Flaming River column
  This topic is about my 1979 MG MGB GT V8 Conversion
While I wait and see if Danmas answers my PM for those who've fitted a Flaming River column can you tell me something about how best to attach it to the car both under the dash where the three lugs are and to the firewall. Presumably for the latter I need one of these products but which is best? I searched like here but haven't found a how to yet - I'm looking at a non-collapsible ie not tilt.
rficalora Avatar
rficalora Rob rficalora
Cypress, TX, USA   USA
Barrie, I'm sure Dan will be along to help with info. In the meantime, have a look at his How it Was Done on BritishV8... http://www.britishv8.org/MG/DanMasters.htm. There are a couple of pics that show a hoop shaped bracket made to line up with at least 2 of the captive nuts on the OEM bracket. Here's one of the pics but there's at least one more too.
DanMasters-EC.jpg    66 KB
Thanks Rob - yes Dan has just sent me lots of links to study over the weekend thumbs up
Dan linked his car's build with pictures that can be enlarged but I'm still at a bit of a loss and need info if anyone has it. In this topic it's confirmed that the OEM collapsible columns all used the same method of attachment to the cradle under the dashtop/scuttle - the three lugs. Obviously to attach a FR column I'll need to modify that cradle so I can use one/two of these but I'm wondering do I need one or two saddles - I think Dan only has one; that's all I can see in the pic but my eyes can deceive me.
Given I've come this far with alterations eg Fastcars FE & Bill's rear perhaps a fully integrated column too???????????
limey222 Avatar
Portland, OR, USA   USA
1969 MG MGB "Mandy"
I believe that Flaming River racks for the MGB may well be made by the same South American company that makes the aftermarket ones that Moss sells. I had a conversation with someone at Flaming River a few months ago when I was looking for an alternative to the Moss one and he in passing confirmed that theirs too are made in South America.
danmas Avatar
danmas Dan Masters
Alcoa, Tennessee, USA   USA
1974 MG MGB GT V8 Conversion "Powered By Ford"
Barrie,
Here are a couple more pics that may help. The column is mounted with two saddles that were homemade by Ted and Terry. Since there are only two UJs, no support is needed for the intermediate shaft, so no firewall reinforcement is needed. The bezel shown in engine bay was made by Ted & Terry, and has a rubber bushing to seal the firewall, with the shaft just passing through.
318186DB-D39A-42E8-8C8E-86DDE8AB9165.jpeg    94.6 KB
320A2C38-694D-46A3-B5D1-D83AE81D874B.jpeg    68.5 KB
28C67061-DBF8-4C78-81C7-E615071A987E.jpeg    52.6 KB
danmas Avatar
danmas Dan Masters
In reply to # 3660884 by limey222 I believe that Flaming River racks for the MGB may well be made by the same South American company that makes the aftermarket ones that Moss sells.
FIO, the racks used by Fast Cars is custom made for Fast Cars by a company that, I believe, is American.
Dan is there a reason Ted & Terry kept the upper universal joint driver side of the firewall? Maybe the length of the column used?
danmas Avatar
danmas Dan Masters
In reply to # 3661489 by MGB567 Dan is there a reason Ted & Terry kept the upper universal joint driver side of the firewall? Maybe the length of the column used?
No particular reason, it just worked out better that way.
rficalora Avatar
Barrie - remember that Dan has the FastCars front end. It uses a shaft with U-joints at top and bottom so it's easy to allow for differences in the flaming River column length vs OEM simply by altering the steering shaft length. If you have the stock front end, the steering shaft is integrated with the steering rack so column length is more critical to ensure your steering wheel ends up where you want it. If necessary Flaming River offers custom length columns (although probably at a premium vs their standard lengths).
Thanks Dan. Rob I too have Fastcars FE.
I was just wondering if there was a particular reason for putting the UJ inside. I've already cut-to-length an intermediate shaft from the FCFE steering uni to the OEM top uni. If the FR column had to have the top uni inside the car I'd need a new intermediate shaft. My OEM column measures 29.25" so I suspect a 30" collapsible might be in order with perhaps a trimming on my intermediate shaft depending on the upper UJ I use. FR columns through say Summit are considerably cheaper than buying direct and that's attractive due to our importation duties so I'm looking for the time being at off-the-shelf rather than customised.
V8MGBV8 Avatar
V8MGBV8 Carl Floyd
Kinggsport, TN, USA   USA
IMO, the u-joint is where it is because there isn't much room for it on the engine bay side.
danmas Avatar
danmas Dan Masters
In reply to # 3662618 by V8MGBV8 IMO, the u-joint is where it is because there isn't much room for it on the engine bay side.
That’s what I was trying to say smiling smiley
"the u-joint is where it is because there isn't much room for it on the engine bay side."
Interesting. On my '79 there's quite a bit of space for the OEM uni engine side - it has its own housing; mind you fitting the shaft in and under the headers is an exercise in itself. Guess I'll need to work out which FR uni I need and then its length. It's no biggie as I can always buy a new intermediate shaft long enough to go through the firewall and put the uni driver's side. I was just going to attach something like that below to the inside firewall.
floor mount.jpg    10.6 KB
rmorgansr Avatar
rmorgansr Robert Morgan
Milford, DE, USA   USA
What’s the total length of your column?
1979 MG MGB Limited Edition LE
