Ecoboost Swap
scott68B Avatar
scott68B Scott Costanzo
Central, OH, USA   USA
1968 MG MGB "GM 5.3 LS4 V8"
Gary,
You're going to have one sweet ride when you get it done in spite of it being a Ford! smiling smiley
Jeepstang Avatar
Jeepstang Gary Alvino
Beverly Hills, FL, USA   USA
Scott,
Flattery will get you nowhere, come to think of it......Chevy power won't get ya'll too far eithersmiling bouncing smiley
Jeepstang Avatar
Reinstalled engine to check final clearance at firewall patches and pedal box, looks good.
And Today's Chuckle,
My Focus ST engine harness arrived today, when I opened the box this was the label that was attached to the harness,
well, yeah......
P1020998.JPG    47 KB
P1030006.JPG    45.8 KB
BryanRVA Bryan Gerrells
Midlothian, VA, USA   USA
That's funny. They didn't know how correct they were with that sticker spinning smiley sticking its tongue out
Edited 1 time(s). Last edit at 2018-02-13 08:13 AM by BryanRVA.
V8MGBV8 Avatar
V8MGBV8 Carl Floyd
Kinggsport, TN, USA   USA
It doesn't look like it in the pic, but the bonnet hinge actually does clear the accelerator housing?
Jeepstang Avatar
Hinge clears with 1 1/2" to sparesmiling smiley
Back of intake to firewall is close though, about 1/2" clearance.
1744 Avatar
1744 Gold Member Bill Guzman
CA, USA   USA
1974 MG MGB "Renegade"
The 350/290 is $2400 and without small chamber heads.
Jeepstang Avatar
Hey, hey,
This project is a bowtie free zonespinning smiley sticking its tongue outangry smileyXsmiling bouncing smiley
TVR Scott Scott Noble
Denver, CO, USA   USA
I'm working on a similar swap and have run into a few issues.
Just bought a throttle body, and it doesn't want to work with the new intake manifold that came with the N/S Orientation kit. You have a picture of how you mounted yours? Did you have to sand off a little of the manifold?
What fuel pump and regulator are you using?
Thanks!
Scott
Jeepstang Avatar
Hi Scott,
I haven't installed the TB yet but it matches perfectly with the N-S intake manifold. My engine is a 2014 Fusion, stock TB.
Still working on engine compartment, making brackets to install Honda/Mitsu alternator on right side of engine above turbo.
Fuel pump & regulator are down the road a bit but it will be a mounted in the tank.
Zimm Avatar
Zimm Scott Zimmermann
Pittsburgh, PA, USA   USA
I'm looking forward to reading about 100+ pounds off the front and this much HP. Ought to be a blast.
Jeepstang Avatar
I'm looking forward to it more than you can imagine but it's going to be awhile. The car is losing more than 100 lbs off the front end after removing the front rubber bumper, I had to cut away the bumper mounting rails to fit the intercooler in the grill opening.
Update pics coming shortly.
Denver, CO, USA   USA
Gary, did you get your engine harness installed? Did you remove about half of it???
I got my new harness, and it seems to have a lot of body-side connectors or something. I don't have the Control Pack yet, but it looks like that only has one big multi-pin connector. So I'm guessing the others on the engine harness are body-related and can be removed.
Jeepstang Avatar
Scott,
No, I haven't installed the new harness yet. I do have the Control Pack and the included instructions clearly state what wires/plugs are used and what plugs need to be cut or eliminated.
You can download the Ford Performance Instructions here to give you a better idea how to proceed,
https://performanceparts.ford.com/part/M-6017-20T
1958 MG Magnette ZB Varitone
