While I wait and see if Danmas answers my PM for those who've fitted a Flaming River column can you tell me something about how best to attach it to the car both under the dash where the three lugs are and to the firewall. Presumably for the latter I need one of these products but which is best? I searched like here but haven't found a how to yet - I'm looking at a non-collapsible ie not tilt.
Posted by MGB567
Sunshine Coast, Queensland, Australia
Jan 12, 2018 02:36 AM
![]() ![]() Joined 7 years ago
rficalora
Rob rficalora
Cypress, TX, USA
![]() 1976 MG MGB V8 Conversion "MG MUTT"
Jan 12, 2018 01:59 PM
Barrie, I'm sure Dan will be along to help with info. In the meantime, have a look at his How it Was Done on BritishV8... http://www.britishv8.org/MG/DanMasters.htm. There are a couple of pics that show a hoop shaped bracket made to line up with at least 2 of the captive nuts on the OEM bracket. Here's one of the pics but there's at least one more too.
Jan 12, 2018 05:07 PM
Thanks Rob - yes Dan has just sent me lots of links to study over the weekend
Jan 12, 2018 09:27 PM
Dan linked his car's build with pictures that can be enlarged but I'm still at a bit of a loss and need info if anyone has it. In this topic it's confirmed that the OEM collapsible columns all used the same method of attachment to the cradle under the dashtop/scuttle - the three lugs. Obviously to attach a FR column I'll need to modify that cradle so I can use one/two of these but I'm wondering do I need one or two saddles - I think Dan only has one; that's all I can see in the pic but my eyes can deceive me.
Given I've come this far with alterations eg Fastcars FE & Bill's rear perhaps a fully integrated column too???????????
Jan 12, 2018 11:56 PM
Joined 4 years ago
I believe that Flaming River racks for the MGB may well be made by the same South American company that makes the aftermarket ones that Moss sells. I had a conversation with someone at Flaming River a few months ago when I was looking for an alternative to the Moss one and he in passing confirmed that theirs too are made in South America.
danmas
Dan Masters
Alcoa, Tennessee, USA
![]() 1974 MG MGB GT V8 Conversion "Powered By Ford"
Jan 13, 2018 02:00 PM
Barrie,
Here are a couple more pics that may help. The column is mounted with two saddles that were homemade by Ted and Terry. Since there are only two UJs, no support is needed for the intermediate shaft, so no firewall reinforcement is needed. The bezel shown in engine bay was made by Ted & Terry, and has a rubber bushing to seal the firewall, with the shaft just passing through.
danmas
Dan Masters
Jan 13, 2018 02:04 PM
In reply to # 3660884 by limey222
FIO, the racks used by Fast Cars is custom made for Fast Cars by a company that, I believe, is American.
Jan 13, 2018 10:55 PM
Dan is there a reason Ted & Terry kept the upper universal joint driver side of the firewall? Maybe the length of the column used?
danmas
Dan Masters
Jan 15, 2018 04:25 PM
In reply to # 3661489 by MGB567
No particular reason, it just worked out better that way.
rficalora
Rob rficalora
Cypress, TX, USA
Jan 15, 2018 05:11 PM
Barrie - remember that Dan has the FastCars front end. It uses a shaft with U-joints at top and bottom so it's easy to allow for differences in the flaming River column length vs OEM simply by altering the steering shaft length. If you have the stock front end, the steering shaft is integrated with the steering rack so column length is more critical to ensure your steering wheel ends up where you want it. If necessary Flaming River offers custom length columns (although probably at a premium vs their standard lengths).
Jan 15, 2018 06:10 PM
Thanks Dan. Rob I too have Fastcars FE.
I was just wondering if there was a particular reason for putting the UJ inside. I've already cut-to-length an intermediate shaft from the FCFE steering uni to the OEM top uni. If the FR column had to have the top uni inside the car I'd need a new intermediate shaft. My OEM column measures 29.25" so I suspect a 30" collapsible might be in order with perhaps a trimming on my intermediate shaft depending on the upper UJ I use. FR columns through say Summit are considerably cheaper than buying direct and that's attractive due to our importation duties so I'm looking for the time being at off-the-shelf rather than customised.
V8MGBV8
Carl Floyd
Kinggsport, TN, USA
Jan 15, 2018 06:34 PM
![]() Joined 13 years ago
danmas
Dan Masters
Jan 15, 2018 07:17 PM
Jan 16, 2018 01:44 AM
"the u-joint is where it is because there isn't much room for it on the engine bay side."
Interesting. On my '79 there's quite a bit of space for the OEM uni engine side - it has its own housing; mind you fitting the shaft in and under the headers is an exercise in itself. Guess I'll need to work out which FR uni I need and then its length. It's no biggie as I can always buy a new intermediate shaft long enough to go through the firewall and put the uni driver's side. I was just going to attach something like that below to the inside firewall.
rmorgansr
Robert Morgan
Milford, DE, USA
Jan 17, 2018 03:14 AM
Joined 3 years ago
Forums
