Exhaust Manifold Gasket Midget 1500
GreenBee Silver Member Daniel Sukel
Maplewood, NJ, USA   USA
1968 MG MGB "The "B"
1976 MG Midget 1500
So trying to solve my engine surge upon start up on my 76' Midget, wearing a DGAV 32/36 Weber, there is a lot of smoke pouring out of the manifold to head. I'm guessing that is where my vacuum leak may be originating from? Is it a standard exhaust manifold gasket I need to order for a 1500, or do I need something specific to the Weber set-up I'm not sure if you can see but on the first image there a wisps of smoke coming up below the fuel filter, and on the second near the back of the manifold to the right. The video I took is much more compelling, however its to large to download. TIA
IMG_2738.jpg    25 KB
IMG_2739.jpg    39.1 KB
Fresno, CA, USA   USA
STANDARD> thumbs up
1976 MG Midget 1500
Thanks Joe winking smiley
Fresno, CA, USA   USA
Daniel: Also if possible, at least lay a straight edge across the manifold's to see if they are pretty straight. You can pick up a piece of aluminum flat stock at like "Home Depot" or "Lowes" and use the "EDGE" to check for "Flatness"
You may have to take the manifold to an "Auto Machine Shop". and have them run it on their "BIG Belt sander. They usually have HUGH ones to lightly flatten cylinder heads and the like. Have Fun. smileys with beer
1976 MG Midget 1500
Will do!
