwide wrecking yard locater.
MGBGM1977 Avatar
I am trying them. Unfortunately too many people don't know the difference between a flywheel and a flexplate. Uggh!
MGBGM1977 Avatar
Still looking. I guess anyone that has one won't let go of it. All the earlier cars that had them probably have met the "Crusher" by now. I have checked out so many that either ended up being the internal balance or what the had was actually a flexplate. Never seemed to have this confusion about flexplates and flywheels back when I was a young "hot rodder". It's a changing world for sure.-haha
1744 Avatar
1744 Gold Member Bill Guzman
CA, USA   USA
1974 MG MGB "Renegade"
BMC Avatar
I have one but it was promised to someone else. I will see if it is still needed and if not...
Also, what is the ORIGINAL application for the engine? What are you using behind it now? This is very important.
-BMC.
260mgb Jim Nichols
Sequim,WA, USA   USA
Summit Racing has an add on weight, but you would have to know the weight.
https://www.summitracing.com/parts/mcl-560222
Edited 1 time(s). Last edit at 2018-02-04 01:23 AM by 260mgb.
MGBGM1977 Avatar
Bill Guzman, that is the wrong one. If you look under specs, it does not have the external balance weight. This is what I have been running into. But, just a few minutes ago I found the correct one at a junkyard up north. It is now on the way to my house. Here is a picture showing the external balance weight.
s-l1600.jpg    47.9 KB
MGBGM1977 Avatar
This one was behind a 1985 2.8l engine. They changed from external to internal balance on the 2.8l engines in 1987. This sure was a tough one to track down. Thanks for all the input, guys.
BC, Canada   CAN
Could one not just get an internal balanced flywheel, and get it rebalanced. I am just wondering if there is a reason, it would not work.
MGBGM1977 Avatar
In reply to # 3696287 by Richardtherodder Could one not just get an internal balanced flywheel, and get it rebalanced. I am just wondering if there is a reason, it would not work.
Yes, you sure could do that and it would work fine. It's always nice to find the correct part though. The one I found cost me $50. Getting one modified to fit would cost much more I am sure. But, I was thinking about going that route until I finally stumbled across this one on Ebay.
bills Avatar
bills Bill Spohn
What's all the fuss about? That's exactly what to do and a simple machining operation. With the cast in weight removed and the flywheel neutral balanced it is functionally identical to the 88 and after internally balanced wheel. And Anthony, you'd wind up with a flywheel that was balanced to a finer tolerance than the factory ever did for those wheels, so it is actually a better, if possibly slightly more costly way to go..
2007 BMW Z4M coupe (340 bhp)
North Vancouver BC
Edited 1 time(s). Last edit at 2018-03-13 12:24 PM by bills.
MGBGM1977 Avatar
In reply to # 3696534 by bills
Well, this one with the weight on obviously worked just fine for many years. I think I will just leave the weight on it. Do you re-balance every flywheel you use?
